09-29-2015, 22:43 | #12691 (permalink) |
Freak Poster Join Date: Dec 2009 Location: JAM
Member: 1196714 Status: Offline Thanks Meter: 238 | Nokia Lumia 710 Read NCK done. [Read Nck.] Testing custom dload Waiting for reconnection Qualcomm.esco loaded, flashing... Waiting for reconnection Waiting for the phone ... Phone reconnected. Connected in qualcom mode, please release all buttons. Flashing DLOAD bootloader Writing dload to flash Syncing Restarting in DLOAD mode To start the new DLOAD, follow these steps: 1. Do NOT disconnect from USB 2. Please press VOLUME UP and POWER for 15 seconds 3. Release POWER (keep pressing VOLUME UP) 4. When connected, release everything Waiting for the phone ... Phone reconnected. You can release POWER now(keep pressing VOLUME UP) You can release the buttons now Test OK. Reading MODEM FS Reading using method A Found SFS1 @ c000000, S: 300000 Found SFS2 @ c300000, S: 300000 SFS1 read Preparing SFS2 Reading SFS2 started SFS2 read Everything read OK. Parsing NCK NCK: 44868114 NCK1: 44XXXXXX NCK2: 43XXXXXX NCK3: 75XXXXXX NCK4: 02XXXXXX NCK5: 16XXXXXX Read NCK done. Finished at local time: [09.29.15 16:32:54] WorkID: XXXXXXX |
09-30-2015, 13:38 | #12692 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Huawei Y330-U01 Direct Unlock done by MTK Code Reader... Searching phone; Phone detected (PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on MediaTek USB VCOM (Android) (COM87); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6572, E01 Sw version: MOLY.WR8.W1315.MD.WG.MP.V15.P11 Hw Version: HUAWEI72_WE_JB3_HSPA_HW Reading phone info; IMEI: 866508-02-435073-3 Reading simlock info; Locked to: 234-30 code_cat_n: 8518415421794231 enabled: yes tries: 10 code_cat_ns: 56781234 enabled: no tries: 10 code_cat_sp: 11112222 enabled: no tries: 10 code_cat_c: 33334444 enabled: no tries: 10 code_cat_sim: 55556666 enabled: no tries: 10 code_cat_ns_sp: 77778888 enabled: no tries: 10 code_cat_sim_c: 99990000 enabled: no tries: 10 Time needed - 00:02:01 Log file saved to: LOG_30_09_2015_12_34_33.txt |
10-01-2015, 15:12 | #12694 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Alcatel OneTouch Pixi 3 4013X Direct Unlock done.. Using library Brom_DLL_v7.1413.5 Searching phone; Phone detected (PreLoader USB VCOM Port (COM4)) Preparing to start flash mode; Preparing to open COM4 Connecting; Downloading DA; Initializing; Rid: 6e4c7f1117ca185c0b93c0e36c4690d5 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (DA USB VCOM Port (COM5)) TRYING TO OPEN COM5; DEVICE INFO: BB CHIP: MT6572_S00 [CA01, 00, 6572, FF] HW_STORAGE_EMMC: 0x46000115 0x43355835 0x53470142 0xB142EECC [SIZE=0xE9880000] IMEI1 [OTP 0001]: 356257-06-375867-2 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 4013X-2AOBGB1 USRDATA INFO: 0x6E380000 SIZE: 0x7B500000 Searching data; Locked to [SIM1]: 234-10 code_cat_n: 9940661408476287 enabled: yes tries: 10 code_cat_ns: 6900308400834478 enabled: no tries: 10 code_cat_sp: 2911081061436781 enabled: no tries: 10 code_cat_c: 6630010110181996 enabled: no tries: 10 code_cat_sim: 7339636983068292 enabled: no tries: 10 code_cat_ns_sp: 7339636983068292 enabled: no tries: 5 code_cat_sim_c: 7339636983068292 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:24 Log file saved to: LOG_1_10_2015_14_08_58.txt |
10-01-2015, 19:35 | #12695 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Alcatel OT-4037T Direct Unlock done by OTSmart... Using library Brom_DLL_v7.1413.5 Searching phone; Phone detected (MTK USB Port (COM61)) Preparing to start flash mode; Preparing to open COM61 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 630c565d162c830162c4383a99669da5 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (DA USB VCOM Port (COM5)) TRYING TO OPEN COM5; DEVICE INFO: BB CHIP: MT6582_S00 [CA00, 00, 6582, 05] HW_STORAGE_EMMC: 0x4E000115 0x4D5A5835 0x3AC90142 0xB77101C2 [SIZE=0xE9880000] IMEI1 [OTP 0001]: 014068-00-234525-5 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 4037T-2BWFUS1 USRDATA INFO: 0x6D080000 SIZE: 0x7C800000 Searching data; Locked to [SIM1]: 310-16 code_cat_n: 0665934082 enabled: yes tries: 3 code_cat_ns: 0200672875 enabled: no tries: 10 code_cat_sp: 1948816824 enabled: no tries: 10 code_cat_c: 2754303849 enabled: no tries: 10 code_cat_sim: 3948522397 enabled: no tries: 10 code_cat_ns_sp: 2408834735 enabled: no tries: 5 code_cat_sim_c: 1690759642 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:22 |
10-02-2015, 17:30 | #12696 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Vodafone 830 Direct Unlock done.. Searching phone ... MODEL : M6275A-OEMSBL Download mode entered ... Loading bootloader ... Requesting random data ... Completed ... Memory Info: 00EC:0078 Nand init done; Reading; Imei : 35426802002786-3 Reading; SP saved to: SP_35426802002786_5DD_16.23.59_02.10.2015_HUAWEI.b in LOCKED_TO: MCC-MNC [0]: F3F-F5 Erasing; Writing; Unlocked ! Checking for password presence ... Found 0 password(s) ! Done ! Time needed - 00:01:11 |
10-03-2015, 00:06 | #12698 (permalink) |
Member: 1196714 Status: Offline Thanks Meter: 238 | SM-J100H Android Version: 4.4.4 Finished successfully. Chimera Mobile Phone Utility version: 7.70.1439 @ 2015-10-02 [Unlock phone started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J100H Android Version: 4.4.4 Sales Code: ITV PDA Version: J100HXCU0AOG1 [july 2015, rev1] Phone Version: J100HXCU0AOG1 [july 2015, rev1] CSC Version: J100HITV0AOG1 [july 2015, rev1] Product Code: SM-J100HZKAITV HIDSw Version: J100HXCU0AOG1/J100HITV0AOG1/J100HXCU0AOG1/J100HXCU0AOG1 Board Platform: SC8830 Serial Number: R21G7241TMH Imei: 357539063XXXXXX Unique Number: C0113B05D0162 Connections: AT,MTP Battery Status: 4.21V (80%) Network Type: GSM SIM Status: NETWORK_LOCKED Knox Version: v00 Processing... Reading image #1 Storing image #1 Preparing image: #1 Writing image #1 Reading image #2 Storing image #2 Preparing image: #2 Writing image #2 Reading image #3 Storing image #3 Preparing image: #3 Writing image #3 Reading image #4 Storing image #4 Preparing image: #4 Writing image #4 Unlocked. Finished successfully. Finished at local time: [10.02.15 18:03:46] WorkID: 7214918 |
10-04-2015, 16:19 | #12699 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Burundi Bujumbura
Member: 750759 Status: Offline Sonork: 75101010 Thanks Meter: 169 | sharp Ads1 unlocked 100% Software engine version: 1.0.0.9796 Searching phone ... MODEL : QCOM SERIES 14 COMPILED DATE : Jun 22 2011 11:44:00 RELEASE DATE : May 4 2011 22:00:00 FIRMWARE INFO : AT8A_MC50.00 IMEI : 35565404073937-2 BLUETOOTH ADDR : 27 54 45 D1 C7 9C WORKING; SAVED: 922DABAAABA924E00368EBC7ED2824FD.bin UNLOCKED; POWER OFF PHONE TO COMPLETE THE UNLOCK; Log file saved to: LOG_4_10_2015_17_10_07.txt Time needed - 00:00:03 |
10-06-2015, 18:06 | #12700 (permalink) |
Major Poster Join Date: Apr 2011
Member: 1552974 Status: Offline Thanks Meter: 7 | Pcd g141 (spd service tool) Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (@oem116.inf,%usb\vid_1782&pid_4d00.devicedesc%;SP RD COM Enumerator) Preparing to sync; Port opened [COM25]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT Chip type: 6531 FdlStat: 0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00C8:0060:0016 - SIZE : 00400000 Reading phone info; PHONE INFO: NONE BT ADDR: F9:23:E9:4A:8F:7F SW IMEI[0]: 352273-01-738634-0 SW IMEI[1]: 352751-01-952326-7 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: OFF FIXED NV BASE: 303A8000 Reading NV; NV saved to : NV_000000-00-000000-0_352273-01-738634-0_65310001_6_10_2015_11_04_14.spd IMEI: 352273-01-738634-0 UNLOCK CODE: NONE ERROR: Simlock not enabled ! Phone is unlocked; Log file saved to: LOG_6_10_2015_11_04_25.txt Time needed - 00:00:22 |
10-07-2015, 07:14 | #12701 (permalink) |
No Life Poster Join Date: Apr 2008 Location: PhP Age: 42
Member: 757799 Status: Offline Thanks Meter: 782 | G6600 UNLOCK COM opened ok; Phone must be powered off; Keep pressing the power button if serial used ! (for USB connection keep SPACE or * (STAR) key pressed and insert the usb cable) Connecting; Meta mode entered; Baseband Chip: MT6235, E04 Sw version: E5.2AV01V01.06 Hw Version: BYD35_09A_PMWY_HW Reading phone info; IMEI: 356344-04-017090-6 Reading simlock info; Unlock codes: Locked to: 505-02 code_cat_n: 00787429 enabled: yes tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 1122FFFF enabled: no tries: 5 code_cat_c: 3344FFFF enabled: no tries: 5 code_cat_sim: 5566FFFF enabled: no tries: 5 code_cat_ns_sp: 7788FFFF enabled: no tries: 5 code_cat_sim_c: 9900FFFF enabled: no tries: 5 Time needed - 00:00:20 Log file saved to: LOG_7_10_2015_14_11_07.txt |
10-07-2015, 17:00 | #12702 (permalink) |
No Life Poster Join Date: Jan 2014 Location: africa mali
Member: 2098907 Status: Offline Thanks Meter: 154 | Flash alcatel 5020 done with fgold Using library Brom_DLL_v7.1413.5 Searching phone; Phone detected (MediaTek PreLoader USB VCOM Port (COM32)) Preparing to start flash mode; Preparing to open COM32 Connecting; Downloading DA; Initializing; Rid: 419ec689707a6ca383c2866e40889df9 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (MediaTek DA USB VCOM Port (COM46)) TRYING TO OPEN COM46; DEVICE INFO: BB CHIP: MT6575_S01 [CB00, E201, 6575, FF] HW_STORAGE_EMMC: 0x4E000115 0x30305535 0x9622024D 0x5F90226C [SIZE=0xE9420000] IMEI1 [OTP 0001]: 863039-01-089403-2 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5020X-2ARGML3 USRDATA INFO: 0x4AF4C000 SIZE: 0x9E4D4000 Loading the file ... Cfg done ... Formatting file system now... Done; Downloading bootloader... Done; Downloading images... Done; Success; Time needed - 00:04:40 Log file saved to: LOG_7_10_2015_17_47_57.txt |
10-07-2015, 18:18 | #12703 (permalink) |
Freak Poster Join Date: May 2015
Member: 2397754 Status: Offline Thanks Meter: 98 | Unlock ot-4009 done Using library Brom_DLL_v7.1413.5 Searching phone; Phone detected (PreLoader USB VCOM Port (COM60)) Preparing to start flash mode; Preparing to open COM60 Connecting; Downloading DA; Initializing; Rid: 9779a92ec5ca69ec2d0c228738267dce Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (MediaTek DA USB VCOM Port (COM99)) TRYING TO OPEN COM99; DEVICE INFO: BB CHIP: MT6572_S00 [CA01, 00, 6572, FF] HW_STORAGE_EMMC: 0x46000115 0x43355835 0xA1510142 0x2312B8C8 [SIZE=0xE9880000] IMEI1 [OTP 0001]: 356868-06-026045-2 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 4009X-2AAMMA1 USRDATA INFO: 0x61180000 SIZE: 0x88700000 Searching data; Locked to [SIM1]: 604-01 code_cat_n: 7686393084133950 enabled: yes tries: 6 code_cat_ns: 9640763761814082 enabled: no tries: 10 code_cat_sp: 4631746396328163 enabled: no tries: 10 code_cat_c: 4109718263807303 enabled: no tries: 10 code_cat_sim: 4987730574894161 enabled: no tries: 10 code_cat_ns_sp: 4987730574894161 enabled: no tries: 5 code_cat_sim_c: 4987730574894161 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:24 Log file saved to: LOG_7_10_2015_18_15_39.txt |
10-07-2015, 19:22 | #12704 (permalink) |
Member: 1196714 Status: Offline Thanks Meter: 238 | SM-G530AZ Android Version: 4.4.4 Finished successfully. Chimera Mobile Phone Utility version: 7.70.1439 @ 2015-10-07 [Unlock phone started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G530AZ Android Version: 4.4.4 Sales Code: AIO PDA Version: G530AZTUU3AOF5 [june 2015, rev5] Phone Version: G530AZTUU3AOF5 [june 2015, rev5] CSC Version: G530AZAIO3AOF5 [june 2015, rev5] Product Code: SM2G530AZWZAIO HIDSw Version: G530AZTUU3AOF5/G530AZAIO3AOF5/G530AZTUU3AOF5/G530AZTUU3AOF5 Board Platform: MSM8916 Serial Number: R28G62J6PDE Imei: 35754906XXXXXXX Unique Number: CQN00E3B9D04A62 Connections: AT,MTP Battery Status: 4.09V (76%) Network Type: GSM SIM Status: NETWORK_LOCKED Knox Version: v00 Warranty Bit: 0 Preparing backup... MODEMST1 stored. MODEMST2 stored. FSG stored. FSC stored. Unlocking... Initializing... Processing... Be patient! Do NOT disconnect the phone! Unlocked. Finished successfully. Finished at local time: [10.07.15 12:20:17] WorkID: XXXXXXX |
10-07-2015, 21:36 | #12705 (permalink) |
No Life Poster Join Date: Feb 2013
Member: 1890459 Status: Offline Sonork: 100.1627340 Thanks Meter: 149 | zte g pro unlock done Searching phone; Phone detected (@oem181.inf,%mtk_preloader%;MediaTek PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Gadget Serial (COM183); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6572, E01 Sw version: MOLY.WR8.W1315.MD.WG.MP.V1.P11 Hw Version: ZTENJ72_WE_JB3_HSPA_HW Reading phone info; IMEI: 862231-02-716xxx-x Reading simlock info; Locked to: 214-04 code_cat_n: 12345678 enabled: yes tries: 2 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Time needed - 00:00:36 Log file saved to: LOG_7_10_2015_22_26_14.txt Phone must be OFF press read codes connect usb cable while off (install mtk driver) and done |
