09-22-2009, 05:22 | #1246 (permalink) |
Freak Poster Join Date: Apr 2009 Location: manila
Member: 1003463 Status: Offline Thanks Meter: 67 | BB 9630 unlock code by FG! Reading info ... IMEI: 359486026581*** Calculating ... MEP: MEP-15326-002 MEP2 CODE: 45925800 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:23 tnx FG! |
The Following User Says Thank You to dOn_eM888 For This Useful Post: |
09-22-2009, 08:53 | #1247 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Kotla arab ali khan Age: 56
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | LG cu 920 unlock ok FG Software engine version: 1.0.0.2824 Searching phone ... MODEL : CU920 COMPILED DATE : Dec 12 2008 14:36:00 RELEASE DATE : Nov 10 2008 23:00:00 FIRMWARE INFO : CU920-MSM4090201D-V10s-DEC-12-2008-ATT-US IMEI : 01184700432695-6 BLUETOOTH ADDR : 0D FF 36 E5 25 00 MEMORY ID : 0098:00CA MEMORY NAME : toshiba_tya000bc00dogg MEMORY INFO : 0800:0040:0696 INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:09 |
09-23-2009, 08:31 | #1248 (permalink) |
Member: 1003463 Status: Offline Thanks Meter: 67 | BB STORM 9500 unlock code by FG!!! another BB STORM 9500 unlock code by FG!!! Searching for usb device ... Reading info ... IMEI: 353472030182*** Calculating ... MEP: MEP-09747-001 MEP2 CODE: 4848413162626592 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:19 tnx FURIOUS TEAM!! |
09-24-2009, 12:15 | #1249 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Lg ks360 unlocked sucessfully:)- Press power on ! Starting communication ... Platform: S-Gold3 ... Preloader sent .... Loader sent .... CODE: 50643189 Power on phone with original sim. Type 2945#*71001# and enter code. Done ! Time needed - 00:00:16 WBR sahil2000ind |
09-24-2009, 13:56 | #1250 (permalink) |
Freak Poster Join Date: Oct 2005 Location: Dar-es-salaam
Member: 187686 Status: Offline Sonork: GHANIM Thanks Meter: 48 | Press power on button ... Starting communication ... BootRom v05.02 Authorising ... Sending preloader ... Preloader started ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Requesting baudrate change ... Baudrate changed ... Flash ID(0): 0001:2C7E:3500 Looking simlock data ... Imei: 3576860******** Reading simlock data ... Writing simlock data ... Done ! Time needed - 00:01:05 |
09-25-2009, 03:47 | #1251 (permalink) |
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | blackberry 8310 unlock ok FG Searching for usb device ... Reading info ... IMEI: 358516021310969 Calculating ... MEP: MEP-06424-002 MEP2 CODE: 7039177317112608 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:11 |
09-25-2009, 08:47 | #1252 (permalink) |
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | T 156 unlock ok FG cable use c2500 Press power on ! Start auth ! SW Ver: P1.2PU02V01.01 Imei: 353081034572738 PhoneLock Reset success ! Unlocked ! Done ! Time needed - 00:00:06 |
09-25-2009, 12:33 | #1253 (permalink) |
No Life Poster Join Date: Mar 2001 Location: ALBANIA(Tirana) Age: 51
Member: 3617 Status: Offline Thanks Meter: 579 | Lg kp 502 Press power on ! Starting communication ... Platform: S-Gold3 ... Preloader sent .... Loader sent .... CODE: 51869645 Power on phone with original sim. Type 2945#*71001# and enter code. Done ! Time needed - 00:00:15 |
09-26-2009, 08:22 | #1256 (permalink) |
Insane Poster Join Date: Jan 2007
Member: 441074 Status: Offline Thanks Meter: 13 | cu515 lg unlocking succes COMPILED DATE : Nov 27 2007 17:51:00 RELEASE DATE : Sep 5 2007 04:00:00 FIRMWARE INFO : CU515-MSM21302430-V10g-NOV-27-2007-ATT-US IMEI : 01166600635036-2 BLUETOOTH ADDR : 00 21 FB 38 F1 A9 MEMORY ID : 0098:00C1 MEMORY NAME : toshiba_ty9000a800jogg MEMORY SIZE : 93MB PERFORMING OPERATION ... READING NV ... READY... SW VERSION: [OK] CU515FL-V10g-01-310-410-00-01-01-NOV-27-2007+0 IMEI: [OK] 01166600635036200 BLUETOOTH ADDR: [OK] A9F138FB2100 FORMAT: [OK] IDDE OK CU515 NV FILE VERSION 2 WITH 829 RECORDS. WRITING NV ... WRITE ERROR: 3252 WRITE ERROR: 3462 RESETTING ... Time needed - 00:00:53 |
09-26-2009, 10:21 | #1257 (permalink) |
No Life Poster Join Date: Apr 2009 Location: lebanon Age: 37
Member: 1008455 Status: Offline Sonork: 0000 Thanks Meter: 99 | thanks fg team Searching for usb device ... Reading info ... IMEI: 355167022198517 Calculating ... MEP: MEP-04104-007 MEP2 CODE: 8099276227502714 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:13 -------------------------------------------------------------- Press power on ! Start auth ! SW Ver: P1.2JD01V01.03:ULC2GL Imei: 358545028603316 PhoneLock Reset success ! Unlocked ! Done ! Time needed - 00:00:13 ------------------------------------------------------------- Searching for usb device ... Reading info ... IMEI: 357778000354837 Calculating ... MEP: MEP-06814-001 MEP2 CODE: 2473931562159744 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:13 ------------------------------ Searching phone ... MODEL : M6275A-OEMS Download mode entered ... Loading bootloader ... Requesting random data ... Completed ... Memory Info: 00EC:0036 Nand init done; Reading; Imei : 35495301208370-7 Reading; SP saved to: SP_35495301208370_6C8_11.48.25_25.09.2009_HUAWEI.b in Erasing; Writing; Unlocked ! Checking for password presence ... Found 1 password(s) ! Password (0): 00000000 Done ! Time needed - 00:00:55 ------------------------------------------------ |
09-26-2009, 13:49 | #1258 (permalink) |
Banned Join Date: May 2003 Location: Heavens
Member: 30124 Status: Offline Sonork: 100.1590000 Thanks Meter: 7,900 | Software engine version: 1.0.0.2537 Searching phone ... MODEL : L704 COMPILED DATE : Oct 7 2007 03:48:00 RELEASE DATE : Aug 7 2007 00:00:00 FIRMWARE INFO : L704i-MSM2340555C-V10a-OCT-02-2007-DCM-JP IMEI : 35500701144579-4 BLUETOOTH ADDR : 00 00 00 00 00 00 MEMORY ID : 0098:00CA MEMORY NAME : toshiba_tya000bc00dogg MEMORY INFO : 0800:0040:0686 INIT NAND ROUTINES; NAND INIT MADE; UNLOCKED ! Time needed - 00:00:17 |
09-27-2009, 03:43 | #1260 (permalink) |
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | U 890 unlock ok fg Software engine version: 1.0.0.2824 Searching phone ... MODEL : U890 COMPILED DATE : Apr 18 2006 14:28:00 RELEASE DATE : Apr 18 2006 17:00:00 FIRMWARE INFO : U890-MSM6250A-V10a_wm-APR-18-2006-H3G-UK IMEI : 35921300048148-7 BLUETOOTH ADDR : D1 62 2D 56 12 00 MEMORY ID : 0098:0079 MEMORY NAME : toshiba_ty9000ac10aobg MEMORY INFO : 0200:0020:1980 LOADING INIT DATA; RESETTING PHONE ! WAITING FOR PHONE TO POWER ON 30 SEC; PHONE ONLINE; SW VERSION: [OK] MODULE ERROR IMEI: [OK] 35921300048148700 BLUETOOTH ADDR: [OK] D1622D561200 PLAYING MUSIC ... WAIT; DOING CONFIG; INJECTING VODKA; INJECTING JUICE; DRINKING; DANCING; STAT: ON NAND UNLOCK DONE; PROCESS STARTED; READING; ERASING; WRITING; READING; ERASING; WRITING; UNLOCKED ! Time needed - 00:01:19 |
