10-15-2015, 12:48 | #12721 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | PRESS AND KEEP RED BUTTON NOW ! PHONE FOUND WORKING... RELEASE PHONE POWER BUTTON ! FLASH CHIP: 00B0001D00000000 PROCESSING... READ DATA... PREPARE... WRITE DATA... Write: final eeprom region WORK DONE ! Time needed - 00:09:39 |
10-15-2015, 13:06 | #12722 (permalink) |
Freak Poster Join Date: May 2015
Member: 2397754 Status: Offline Thanks Meter: 98 | unlock samsung e1205y spd SW IMEI[3]: 910575-60-100046-8 SIMLOCK FLAG: ON FIXED NV BASE: 306A0000 Reading NV; NV saved to : NV_000000-00-000000-0_358274-06-710381-1_6530C000_15_10_2015_13_00_34.spd Calculating ... Freeze code: 93057184 NET lock: 00000000 Sub lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 Re-programming; NV programmed; Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_15_10_2015_13_01_42.txt Time needed - 00:01:11 |
10-15-2015, 17:58 | #12723 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Alcatel OT-3002G firmware flash done.. Using library Brom_DLL_v5.1316.1 EMI Settings Loaded; COM opened ok; Press power and keep it pressed now ! Requesting authorization; Done; Connecting; Downloading DA; Initializing; Requesting baudrate change; Done; DEVICE INFO: BB CHIP: MT6250_S0001 [CA01, 01, 625A, 05] MEMORY: [Numonyx] N25W256 [2C:CB:19] [SIZE=0x02000000] FAT INFO: 0x00E80000 SIZE: 0x01180000 IMEI1 [OTP]: 861221-02-069441-0 IMEI2 [OTP]: N/A Loading the file ... Cfg done ... File contents to write: [70008000-7000B7E7] ARM_BL [FFFFFFFF-00000406] ROOT_CERT [10008000-100122F3] ARM_EXT_BL [10E7E000-10E7E9AB] SECURE_RO_ME [100C0000-108AF143] PRIMARY_MAUI [10980000-10C12FC3] CUSTOM_PACK [10D00000-10D02E33] STUDYPARA_ROM [10D03000-10D03517] JUMP_TABLE [10D04000-10DA3DD3] VIVA Downloading bootloader... Done; Pre-formatting code area.. Done; Downloading images... Done; Done; Done; Done; Done; Done; Done; Formatting file system now... Done; Time needed - 00:13:07 |
10-16-2015, 12:49 | #12724 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | SWITEL SUNNY S52D Direct Unlock done.. Searching phone; Phone detected (PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Gadget VCOM Driver (COM28); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6572, E01 Sw version: MOLY.WR8.W1315.MD.WG.MP.V47.P3 Hw Version: HEXING72_CWET_KK_HSPA_HW Reading phone info; IMEI: 869758-00-590271-6 Reading simlock info; Locked to: 228-03 code_cat_n: 12345678 enabled: yes tries: 0 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Unlocking SIM2 too. Time needed - 00:02:00 Log file saved to: LOG_16_10_2015_11_45_52.txt |
10-16-2015, 14:37 | #12725 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Rabat
Member: 1209155 Status: Offline Thanks Meter: 110 | Amazon fire sd49330ur unlock succeful Software engine version: 1.0.0.9796 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jan 27 2015 10:11:00 RELEASE DATE : Jan 8 2015 00:00:00 FIRMWARE INFO : PB_02_06_12 IMEI : 01418600035099-2 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Log file saved to: LOG_17_10_2015_13_34_54.txt Time needed - 00:00:40 |
10-16-2015, 14:43 | #12726 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Alcatel OT-5020T Direct Unlock done.. Using library Brom_DLL_v7.1413.5 Searching phone; Phone detected (PreLoader USB VCOM Port (COM4)) Preparing to start flash mode; Preparing to open COM4 Connecting; Downloading DA; Initializing; Rid: a0bd478d2d4bc81a08872d68360fd488 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (DA USB VCOM Port (COM5)) TRYING TO OPEN COM5; DEVICE INFO: BB CHIP: MT6575_S01 [CB00, E201, 6575, FF] HW_STORAGE_EMMC: 0x484A0190 0x64314734 0xA3018604 0xC751E0FA [SIZE=0xE7600000] IMEI1 [OTP 0001]: 014140-00-260410-4 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5020T-2BWNCA1 USRDATA INFO: 0x4AF4C000 SIZE: 0x9C6B4000 Searching data; Locked to [SIM1]: 222-01 code_cat_n: 17487109 enabled: yes tries: 10 code_cat_ns: 03904898 enabled: no tries: 10 code_cat_sp: 02975048 enabled: no tries: 10 code_cat_c: 03042890 enabled: no tries: 10 code_cat_sim: 16549274 enabled: no tries: 10 code_cat_ns_sp: 19485467 enabled: no tries: 5 code_cat_sim_c: 06997581 enabled: no tries: 5 Code reading finished; Remove battery and cable; Time needed - 00:00:15 Log file saved to: LOG_16_10_2015_13_41_27.txt |
10-16-2015, 19:47 | #12727 (permalink) |
Freak Poster Join Date: Dec 2009 Location: JAM
Member: 1196714 Status: Offline Thanks Meter: 238 | SM-G900A Android Version: 5.0 Finished successfully. Chimera Mobile Phone Utility version: 8.04.1558 @ 2015-10-16 Printing phone history Unlock 10/16/2015 6:26:17 PM [Unlock phone started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G900A Android Version: 5.0 [LRX21T] Sales Code: ATT PDA Version: G900AUCU4BOF3 [june 2015, rev3] Phone Version: G900AUCU4BOF3 [june 2015, rev3] CSC Version: G900AATT4BOF3 [june 2015, rev3] Product Code: SM2G900AZKAATT HIDSw Version: G900AUCU4BOF3/G900AATT4BOF3/G900AUCU4BOF3/G900AUCU4BOF3 Board Platform: MSM8974 Modem Platform: MSM8974PRO Serial Number: R38G70BXJYV Imei: 35469106XXXXXXX Unique Number: C000020E8AF0652 Connections: AT,MTP Battery Status: 3.96V (62%) SIM Status: ABSENT Knox Version: v30 Warranty Bit: 0 Checking root state... Not rooted. There is no backup, because there is no root access. Unlocking... Trying on SAMSUNG Mobile USB Serial Port (COM49) Unlocked. Finished successfully. Finished at local time: [10.16.15 13:27:44] WorkID: XXXXXXX |
10-17-2015, 14:34 | #12728 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | alcatel 4013x unlock done Using library Brom_DLL_v7.1413.5 Searching phone; Phone detected (PreLoader USB VCOM Port) Preparing to start flash mode; Preparing to open COM9 Connecting; Downloading DA; Initializing; Rid: bc6ec41452faf5057eb30f47c9de4ed8 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (DA USB VCOM Port) TRYING TO OPEN COM40; DEVICE INFO: BB CHIP: MT6572_S00 [CA01, 00, 6572, FF] HW_STORAGE_EMMC: 0x46000115 0x43355835 0x589A0142 0x6B6277DA [SIZE=0xE9880000] IMEI1 [OTP 0001]: 356257-06-407942-5 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 4013X-2ATUAU1 USRDATA INFO: 0x6E380000 SIZE: 0x7B500000 Searching data; Locked to [SIM1]: 505-02 code_cat_n: 0989812406 enabled: yes tries: 99 code_cat_ns: 1071887708 enabled: no tries: 10 code_cat_sp: 2492276111 enabled: no tries: 10 code_cat_c: 1175511506 enabled: no tries: 10 code_cat_sim: 1241788539 enabled: no tries: 10 code_cat_ns_sp: 3758923133 enabled: no tries: 5 code_cat_sim_c: 3352020330 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:15 |
10-17-2015, 19:57 | #12729 (permalink) |
Member: 1196714 Status: Offline Thanks Meter: 238 | Z10 STL100-3 LTE Successfully unlocked. Chimera Mobile Phone Utility version: 8.04.1558 @ 2015-10-17 [Direct unlock started.] Phone is in loader mode Updating software. Phone is in loader mode Connected to loader Querying meminfo Downloading files Flashing file Parsing file Start flashing Flashing has been finished Reconnected Flashing file Parsing file Start flashing Flashing has been finished Waiting for the phone connection. Turn on your phone and wait for the Chimera logo. Phone found. Initializing usb connection. Testing usb connection. Usb successfully initialized. Waiting for the usb answer. Starting unlock ... Successfully unlocked. Finished at local time: [10.17.15 13:48:11] WorkID: XXXXXXX |
10-19-2015, 12:11 | #12731 (permalink) |
Freak Poster Join Date: May 2014 Location: baia mare romania Age: 40
Member: 2195859 Status: Offline Thanks Meter: 19 | gowell g328 succesfully unlocked thx to hack3r2k ! Software engine version: 1.0.0.9799 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Jul 21 2011 15:00:00 RELEASE DATE : Dec 8 2009 23:00:00 FIRMWARE INFO : GLO_CA_P622C4V1.0.0B11-S IMEI : 35947703000365-8 BLUETOOTH ADDR : C8 FE D4 ED 26 00 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 1 (MCC: 222 MNC: 1) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! |
10-19-2015, 14:39 | #12732 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Alcatel OneTouch Pixi 4027X Direct Unlock done.. Using library Brom_DLL_v7.1413.5 Searching phone; Phone detected (PreLoader USB VCOM Port (COM4)) Preparing to start flash mode; Preparing to open COM4 Connecting; Downloading DA; Initializing; Rid: c583f08ef1a6767c54c8af99950d969d Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (DA USB VCOM Port (COM5)) TRYING TO OPEN COM5; DEVICE INFO: BB CHIP: MT6572_S00 [CA01, 00, 6572, FF] HW_STORAGE_EMMC: 0x30000111 0x45473430 0x4ACF0130 0xE332778E [SIZE=0xEC480000] IMEI1 [OTP 0001]: 358144-06-070739-9 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 4027X-2AVRGB1-1 USRDATA INFO: 0x67F80000 SIZE: 0x84500000 Searching data; Locked to [SIM1]: 234-30 code_cat_n: 2084382560694803 enabled: no tries: 5 code_cat_ns: 3531314924761289 enabled: no tries: 10 code_cat_sp: 7512456493285611 enabled: yes tries: 7 code_cat_c: 0177651035875664 enabled: no tries: 10 code_cat_sim: 7689396592215254 enabled: no tries: 10 code_cat_ns_sp: 3901018658417890 enabled: no tries: 5 code_cat_sim_c: 6699085803051284 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:35 Log file saved to: LOG_19_10_2015_13_37_44.txt |
10-19-2015, 14:48 | #12733 (permalink) |
No Life Poster Join Date: May 2010 Location: kumasi-GHANA
Member: 1311694 Status: Offline Sonork: 100.1606976 Thanks Meter: 107 | huawei y530 great box 2015-10-19 14:43:58.546 Autodetect started! 2015-10-19 14:44:13.421 Found COM port :COM524 2015-10-19 14:44:13.421 Start read phone info! 2015-10-19 14:44:13.421 Open port COM524 (DBAdapter Reserved Interface (COM524))... 2015-10-19 14:44:13.546 Phone authorize start 2015-10-19 14:44:13.546 Connecting to server... 2015-10-19 14:44:17.625 Connected! 2015-10-19 14:44:17.640 Read data from server... 2015-10-19 14:44:20.234 Read data from server success! 2015-10-19 14:44:22.046 Phone authorize success! 2015-10-19 14:44:22.062 Read secure info... 2015-10-19 14:44:22.093 Read basic info... 2015-10-19 14:44:22.296 Detect phone done! Model: Y530_U00 IMEI: 864921020106268 Firmware ver.: MSM8x1xC900B512_AMSS Aug 7 201413:27:26 SN: C2Z7NB94B1119256 Custom SN: 022KRN7N4B074635 WiFi MAC: 84B:AC:E3:1A:89 BlueTooth MAC: 84B:AC:E3:32:C2 Vendor: orange Country: ch MSM8x1xC900B512_BOOT MSM8x1xC900B512_AMSS Aug 7 201413:27:26 Y530U00C00B012_EFS_RFNV_B01 HD1Y530M_VERA APPSBOOT Aug 11 201418:38:13 Y530-U00V100R001C900B512_KERNEL Y530-U00V100R001C900B512_SYSTEM Y530-U00V100R001C900B512_RECOVERY MSM8210 IMEI 1 Sim Lock status: NET: locked, unlock retry counts: 10 NETSUB: unlocked SP: unlocked Bootloader code: 2531631831291981 2015-10-19 14:44:32.843 Autodetect started! 2015-10-19 14:44:34.875 Found COM port :COM524 2015-10-19 14:44:34.890 Open port COM524 (DBAdapter Reserved Interface (COM524))... 2015-10-19 14:44:35.015 Connecting to server... 2015-10-19 14:44:38.765 Connected! 2015-10-19 14:44:38.781 Read data from server... 2015-10-19 14:44:41.046 Read data from server success! 2015-10-19 14:44:41.062 Phone authorize start 2015-10-19 14:44:41.078 Phone authorize success! 2015-10-19 14:44:41.093 Unlocking start 2015-10-19 14:44:41.093 Read basic info... 2015-10-19 14:44:41.125 Read basic info success! 2015-10-19 14:44:41.125 Read secure info... 2015-10-19 14:44:41.171 Read secure info success! 2015-10-19 14:44:41.203 Read data from server... 2015-10-19 14:44:46.765 Read data from server success! 2015-10-19 14:44:46.781 Writing security data... 2015-10-19 14:44:46.937 Write security data success! 2015-10-19 14:44:47.890 Unlock done! 2015-10-19 14:44:47.921 Job finished! SAFE N NO ROOT |
10-19-2015, 19:32 | #12734 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Macedonia
Member: 1671934 Status: Offline Thanks Meter: 247 | Huawei P8 unlock done Custom SN: S7M7N*********** WiFi MAC: 50:A7:2B:72:0C:FC BlueTooth MAC: **:**:**:**:**:** Vendor: dt Country: mk FASTBOOT:GRA-L09V100R001C150B134_FASTBOOT BOOT:GRA-V100R001C150B134_BOOT RECOVERYunknow) SYSTEM:GRA-L09V100R001C150B134_SYSTEM MAINVER:GRA-L09V100R001C150B134 DATAVERunknow) APTIME:Wed Jun 10 11:53:55 CST 2015 RAM: 3G eMMC: 16G IMEI 1 Sim Lock status: NET: locked, unlock retry counts: 10 NETSUB: unlocked SP: unlocked Bootloader code: 1991251814428102 Fastboot LockStatus: locked 2015-10-19 20:28:16.985 Open port COM7 (Android Adapter PCUI (COM7))... 2015-10-19 20:28:17.137 Connecting to server... 2015-10-19 20:28:18.110 Connected! 2015-10-19 20:28:18.113 Read data from server... 2015-10-19 20:28:19.561 Read data from server success! 2015-10-19 20:28:19.564 Unlocking start 2015-10-19 20:28:19.567 Read basic info... 2015-10-19 20:28:23.049 Read basic info success! 2015-10-19 20:28:23.052 Read secure info... 2015-10-19 20:28:25.623 Read secure info success! 2015-10-19 20:28:25.626 Phone secure identify start 2015-10-19 20:28:29.372 Phone secure identify success! 2015-10-19 20:28:30.942 Unlock done! 2015-10-19 20:28:30.945 Job finished! |
The Following User Says Thank You to unlock.mk For This Useful Post: |
10-20-2015, 13:31 | #12735 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Romania,Buc
Member: 694535 Status: Offline Thanks Meter: 70 | Orange Klif unlock OK Searching phone; Phone detected (@oem105.inf,%mtk_preloader%;PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Gadget VCOM Driver (COM202); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6572, E01 Sw version: MOLY.WR8.W1449.MD.WG.MP.V2.P5 Hw Version: JRDHZ72_W_FF_HSPA_HW Reading phone info; IMEI: 357628-06-081365-3 Reading simlock info; Locked to: 226-10 code_cat_n: 34820484 enabled: yes tries: 10 code_cat_ns: 29689464 enabled: no tries: 10 code_cat_sp: 30542033 enabled: no tries: 10 code_cat_c: 30463725 enabled: no tries: 10 code_cat_sim: 33064759 enabled: no tries: 10 code_cat_ns_sp: 53297761 enabled: no tries: 5 code_cat_sim_c: 86817778 enabled: no tries: 5 Time needed - 00:01:02 Log file saved to: LOG_20_10_2015_15_29_06.txt |
The Following User Says Thank You to IM8 For This Useful Post: |
