09-09-2015, 15:12 | #12632 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Alcatel 2050G SPD phone direct Unlock done... other box failed... Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (SCI USB2Serial) Preparing to sync; Port opened [COM10]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT Chip type: 6531 FdlStat: 0000 Starting auth; HW IMEI : 862644-02-005756-0 Memory [CS0]: 00EF:0040:0016 - SIZE : 00400000 Reading phone info; PHONE INFO: 2050G-3DSFFR1 BT ADDR: 0C:82:C4:02:2D:E4 SW IMEI[0]: 352273-01-738634-0 SW IMEI[1]: 352751-01-952326-7 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: ON FIXED NV BASE: 303A8000 Reading NV; NV saved to : NV_862644-02-005756-0_352273-01-738634-0_65310000_8_09_2015_16_51_34.spd IMEI: 862644-02-005756-0 UNLOCK CODE: 61232114 Re-programming; NV programmed; Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_8_09_2015_16_52_02.txt Time needed - 00:00:42 |
09-09-2015, 19:00 | #12633 (permalink) |
Freak Poster Join Date: Dec 2009 Location: JAM
Member: 1196714 Status: Offline Thanks Meter: 238 | SM-N900A Android Version: 5.0 Finished successfully. Chimera Mobile Phone Utility version: 7.61.1649 @ 2015-09-08 [Unlock phone started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-N900A Android Version: 5.0 Sales Code: ATT PDA Version: N900AUCUEOC1 [march 2015, rev1] Phone Version: N900AUCUEOC1 [march 2015, rev1] CSC Version: N900AATTEOC1 [march 2015, rev1] Product Code: SM-N900AXXXATT HIDSw Version: N900AUCUEOC1/N900AATTEOC1/N900AUCUEOC1/N900AUCUEOC1 Board Platform: MSM8974 Serial Number: R31D90QKAQH Imei: 357572050XXXXXX Unique Number: CMB002B89B47990 Connections: AT,MTP Battery Status: 4.24V (90%) SIM Status: ABSENT Knox Version: v30 Warranty Bit: 0 Checking root state... Not rooted. There is no backup, because there is no root access. Unlocking... Trying on SAMSUNG Mobile USB Serial Port (COM9) Unlocked. Finished successfully. Finished at local time: [09.08.15 18:22:23] WorkID: XXXXXXX |
09-09-2015, 19:01 | #12634 (permalink) |
Member: 1196714 Status: Offline Thanks Meter: 238 | Blackberry Q10 SQN 100-1 Successfully unlocked. Chimera Mobile Phone Utility version: 7.69.1527 @ 2015-09-09 [Direct unlock started.] Phone is in loader mode Updating software. Retrieving necessary files Files have been already downloaded! Retrieving necessary files Extracting: qcfm.image.com.qnx.qcfm.radio.qc8960.wtr.BB10_3_0. 1419.783508.signed Initializing phone mode Device recognized Flashing file Parsing file Start flashing Flashing has been finished Reconnected Flashing file Parsing file Start flashing Flashing has been finished Waiting for the phone connection. Please un-plug the cable, put in the battery, turn it on, re-plug the cable, wait for Chimera logo on your phone Phone found. Initializing usb connection. Testing usb connection. Usb successfully initialized. Waiting for the usb answer. Starting unlock ... Initializing phone mode Could not automatically restart the phone. Please, restart the phone or put out the battery and re-plug the cable. Device recognized Flashing file Parsing file Start flashing Flashing has been finished Reconnected Flashing file Parsing file Start flashing Flashing has been finished Successfully unlocked. Finished at local time: [09.09.15 09:56:27] WorkID: XXXXXXX |
09-09-2015, 19:08 | #12635 (permalink) |
Member: 1196714 Status: Offline Thanks Meter: 238 | SGH-I896 Android Version: 2.3.3 Finished successfully. Chimera Mobile Phone Utility version: 7.69.1527 @ 2015-09-09 [Unlock phone started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SGH-I896 Android Version: 2.3.3 Sales Code: ATT PDA Version: I896UXKH2 [august 2011, rev2] Phone Version: I896UXKH2 [august 2011, rev2] Product Code: SGH-I896ZKARWC HIDSw Version: I896UXKH2//I896UXKH2/I896UXKH2 Board Platform: S5PC110 Serial Number: 00000000000 Imei: 354182040XXXXXX Connections: DEBUG Battery Status: 4.10V (81%) Network Type: GSM SIM Status: ABSENT Rooting by generic root method 2... Rooting in progress. Be patient! Do NOT disconnect the phone! Root method failed. Rooting by generic root method... Checking root state... Rooted. Unlocking... Checking secure image. Storing secure image. Preparing secure block. Preparing image: #0. Preparing image: #1. Preparing image: #2. Success. Finished successfully. Finished at local time: [09.09.15 11:07:06] WorkID: XXXXXXX |
09-10-2015, 00:27 | #12637 (permalink) |
Freak Poster Join Date: Dec 2007
Member: 642071 Status: Offline Thanks Meter: 54 | Huawei model: Y220-u05 Using library Brom_DLL_v7.1413.5 Connecting; Be sure you unlock the phone screen; BRAND: HUAWEI MODEL: Y220-U05 ANDROID: v2.3.6 CPU: MT6572 IMEI: 86************* Trying to get root access; Done; Reading simlock data; Done; Locked to [SIM1]: 714-04 code_cat_n: 82390605 enabled: yes tries: 0 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Cleaning; Calculating; Reconnecting; Trying to get root access; Done; Unlocking; Done; Phone unlocked; Remove battery and cable; Time needed - 00:03:37 |
09-10-2015, 12:33 | #12638 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Alcatel OT-918 Direct Unlock done... Searching phone; Phone detected (PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on FTEAM USB Serial Port (COM65); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6573, E00 Sw version: MAUI.11AMD.W11.37.SP.V27.P35 Hw Version: JRD73_GIN_MODEM_GEMINI2_HW Reading phone info; IMEI: 860767-00-282453-3 Reading simlock info; Locked to: 613-02 code_cat_n: 36847893 enabled: yes tries: 3 code_cat_ns: 27658968 enabled: no tries: 10 code_cat_sp: 27201234 enabled: no tries: 10 code_cat_c: 27132762 enabled: no tries: 10 code_cat_sim: 35105285 enabled: no tries: 10 code_cat_ns_sp: 53297761 enabled: no tries: 5 code_cat_sim_c: 86817778 enabled: no tries: 5 Time needed - 00:01:12 Log file saved to: LOG_10_09_2015_11_17_15.txt |
09-10-2015, 15:05 | #12639 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Africa.uganda
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 247 | ZTE Z740 unlocked Connecting; Check your phone and "Always allow from this computer" and select "OK". Connected; BRAND: ZTE MODEL: Z740 ANDROID: v4.1.2 CPU: QCOM IMEI: 861897010126396 KERNEL: Linux version 3.4.0-svn9819 (xueyibing@zte) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 SMP PREEMPT Tue Sep 10 14:43:48 CST 2013 Cleaning; Loading files; Done; Reconnecting; Setting access; Initing kernel config; Done; Remapping; Done; Checking tz cfg; Checking modem; Done; Enabling i/o; Done; Exploiting; Done; Patching; Done; Enabling access; Done; Reading; Done; Reading simlock; Done; Backup saved to: 861897010126396_34B131B30769F8D03CC5248B7987F3C4 Checking simlock; Unlocking; Writing simlock; Done; Checking simlock status; Done; SIM_LOCK REMOVED ! RESTARTING ! |
The Following User Says Thank You to ibrajinja For This Useful Post: |
09-12-2015, 10:05 | #12640 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | etisalat 211fm unlock done Keep pressing the power button if serial used ! (for USB connection keep SPACE or * (STAR) key pressed and insert the usb cable) Connecting; Meta mode entered; Baseband Chip: MT6223, E05 Sw version: AE-UAE-ET-P109A2FMV1.0.0B04 Hw Version: 07A ZTENJ23_07A_PMJ Reading phone info; IMEI: 358614-02-014391-9 Reading simlock info; Unlock codes: Locked to: 424-02 code_cat_n: 860378060288 enabled: yes tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 1122FFFF enabled: no tries: 5 code_cat_c: 3344FFFF enabled: no tries: 5 code_cat_sim: 5566FFFF enabled: no tries: 5 code_cat_ns_sp: 7788FFFF enabled: no tries: 5 code_cat_sim_c: 9900FFFF enabled: no tries: 5 Time needed - 00:00:26 Log file saved to: LOG_12_09_2015_14_02_23.txt |
09-12-2015, 18:05 | #12641 (permalink) |
Member: 1196714 Status: Offline Thanks Meter: 238 | GT-I9305 Android Version: 4.3 Finished successfully. Chimera Mobile Phone Utility version: 7.70.1439 @ 2015-09-12 [Unlock phone started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: GT-I9305 Android Version: 4.3 Sales Code: EVR PDA Version: I9305XXUENH1 [august 2014, rev1] Phone Version: I9305XXUENG1 [july 2014, rev1] CSC Version: I9305EVRENH1 [august 2014, rev1] Product Code: GT-I9305TADEVR HIDSw Version: I9305XXUENH1/I9305EVRENH1/I9305XXUENG1/I9305XXUENH1 Board Platform: EXYNOS4 Serial Number: R31CA1H43DB Imei: 353575054XXXXXX Unique Number: CMAF14B0E48C47F Connections: AT,MTP Battery Status: 4.16V (91%) Network Type: GSM SIM Status: READY Warranty Bit: 0 Checking root state... Not rooted. There is no backup, because there is no root access. Unlocking... Trying on SAMSUNG Mobile USB Serial Port (COM15) Unlocked. Finished successfully. Finished at local time: [09.12.15 11:23:11] WorkID: XXXXXXX |
09-12-2015, 20:14 | #12642 (permalink) |
Member: 1196714 Status: Offline Thanks Meter: 238 | SM-G900T Android Version: 4.4.2 Finished successfully. Chimera Mobile Phone Utility version: 7.70.1439 @ 2015-09-12 [Unlock phone started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G900T Android Version: 4.4.2 Sales Code: TMB PDA Version: G900TUVU1BNH5 [august 2014, rev5] Phone Version: G900TUVU1BNH5 [august 2014, rev5] CSC Version: G900TTMB1BNH5 [august 2014, rev5] Product Code: XXXXXXXXXXXTMB HIDSw Version: G900TUVU1BNH5/G900TTMB1BNH5/G900TUVU1BNH5/G900TUVU1BNH5 Board Platform: MSM8974 Serial Number: RV8F40X0TTR Imei: 351881062XXXXXX Unique Number: CMA00D522D26731 Connections: AT,MTP Battery Status: 3.99V (62%) Network Type: GSM SIM Status: ABSENT Knox Version: v30 Warranty Bit: 1 Checking root state... Not rooted. There is no backup, because there is no root access. Unlocking... Trying on SAMSUNG Mobile USB Serial Port (COM29) Unlocked. Finished successfully. Finished at local time: [09.12.15 14:11:49] WorkID: XXXXXXX |
09-13-2015, 02:41 | #12643 (permalink) |
Member: 1196714 Status: Offline Thanks Meter: 238 | SM-J100H Android Version: 4.4.4 Finished successfully. Chimera Mobile Phone Utility version: 7.70.1439 @ 2015-09-12 [Unlock phone started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J100H Android Version: 4.4.4 Sales Code: XME PDA Version: J100HXXU0AOH1 [august 2015, rev1] Phone Version: J100HDXU0AOH1 [august 2015, rev1] CSC Version: J100HOLB0AOH1 [august 2015, rev1] Product Code: SM-J100HZKDINS HIDSw Version: J100HXXU0AOH1/J100HOLB0AOH1/J100HDXU0AOH1/J100HXXU0AOH1 Board Platform: SC8830 Serial Number: RZ1G71V72TY Imei: 352313071XXXXXX Unique Number: C0145B350DB62 Connections: AT,MTP Battery Status: 4.29V (90%) Network Type: GSM SIM Status: NETWORK_LOCKED SIM2 Status: ABSENT Knox Version: v00 Processing... Reading image #1 Storing image #1 Preparing image: #1 Writing image #1 Reading image #2 Storing image #2 Preparing image: #2 Writing image #2 Reading image #3 Storing image #3 Preparing image: #3 Writing image #3 Reading image #4 Storing image #4 Preparing image: #4 Writing image #4 Unlocked. Finished successfully. Finished at local time: [09.12.15 20:36:12] WorkID: XXXXXXX |
09-14-2015, 06:55 | #12645 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Romania,Sinaia
Member: 637351 Status: Offline Thanks Meter: 167 | Huawei Y530 successfully unlocked Code: Connecting; Check your phone and "Always allow from this computer" and select "OK". Connected; BRAND: HUAWEI MODEL: HUAWEI Y530-U00 ANDROID: v4.3 CPU: QCOM IMEI: 8649210277xxxxx KERNEL: Linux version 3.4.0+ (android@localhost) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Mon Aug 11 18:52:35 IST 2014 Cleaning; Loading files; Done; Reconnecting; Setting access; Done; Exploiting; Android v4.3 TRUE Backing up sec area; Done; Getting sec size; 00165832 bytes Decompressing; Backup saved to: 8649210277xxxxx Finished; IMEI: 8649210277xxxxx BT ADDR: 3C:47:11:C8:C9:63 MAC ADDR: 3C:47:11:C8:C1:6A BOOTLOADER PASS: 1619622710421212 MCC-MNC: 226-10 [orange/ro] LOCK [0] HASH: DEDA95CF6F990865A461A6A28AC4E982 LOCK [1] HASH: 05BC7148669669B5B792B12B28CFF4A2 LOCK [2] HASH: 9C1BEBC16FCCA72380EC926052C00015 LOCK [3] HASH: E9DA11DABD5014809922DF78C7B70FB9 LOCK [4] HASH: E9DA11DABD5014809922DF78C7B70FB9 LOCK [5] HASH: D7E7805904E4C16AF25116D94238B70A LOCK [6] HASH: D97E541A5DC214E3559C0BB61CB22B40 LOCK [7] HASH: E9DA11DABD5014809922DF78C7B70FB9 LOCK [8] HASH: E9DA11DABD5014809922DF78C7B70FB9 LOCK [9] HASH: E9DA11DABD5014809922DF78C7B70FB9 Starting; Done; Unlocking in progress; Calc 0000 ; Calc 0001 ; SIM_LOCK REMOVED ! Rebooting; Log file saved to: LOG_14_09_2015_08_50_24.txt Time needed - 00:00:55 |
