05-05-2015, 11:13 | #12436 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: SL3 LBF IN Kamoke(Gujranwala)
Member: 481915 Status: Offline Sonork: 100.1604233 Thanks Meter: 476 | with pack-6 by selecting "Alcatel MTK (SerialUSB)" Instructions: 1- phone must be off 2- in comport selection select USB, then press read codes 3- press (*) Key and attach usb cable to phone here is Log: Quote:
05-05-2015, 14:08 | #12437 (permalink) |
No Life Poster Join Date: May 2005 Location: Bulgaria Age: 49
Member: 142632 Status: Offline Sonork: 100.1589012 Thanks Meter: 459 | Unlock Alcatel Y580D 3G-WiFi Successful unlock Alcatel Y580D-2***BG3 3G-WiFi I use PACK 5 ,QCOM_SMART_TOOL_v1.0.0.9198 and DIRECT UNLOCK ! Software engine version: 1.0.0.9198 Searching phone ... MODEL : QCOM SERIES 44 COMPILED DATE : Sep 20 2012 15:16:00 RELEASE DATE : Aug 14 2012 11:00:00 FIRMWARE INFO : YX171P008X IMEI : 86996400xxxxxx-x BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; WORKING; UNLOCK CONTROL KEY: 0393019824 SIM_LOCK REMOVED ! RESET ! Log file saved to: LOG_5_05_2015_16_02_16.txt Time needed - 00:00:15 THANKS FURIOUS TEAM !!! |
05-06-2015, 14:25 | #12438 (permalink) |
Freak Poster Join Date: Nov 2006 Location: Accra, Ghana
Member: 390671 Status: Offline Thanks Meter: 31 | HTC desire unlock 320 done!!! Searching phone; Phone detected (@oem138.inf,%mtk_preloader%;PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Gadget VCOM Driver (COM185); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6582, E01 Sw version: MOLY.WR8.W1315.MD.WG.MP.V42.F1.P9 Hw Version: CCI82_WE_UC81_KK_HSPA_HW Reading phone info; IMEI: 355036-xx-xxxxxxx-x Reading simlock info; Locked to: 302-22 code_cat_n: 83554536 enabled: yes tries: 10 code_cat_ns: 56781234 enabled: no tries: 11 code_cat_sp: 11112222 enabled: no tries: 11 code_cat_c: 33334444 enabled: no tries: 11 code_cat_sim: 55556666 enabled: no tries: 11 code_cat_ns_sp: 77778888 enabled: no tries: 11 code_cat_sim_c: 99990000 enabled: no tries: 11 Time needed - 00:01:10 |
05-08-2015, 08:34 | #12439 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Romania,Sinaia
Member: 637351 Status: Offline Thanks Meter: 167 | Alcatel 2001x unlocked done.. Code: Using library Brom_DLL_v5.1316.1 Searching phone; (for some models keep SPACE or * (STAR) key pressed before inserting the cable) Phone detected (MTK USB Port) Preparing to start meta mode; Requesting authorization; Done; Meta mode entered; Baseband Chip: MT6250 Sw version: MAUI.11B.W12.24.MP.V2.F42 Hw Version: JRDHZ50_12864_11B_24MP_HW Reading phone info; IMEI: 861292-02-3xxxxx-x Reading security; Done; Checking; Preparing; Writing security; Phone unlocked; Remove battery and cable; Time needed - 00:00:21 |
05-08-2015, 17:36 | #12440 (permalink) |
No Life Poster Join Date: Dec 2009 Location: CIEGO DE AVILA ,CUBA
Member: 1176958 Status: Offline Thanks Meter: 158 | vodafone 710 unlock done Searching phone ... MODEL : D618 V1.0 G Download mode entered ... Loading bootloader ... Requesting random data ... Completed ... Init nand made; Reading; Imei : 35197901147316-2 Unlock code: 1842554369216113 Done ! Time needed - 00:00:12 |
The Following User Says Thank You to yaro_rguez For This Useful Post: |
05-09-2015, 05:22 | #12441 (permalink) |
No Life Poster Join Date: Dec 2006 Location: BEST COUNTRY
Member: 421947 Status: Offline Sonork: 100:1658491 Thanks Meter: 239 | COOLPAD FIO unlock DONE Software engine version: 1.0.0.9201 Searching phone ... MODEL : QCOM SERIES 35 COMPILED DATE : Oct 29 2013 13:53:00 RELEASE DATE : Dec 5 2012 19:00:00 FIRMWARE INFO : 8X25-SSRSKOLYM-2050 IMEI : 86242508014582-0 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; WORKING; SAVED: 164893BDC1008F7BE89F64A9AC812081.bin UNLOCK CODE: N/A DONE; SIM_LOCK REMOVED ! RESET ! Log file saved to: LOG_9_05_2015_09_16_43.txt Time needed - 00:00:42 |
05-09-2015, 13:07 | #12443 (permalink) |
No Life Poster Join Date: Mar 2012 Location: *#0011# NG
Member: 1736804 Status: Offline Sonork: @kanokh / @imeione Thanks Meter: 451 | succsesfully Unlock Alcatel OT-4037R with FG succsesfully Unlock Alcatel OT-4037R with FG Last edited by .:hack3r2k:.; 05-10-2015 at 10:50. |
05-09-2015, 20:44 | #12444 (permalink) |
No Life Poster Join Date: Jul 2011 Location: malawi
Member: 1614640 Status: Offline Thanks Meter: 468 | zte v795 unlocked with furious gold usb key Searching phone; Phone detected (@oem37.inf,%vcom_preloader%;PreLoader USB VCOM (Android)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Gadget VCOM Driver (COM97); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6572, E01 Sw version: MOLY.WR8.W1315.MD.WG.MP.V4.P9 Hw Version: ZTENJ72_WE_GB3_HSPA_HW Reading phone info; IMEI: 863372-02-198985-9 Reading simlock info; Locked to: 001-01 code_cat_n: 12345678 enabled: yes tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Time needed - 00:02:19 |
The Following User Says Thank You to bright hlatini For This Useful Post: |
05-10-2015, 13:02 | #12445 (permalink) |
No Life Poster Join Date: Apr 2010 Location: pakistan Age: 48
Member: 1275418 Status: Offline Thanks Meter: 432 | srf 1180 unkock Using library Brom_DLL_v5.1316.1 Searching phone; (for some models keep SPACE or * (STAR) key pressed before inserting the cable) Phone detected (MTK USB Port) Preparing to start meta mode; Meta mode entered; Baseband Chip: MT6260 Sw version: V05_M131030_UL18_SFR1180_MP Hw Version: SAGETEL60A_12864_11B_HW Reading phone info; IMEI: 359562-05-103019-1 Reading security; Done; Checking; Preparing; Writing security; Phone unlocked; Remove battery and cable; Time needed - 00:00:28 |
05-10-2015, 13:02 | #12446 (permalink) |
Member: 1275418 Status: Offline Thanks Meter: 432 | 3002g flash Using library Brom_DLL_v5.1316.1 EMI Settings Loaded; COM opened ok; Press power and keep it pressed now ! Requesting authorization; Done; Connecting; Downloading DA; Initializing; Requesting baudrate change; Done; DEVICE INFO: BB CHIP: MT6250_S0001 [CA01, 01, 625A, 05] MEMORY: [Numonyx] N25W256 [2C:CB:19] [SIZE=0x02000000] FAT INFO: 0x00E80000 SIZE: 0x01180000 IMEI1 [OTP]: 861221-02-079287-5 IMEI2 [OTP]: N/A Loading the file ... Cfg done ... File contents to write: [70008000-7000B7E7] ARM_BL [FFFFFFFF-00000406] ROOT_CERT [10008000-100122F3] ARM_EXT_BL [10E7E000-10E7E9AB] SECURE_RO_ME [100C0000-108AF143] PRIMARY_MAUI [10980000-10C12FC3] CUSTOM_PACK [10D00000-10D02E33] STUDYPARA_ROM [10D03000-10D03517] JUMP_TABLE [10D04000-10DA3DD3] VIVA Downloading bootloader... Done; Pre-formatting code area.. Done; Downloading images... Done; Done; Done; Done; Done; Done; Done; Formatting file system now... Done; Time needed - 00:21:54 |
05-10-2015, 13:03 | #12447 (permalink) |
Member: 1275418 Status: Offline Thanks Meter: 432 | Using library Brom_DLL_v7.1413.5 Searching phone; Phone detected (PreLoader USB VCOM Port) Preparing to start flash mode; Preparing to open COM24 Connecting; Downloading DA; Initializing; Rid: e6a80bc74a0542b3a824d15d1bf22b16 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (DA USB VCOM Port) TRYING TO OPEN COM58; DEVICE INFO: BB CHIP: MT6572_S00 [CA01, 00, 6572, FF] HW_STORAGE_EMMC: 0x30000111 0x39473430 0x1BA21030 0x9761E639 [SIZE=0xEC480000] IMEI1 [OTP 0001]: 355250-06-085900-8 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: V785-2BVDNL1 USRDATA INFO: 0x61B80000 SIZE: 0x8A900000 Searching data; Locked to [SIM1]: 204-04 code_cat_n: 23502734 enabled: yes tries: 0 code_cat_ns: 26880206 enabled: no tries: 10 code_cat_sp: 00025793 enabled: yes tries: 10 code_cat_c: 39501828 enabled: no tries: 10 code_cat_sim: 00023880 enabled: no tries: 10 code_cat_ns_sp: 53297761 enabled: no tries: 5 code_cat_sim_c: 86817778 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:18 |
05-10-2015, 13:03 | #12448 (permalink) |
Member: 1275418 Status: Offline Thanks Meter: 432 | Software engine version: 1.0.0.9200 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Dec 2 2009 11:18:00 RELEASE DATE : Aug 26 2009 02:00:00 FIRMWARE INFO : H3G_GB_P607C3V2.0.0B04-S IMEI : 35674003316017-8 BLUETOOTH ADDR : A8 E9 05 37 F5 98 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 234 MNC: 20) LOCKED NET 1 (MCC: 235 MNC: 94) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Log file saved to: LOG_25_04_2015_00_07_21.txt Time needed - 00:00:48 |
05-10-2015, 13:03 | #12449 (permalink) |
Member: 1275418 Status: Offline Thanks Meter: 432 | Software engine version: 1.0.0.9198 Searching phone ... MODEL : QCOM SERIES 2 [KYUZ] COMPILED DATE : Dec 1 2008 09:33:00 RELEASE DATE : Nov 12 2008 22:00:00 FIRMWARE INFO : M6260A-KYRZ-2.5.1033_8A IMEI : 35454102511447-6 BLUETOOTH ADDR : 11 18 51 40 12 00 MEMORY ID : 00AD:0078 MEMORY NAME : hynix_h8acs0ej0mcp MEMORY INFO : 0200:0020:1599 INIT NAND ROUTINES; NAND INIT MADE; PROCESS STARTED; READING; ERASING; WRITING; RESET ! Log file saved to: LOG_8_04_2015_06_10_36.txt Time needed - 00:00:37 |
05-12-2015, 09:04 | #12450 (permalink) |
No Life Poster Join Date: Aug 2008 Location: The Matrix :) Age: 36
Member: 833760 Status: Offline Sonork: 100.1597150 Thanks Meter: 114 | Code: Software engine version: 1.0.0.9203 Searching phone ... MODEL : QCOM SERIES 41 COMPILED DATE : Nov 27 2014 16:12:00 RELEASE DATE : May 22 2014 23:00:00 FIRMWARE INFO : MPSS.DI.2.0.c11.1-00012-M8926DAAAANAZM-1 IMEI : 86440902027932-7 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; WORKING; SAVED: 12DF44418D45E2EE195A94E847EBCA82.bin UNLOCK CODE: N/A DONE; DOING EXTRA CALCULATION; AFTER UNLOCK YOU MUST RESTART THE PHONE MANUALLY; SIM_LOCK REMOVED ! RESET ! Log file saved to: LOG_12_05_2015_10_00_52.txt Time needed - 00:00:20 |
