10-06-2009, 15:42 | #1306 (permalink) |
No Life Poster Join Date: Oct 2007 Location: india
Member: 618404 Status: Offline Thanks Meter: 311 | <<<<<<lg u310 successfully unlocked>>>>>>>>>> Searching phone ... MODEL : U310 COMPILED DATE : Oct 12 2006 14:55:00 RELEASE DATE : May 9 2006 17:00:00 FIRMWARE INFO : U310-MSM6250A-V10a-OCT-12-2006-H3G-IT IMEI : 352xxxxxxxxxxxxx-x BLUETOOTH ADDR : 90 54 14 A1 19 00 MEMORY ID : 0098:0076 MEMORY NAME : toshiba_ty90009800cogg MEMORY INFO : 0200:0020:0900 LOADING INIT DATA; RESETTING PHONE ! WAITING FOR PHONE TO POWER ON 30 SEC; PHONE ONLINE; SW VERSION: [OK] MODULE ERROR IMEI: [OK] 352xxxxxxxxxxx-x BLUETOOTH ADDR: [OK] 905414A11900 PLAYING MUSIC ... WAIT; DOING CONFIG; INJECTING VODKA; INJECTING JUICE; DRINKING; DANCING; STAT: ON NAND UNLOCK DONE; PROCESS STARTED; READING; ERASING; WRITING; READING; ERASING; WRITING; UNLOCKED ! Time needed - 00:01:16 |
10-06-2009, 16:12 | #1307 (permalink) |
No Life Poster Join Date: Jul 2007 Location: PK
Member: 539052 Status: Offline Sonork: 100.1585495 Thanks Meter: 119 | 8310 unlock........................... Searching for usb device ... Reading info ... IMEI: 356088022873074 Calculating ... MEP: MEP-04598-005 MEP2 CODE: 6394854034040167 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:11 Last edited by multicom_fsdpk; 10-06-2009 at 16:18. |
10-06-2009, 16:15 | #1308 (permalink) |
Member: 539052 Status: Offline Sonork: 100.1585495 Thanks Meter: 119 | 8820 unlock........... Searching for usb device ... Reading info ... IMEI: 353763012427759 Calculating ... MEP: MEP-16472-001 MEP2 CODE: 4156573833637024 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:23 |
10-07-2009, 04:28 | #1309 (permalink) |
Member: 539052 Status: Offline Sonork: 100.1585495 Thanks Meter: 119 | 8900 successful unlock... Searching for usb device ... Reading info ... IMEI: 355383037026649 Calculating ... MEP: MEP-16472-001 MEP2 CODE: 3079161011918326 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:01:11 |
10-07-2009, 05:45 | #1310 (permalink) |
Banned Join Date: Mar 2008
Member: 733071 Status: Offline Thanks Meter: 87 | cu920 unlock done MODEL : CU920 COMPILED DATE : Sep 26 2008 09:12:00 RELEASE DATE : Jul 31 2008 11:00:00 FIRMWARE INFO : CU920-MSM4090201D-V10p-SEP-26-2008-ATT-US IMEI : 01133300847191-6 BLUETOOTH ADDR : 40 CC 71 FB 21 00 MEMORY ID : 0098:00CA MEMORY NAME : toshiba_tya000bc00dogg MEMORY INFO : 0800:0040:0696 INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:06 |
10-07-2009, 16:50 | #1311 (permalink) |
Product Supporter Join Date: Sep 2004 Age: 39
Member: 81703 Status: Offline Thanks Meter: 1,332 | 8900 Movistar Searching for usb device ... Reading info ... IMEI: 351845033155493 Calculating ... MEP: MEP-06041-007 MEP2 CODE: 8693717350157046 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card |
10-07-2009, 17:22 | #1312 (permalink) |
Member: 539052 Status: Offline Sonork: 100.1585495 Thanks Meter: 119 | skype s2 unlock........... Software engine version: 1.0.0.2824 Searching phone ... MODEL : QCOM SERIES 2 COMPILED DATE : Apr 10 2009 19:16:00 RELEASE DATE : Jul 8 2008 05:00:00 FIRMWARE INFO : M6260A-KYRZ-2.5.1033_3A IMEI : 35422202233135-1 BLUETOOTH ADDR : 1E 5E 54 40 12 00 MEMORY ID : 00AD:0078 MEMORY NAME : hynix_h8acs0ej0mcp MEMORY INFO : 0200:0020:1599 INIT NAND ROUTINES; NAND INIT MADE; PROCESS STARTED; READING; ERASING; WRITING; RESET ! Time needed - 00:00:07 |
10-08-2009, 05:08 | #1313 (permalink) |
Cheater -Don't Deal with him- Join Date: May 2006 Age: 38
Member: 283204 Status: Offline Sonork: 100.1577140 Thanks Meter: 1,098 | <<<<succsessfully unlock 2 telstra zte t6 with furious-gold>>>> Here is log: Software engine version: 1.0.0.3071 Searching phone ... MODEL : QCOM SERIES 2 COMPILED DATE : Nov 3 2008 13:15:00 RELEASE DATE : Sep 24 2008 23:00:00 FIRMWARE INFO : TEL_AU_P622C3V1.0.3B01-S IMEI : 35535202020101-4 BLUETOOTH ADDR : FC 7C FB 73 1E 00 MEMORY ID : 00AD:0078 MEMORY NAME : hynix_hyg0sgh0mf3 MEMORY INFO : 0200:0020:133D INIT NAND ROUTINES; NAND INIT MADE; PROCESS STARTED; READING; ERASING; WRITING; UNLOCK CODE: 1399999913121219 ENTER USING: *983*865625# RESET ! Time needed - 00:00:08 Software engine version: 1.0.0.3071 Searching phone ... MODEL : QCOM SERIES 2 COMPILED DATE : Nov 3 2008 16:03:00 RELEASE DATE : Sep 24 2008 23:00:00 FIRMWARE INFO : TEL_AU_P622C3V1.0.3B01-S IMEI : 35535202101747-6 BLUETOOTH ADDR : 93 4D 82 93 22 00 MEMORY ID : 00AD:0078 MEMORY NAME : hynix_hyg0sgh0mf3 MEMORY INFO : 0200:0020:133D INIT NAND ROUTINES; NAND INIT MADE; PROCESS STARTED; READING; ERASING; WRITING; UNLOCK CODE: 9349498920235312 ENTER USING: *983*865625# RESET ! Time needed - 00:00:09 Br: Harkishan |
The Following 3 Users Say Thank You to Harkishan singh For This Useful Post: |
10-08-2009, 08:17 | #1316 (permalink) |
Banned Join Date: Nov 2007 Age: 36
Member: 631286 Status: Offline Thanks Meter: 1,250 | Software engine version: 1.0.0.3071 Searching phone ... MODEL : QCOM SERIES 6 COMPILED DATE : Dec 3 2005 16:34:00 RELEASE DATE : Sep 26 2001 01:30:00 FIRMWARE INFO : P600B2V4.0.0B11_SEC IMEI : 35753900179216-3 BLUETOOTH ADDR : 00 00 00 00 00 00 MEMORY ID : 00EC:0076 MEMORY NAME : samsung_kag00j007m MEMORY INFO : 0200:0020:0800 INIT NAND ROUTINES; NAND INIT MADE; READING; ERASING; WRITING; READING; ERASING; WRITING; UNLOCKED ! RESET ! Time needed - 00:00:08 |
10-08-2009, 12:01 | #1317 (permalink) |
Member: 283204 Status: Offline Sonork: 100.1577140 Thanks Meter: 1,098 | <<<<succsessfully unlock skype amoi wp-s1 with furious-gold>>>> Here is log: Software engine version: 1.0.0.3071 Searching phone ... MODEL : QCOM SERIES 2 COMPILED DATE : Mar 11 2008 15:57:00 RELEASE DATE : Aug 10 2007 08:00:00 FIRMWARE INFO : M6260A-KYRZ-2.1.3022 IMEI : 35776701702263-6 BLUETOOTH ADDR : 51 08 3C 40 12 00 MEMORY ID : 00AD:0036 MEMORY NAME : hynix_hycosehomf3p MEMORY INFO : 0200:0020:06BD INIT NAND ROUTINES; NAND INIT MADE; PROCESS STARTED; READING; ERASING; WRITING; RESET ! Time needed - 00:00:08 Br: Harkishan |
10-08-2009, 16:25 | #1318 (permalink) |
No Life Poster Join Date: Apr 2009 Location: lebanon Age: 37
Member: 1008455 Status: Offline Sonork: 0000 Thanks Meter: 99 | sucsesful Press power on button ... Phone detected ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Requesting baudrate change ... Baudrate changed ... Flash ID(0): 0001:227E:3C00 Searching flash image ... Reading flash image ... Unlock finished ! Done ! Time needed - 00:00:23 ------------------------------------------- Searching for usb device ... Reading info ... IMEI: 355085026137226 Calculating ... MEP: MEP-04598-005 MEP2 CODE: 9735130202440346 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:24 |
10-08-2009, 18:11 | #1319 (permalink) |
Member: 539052 Status: Offline Sonork: 100.1585495 Thanks Meter: 119 | Inq 3g successful unlock........... Software engine version: 1.0.0.3071 Searching phone ... MODEL : QCOM SERIES 2 COMPILED DATE : Mar 6 2009 16:47:00 RELEASE DATE : Nov 12 2008 22:00:00 FIRMWARE INFO : M6260A-KYRZ-2.5.1033_8A IMEI : 35454102128799-5 BLUETOOTH ADDR : AD 09 4E 40 12 00 MEMORY ID : 00AD:0078 MEMORY NAME : hynix_h8acs0ej0mcp MEMORY INFO : 0200:0020:1599 INIT NAND ROUTINES; NAND INIT MADE; PROCESS STARTED; READING; ERASING; WRITING; RESET ! Time needed - 00:00:08 |
10-08-2009, 21:08 | #1320 (permalink) |
No Life Poster Join Date: Jun 2007 Age: 37
Member: 520810 Status: Offline Thanks Meter: 231 | 8220 t mobile,. unlocked Searching for usb device ... Reading info ... IMEI: 3562000279XXXXX Calculating ... MEP: MEP-04104-007 MEP2 CODE: 2589601097235545 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:16 |
