07-24-2016, 15:03 | #13216 (permalink) |
Freak Poster Join Date: Jan 2012 Location: On Earth
Member: 1716439 Status: Offline Thanks Meter: 38 | FuriousGold Successfully Unlocked / Repaired / Flashed Phones !!! Support video and tutorial find youself at Software engine version: 1.0.0.10068 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Nov 21 2014 16:32:00 RELEASE DATE : Oct 25 2010 09:00:00 FIRMWARE INFO : LQBKI04.1.2_M034 IMEI : 35759305xxxxxx-9 BLUETOOTH ADDR : CE 46 82 xx xx xx DONE; PHONE CODE: 0000 READING DATA; CALCULATING; UNLOCK CODE: 7446702275 TO COMPLETE THE UNLOCK ENTER *#8611# AND ENTER THE UNLOCK CODE ABOVE. Last edited by .:hack3r2k:.; 07-25-2016 at 09:01. |
07-25-2016, 11:45 | #13217 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Now on earth Age: 48
Member: 75290 Status: Offline Thanks Meter: 57 | Successfully flashed OT-I213 ! Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (PreLoader USB VCOM Port (COM28)) Preparing to start flash mode; Preparing to open COM28 Connecting; Downloading DA; Initializing; Rid: 1b60e8827251222a865102021de76574 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (DA USB VCOM Port) TRYING TO OPEN COM37; DEVICE INFO: BB CHIP: MT8127_S00 [CA00, 00, 8127, FF] HW_STORAGE_EMMC: 0x34000115 0x33444D59 0x52220152 0x8B320DB6 [SIZE=0xE9880000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: I213-2BRGPL1 USRDATA INFO: 0x60F80000 SIZE: 0x66880000 Loading the file ... Cfg done ... Formatting file system now... Done; Downloading bootloader... Done; Downloading images... Done; Success; Time needed - 00:07:32 Log file saved to: LOG_25_07_2016_12_05_32.txt Thank you Daniel! Last edited by ersa; 07-25-2016 at 11:51. Reason: picture |
07-25-2016, 14:29 | #13218 (permalink) |
No Life Poster Join Date: Jan 2008 Location: PAKISTAN KARACHI Age: 44
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | 180 amazon mobiles unlock done Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500048732-7 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500164015-5 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500066903-1 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500158798-4 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500066680-5 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500065140-1 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500158823-0 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500160555-4 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500160731-1 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500162306-0 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500152080-3 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500159858-5 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500152175-1 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500150120-9 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500159880-9 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500159938-5 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500160758-4 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500160630-5 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500160708-9 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500164538-6 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500066887-6 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500160977-0 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500066890-0 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500066342-2 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500152030-8 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500070571-0 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500160656-0 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500068221-6 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500161831-8 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500159884-1 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500070369-9 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500064669-0 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500068292-7 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500162689-9 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500164563-4 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500068339-6 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500068230-7 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500068392-5 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500064772-2 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500068339-6 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500158776-0 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500186517-4 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jan 27 2015 10:11:00 RELEASE DATE : Jan 8 2015 00:00:00 FIRMWARE INFO : PB_02_06_12 IMEI : 01428500144680-7 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jan 27 2015 10:11:00 RELEASE DATE : Jan 8 2015 00:00:00 FIRMWARE INFO : PB_02_06_12 IMEI : 01408500394719-4 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500164534-5 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500158654-9 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500157638-3 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500162619-6 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500158693-7 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500158810-7 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500064949-6 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500150068-0 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500152057-1 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500153964-7 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500068614-2 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500065012-2 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500158207-6 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500162189-0 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500164061-9 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500164032-0 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500162581-8 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500162610-5 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500157664-9 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500157745-6 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500150018-5 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500159903-9 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500115247-4 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500165657-3 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500162663-4 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500154126-2 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500157792-8 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500151961-5 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500152153-8 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500150009-4 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500150005-2 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500152023-3 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500157710-0 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500151954-0 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500101914-5 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500160653-7 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500160697-4 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500158769-5 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500162685-7 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500160742-8 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500158699-4 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500164549-3 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500160612-3 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500160793-1 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500158610-1 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jan 27 2015 10:11:00 RELEASE DATE : Jan 8 2015 00:00:00 FIRMWARE INFO : PB_02_06_12 IMEI : 01408500431973-2 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jan 27 2015 10:11:00 RELEASE DATE : Jan 8 2015 00:00:00 FIRMWARE INFO : PB_02_06_12 IMEI : 01428500121813-1 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jan 27 2015 10:11:00 RELEASE DATE : Jan 8 2015 00:00:00 FIRMWARE INFO : PB_02_06_12 IMEI : 01408500089421-7 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500164508-9 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500164492-6 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500157639-1 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500149959-4 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500071050-4 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500066918-9 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500157799-3 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Aug 14 2014 09:30:00 RELEASE DATE : Aug 13 2014 23:00:00 FIRMWARE INFO : PB_02_06_05 IMEI : 01428500047935-3 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500149969-3 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500154135-3 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500061968-9 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500163975-1 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500068848-6 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500157593-0 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500070864-9 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500152039-9 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500152135-5 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500152021-7 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500157659-9 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500157574-0 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500160630-5 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500152060-5 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500064462-0 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500067024-5 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500160758-4 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jan 27 2015 10:11:00 RELEASE DATE : Jan 8 2015 00:00:00 FIRMWARE INFO : PB_02_06_12 IMEI : 01408500441746-0 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500160538-0 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500050226-5 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500117637-4 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500091252-2 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500048018-1 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500089534-7 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500089574-3 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500093140-7 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500050207-5 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500053841-8 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500050189-5 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500088592-6 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500054058-8 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500054360-8 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jan 27 2015 10:11:00 RELEASE DATE : Jan 8 2015 00:00:00 FIRMWARE INFO : PB_02_06_12 IMEI : 01408500157632-6 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500089115-5 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500052082-0 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500098919-9 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500053540-6 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500090557-5 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500048815-0 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500070582-7 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500066883-5 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500050719-9 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500117245-6 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500113537-0 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500050733-0 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500050163-0 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500094993-8 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500092902-1 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500058450-3 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500117301-7 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500117061-7 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500113469-6 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500050439-4 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Software engine version: 1.0.0.9701 Searching phone ... MODEL : QCOM SERIES 47 COMPILED DATE : Jun 3 2014 20:24:00 RELEASE DATE : Apr 17 2014 15:00:00 FIRMWARE INFO : PB_02_05_17 IMEI : 01408500090314-1 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LO |
07-25-2016, 14:56 | #13219 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Amoi MD1 unlock done Software engine version: 1.0.0.9994 Searching phone ... MODEL : QCOM SERIES 1 COMPILED DATE : Oct 16 2006 10:23:00 RELEASE DATE : Aug 3 2006 00:00:00 FIRMWARE INFO : M6250D-VMSY-6.2.9343T IMEI : 35209101527787-7 BLUETOOTH ADDR : A9 9C 14 40 12 00 MEMORY ID : 00EC:0036 MEMORY NAME : samsung_k9f1208 MEMORY INFO : 0200:0020:08C0 INIT NAND ROUTINES; NAND INIT MADE; PROCESS STARTED; READING; ERASING; WRITING; RESET ! Log file saved to: LOG_25_07_2016_13_40_52.txt Time needed - 00:00:36 |
07-26-2016, 01:12 | #13220 (permalink) |
No Life Poster Join Date: Oct 2008 Location: PAKISTAN
Member: 882981 Status: Offline Sonork: 161363 Thanks Meter: 306 | Huawei p9 vns-l21 imei repair successfull worldfirst HUAWEI P9 VNS-L21 IMEI REPAIR SUCCESSFULL WORLD FIRST 7/26/2016 2:57:31 AM FlyCaptain Huawei Module v2.0.0.0092 Furious Gold Pack 7 Dongle S/N: 8DA41CF6 Before detection connect cable to usb and enable Manufacture mode ! Qualcomm and HiSilicon: *#*#2846579#*#* MTK: *#*#14789632#*#* Windows: ##2846579# ProjectMenu 1.Background setting 2.USB ports setting Select Manufacture mode (for MTK other/debug mode) 2016-07-26 02:59:59.346 Autodetect started! 2016-07-26 02:59:59.946 Found COM port: COM31 2016-07-26 03:00:00.966 Start read phone info! 2016-07-26 03:00:00.976 Open port COM31 (Android Adapter PCUI (COM31))... 2016-07-26 03:00:04.496 Phone authorize start 2016-07-26 03:00:04.576 Connecting to server... 2016-07-26 03:00:06.386 Connected! 2016-07-26 03:00:06.396 Read data from server... 2016-07-26 03:00:08.546 Read data from server success! 2016-07-26 03:00:11.256 Phone authorize success! 2016-07-26 03:00:11.266 Read basic info... 2016-07-26 03:00:12.506 Read secure info... 2016-07-26 03:00:15.776 Detect phone done! Model: VNS-L21 IMEI: 869XXXXXXXXXXXX SUB_IMEI: 869XXXXXXXXX IMEISV: 20 Firmware ver.: VNS-C900B120 SN: 023SNC1661002795 Custom SN: BUC0216530000675 WiFi MAC: FC:3F:7C:85:AC:23 BlueTooth MAC: FC:3F:7C:85:A2:C2 Vendor: hw Country: meafnaf FASTBOOTallas-Trunk_FASTBOOT BOOTallas-Trunk_BOOT RECOVERYunknow) SYSTEM:VNS-L21C900B120_SYSTEM MAINVER:VNS-C900B120 DATAVER:VNS-C900B120_DATA_hw_meafnaf APTIME:Tue May 24 04:11:12 CST 2016 RAM: 2G eMMC: 16G IMEI 1 Sim Lock status: NET: unlocked NETSUB: unlocked SP: unlocked 2016-07-26 03:00:44.576 Autodetect started! 2016-07-26 03:00:47.186 Found COM port: COM31 Fixed IMEI 1 CRC: 869XXXXXXXXX Fixed IMEI 2 CRC: 869XXXXXXXXX 2016-07-26 03:00:47.246 Open port COM31 (Android Adapter PCUI (COM31))... 2016-07-26 03:00:47.376 Connecting to server... 2016-07-26 03:00:48.956 Connected! 2016-07-26 03:00:48.976 Read data from server... 2016-07-26 03:00:51.186 Read data from server success! 2016-07-26 03:00:52.336 Repairing start New IMEI 1 : 8698xxxxxxxxxx New IMEI 2 : 86989xxxxxxxxxx 2016-07-26 03:00:52.376 Phone authorize start 2016-07-26 03:00:55.286 Phone authorize success! 2016-07-26 03:00:58.446 Read basic info... 2016-07-26 03:01:02.176 Read secure info... 2016-07-26 03:01:02.186 Repair IMEI 1 start! 2016-07-26 03:01:02.206 Phone secure identify start 2016-07-26 03:01:05.026 Phone secure identify success! 2016-07-26 03:01:05.046 Reading data from server... 2016-07-26 03:01:06.576 Reading data from server success! 2016-07-26 03:01:07.816 Repair IMEI 1 Success! 2016-07-26 03:01:07.826 Repair IMEI 2 start! 2016-07-26 03:01:07.846 Phone secure identify start 2016-07-26 03:01:12.156 Phone secure identify success! 2016-07-26 03:01:12.176 Reading data from server... 2016-07-26 03:01:13.656 Reading data from server success! 2016-07-26 03:01:14.806 Repair IMEI 2 Success! 2016-07-26 03:01:14.826 Finished! |
The Following 2 Users Say Thank You to faisal jee For This Useful Post: |
07-26-2016, 11:05 | #13221 (permalink) |
Freak Poster Join Date: Dec 2006
Member: 415773 Status: Offline Thanks Meter: 14 | Succesfull unlocked VDF895N !! thanks to Mrs. Daniel !! Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@usb.inf,%usb\composite.devicedesc%;Dispositivo composto USB) Preparing to enter download mode; Preparing to open COM57 Connecting; Init; Port opened; Phone detected (@oem94.inf,%qcomdevice90080%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM96 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22D4 IMEI: ************** PTH: 09 PTS: W5B PROV_ID: V895N-2GVDPT1 SBTADDR: 3C:CB:7C:F6:10:39 SWIFIADDR: 3C:CB:7C:F6:10:3A HS_PN: SAA6197AAS0C SSN: 3PKC33CBKHY03JA Work id: 09B6B3CD Setup 1; Done; Setup 2; Done; Setup 3; Done; Uploading; Done; SECURITY: X9W5FFB0BG00 Size: 00000430 Backup saved to: *************** Checking the simlock; Magic ok; Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_26_07_2016_11_00_14.txt Time needed - 00:00:34 |
07-26-2016, 13:27 | #13222 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | tablette alcatel 9002x lock by tigo done 9002x unlock done Searching phone; Phone detected (@oem375.inf,%mtk_preloader%;PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on MediaTek USB VCOM (Android) (COM67); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6582, E01 Sw version: MOLY.WR8.W1315.MD.WG.MP.V39.F1.P7 Hw Version: TCL82_TB_KK_HSPA_HW Reading phone info; IMEI: 358091-06-049318-3 Reading simlock info; Locked to: 608-02 code_cat_n: 79953588 enabled: yes tries: 10 code_cat_ns: 94832752 enabled: no tries: 10 code_cat_sp: 00424528 enabled: no tries: 10 code_cat_c: 63342097 enabled: no tries: 10 code_cat_sim: 25381545 enabled: no tries: 10 code_cat_ns_sp: 53297761 enabled: no tries: 5 code_cat_sim_c: 86817778 enabled: no tries: 5 Unlocking SIM2 too. Time needed - 00:01:03 Log file saved to: LOG_26_07_2016_12_46_13.txt |
07-27-2016, 04:07 | #13223 (permalink) |
Freak Poster Join Date: Jun 2014
Member: 2207443 Status: Offline Thanks Meter: 22 | success unlock v695 vofafone Using library Brom_DLL_v7.1413.5 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM7)) Preparing to start flash mode; Preparing to open COM7 Connecting; Downloading DA; Initializing; Rid: 4514b2ac2dc7991e6e2fdf98b0efe567 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM10; DEVICE INFO: BB CHIP: MT6572_S00 [CA01, 00, 6572, FF] HW_STORAGE_EMMC: 0x504E01FE 0x34394A31 0x1D11124D 0x73425A49 [SIZE=0xE9B00000] IMEI1 [OTP 0001]: 357773-06-530219-3 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: V695-2BVDAU1 USRDATA INFO: 0x61B80000 SIZE: 0x87F80000 Searching data; Locked to [SIM1]: 505-03 code_cat_n: 38663455 enabled: yes tries: 90 code_cat_ns: 28888036 enabled: no tries: 10 code_cat_sp: 32381190 enabled: no tries: 10 code_cat_c: 00577923 enabled: no tries: 10 code_cat_sim: 34969852 enabled: no tries: 10 code_cat_ns_sp: 53297761 enabled: no tries: 5 code_cat_sim_c: 86817778 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:14 |
07-28-2016, 10:53 | #13224 (permalink) |
Freak Poster Join Date: Nov 2001 Location: Portugal Age: 43
Member: 7557 Status: Offline Thanks Meter: 26 | Meo Smart A25 Unlock 1º in the world i think :) Searching phone; Phone detected (@oem132.inf,%vcom_preloader%;MediaTek PreLoader USB VCOM (Android)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on USB VCOM (Android) (COM11); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6572, E01 Sw version: MOLY.WR8.W1315.MD.WG.MP.V43.P12 Hw Version: SAGETEL72_CWET_KK_HSPA_HW Reading phone info; IMEI: 351780-08-002290-0 Reading simlock info; Locked to: C1C-1C code_cat_n: 12345678 enabled: no tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Time needed - 00:01:04 Log file saved to: LOG_28_07_2016_10_46_22.txt |
The Following User Says Thank You to theboy For This Useful Post: |
07-28-2016, 16:00 | #13225 (permalink) |
No Life Poster Join Date: Apr 2010 Location: pakistan Age: 48
Member: 1275418 Status: Offline Thanks Meter: 432 | success unlock v695 vofafone Using library Brom_DLL_v7.1413.5 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM Port (COM7)) Preparing to start flash mode; Preparing to open COM7 Connecting; Downloading DA; Initializing; Rid: 6e2cbc9d97a3364a199ea1b9b2586e38 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (MediaTek DA USB VCOM Port) TRYING TO OPEN COM16; DEVICE INFO: BB CHIP: MT6572_S00 [CA01, 00, 6572, FF] HW_STORAGE_EMMC: 0x46000115 0x4135324A 0x680F0242 0x9733739B [SIZE=0xE9880000] IMEI1 [OTP 0001]: 357774-06-299391-9 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: V695-2AVDGB2 USRDATA INFO: 0x61B80000 SIZE: 0x87D00000 Searching data; Locked to [SIM1]: 234-15 code_cat_n: 12007048 enabled: yes tries: 10 code_cat_ns: 09549982 enabled: no tries: 10 code_cat_sp: 10413616 enabled: no tries: 10 code_cat_c: 10324168 enabled: no tries: 10 code_cat_sim: 12927823 enabled: no tries: 10 code_cat_ns_sp: 53297761 enabled: no tries: 5 code_cat_sim_c: 86817778 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:15 Log file saved to: LOG_28_07_2016_05_06_11.txt |
07-29-2016, 14:52 | #13226 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Romania,Sinaia
Member: 637351 Status: Offline Thanks Meter: 167 | vodafone smart prime 6 unlocked Code: Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (USB Composite Device) Preparing to enter download mode; Preparing to open COM165 Connecting; Init; Port opened; Phone detected (Android HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM76 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22D4 IMEI: 356907068xxxxx-x PTH: 15 PTS: W7N PROV_ID: V895N-2HVDRO1 SBTADDR: 18:E3:BC:72:1C:99 SWIFIADDR: 18:E3:BC:72:1C:9A HS_PN: SAA6197AAC0C SSN: 3PKC35CBSPY0363 Work id: 16B1C99C Setup 1; Done; Setup 2; Done; Uploading; Done; SECURITY: X9W7FLN0BG00 Size: 00000430 Backup saved to: 35690706845594-4 Checking the simlock; Magic ok; Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_29_07_2016_16_28_14.txt Time needed - 00:00:30 |
07-29-2016, 19:45 | #13227 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Wiko Lenny 2 Unlocked Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (PreLoader USB VCOM Port (COM92)) Preparing to start flash mode; Preparing to open COM92 Connecting; Downloading DA; Initializing; Rid: 94fed84e1f8b7fee95d415531ed46c82 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem118.inf,%mtk_sp_da%;DA USB VCOM Port) TRYING TO OPEN COM98; DEVICE INFO: BB CHIP: MT6580_S00 [CA00, 00, 6580, FF] HW_STORAGE_EMMC: 0x46000115 0x4D37324A 0x6FBD0242 0x83133ED2 [SIZE=0xE9880000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x59800000 SIZE: 0x90080000 Searching data; Locked to [SIM1]: 228-02 code_cat_n: 87654321 enabled: yes tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Locked to [SIM2]: 228-02 code_cat_n: 87654321 enabled: yes tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:49 Log file saved to: LOG_29_07_2016_18_38_49.txt |
07-29-2016, 19:58 | #13228 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Alcatel 5020T unlock code readed Using library Brom_DLL_v7.1413.5 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (USB Modem Driver (COM97)) Preparing to start flash mode; Preparing to open COM97 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 6018dd2f8697736e6fa39f1b96e326f2 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem118.inf,%mtk_sp_da%;DA USB VCOM Port) TRYING TO OPEN COM98; DEVICE INFO: BB CHIP: MT6575_S01 [CB00, E201, 6575, 05] HW_STORAGE_EMMC: 0x504E01FE 0x58585830 0xA5D51058 0xB790CAC7 [SIZE=0xE9300000] IMEI1 [OTP 0001]: 013778-00-42AAAA-5 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5020T-2ATBUS1 USRDATA INFO: 0x4AF4C000 SIZE: 0x9E3B4000 Searching data; Locked to [SIM1]: 310-16 code_cat_n: 24507639 enabled: yes tries: 3 code_cat_ns: 40499162 enabled: no tries: 10 code_cat_sp: 27395771 enabled: no tries: 10 code_cat_c: 06306401 enabled: no tries: 10 code_cat_sim: 09251548 enabled: no tries: 10 code_cat_ns_sp: 21488975 enabled: no tries: 5 code_cat_sim_c: 37164532 enabled: no tries: 5 Code reading finished; Remove battery and cable; Time needed - 00:00:09 Log file saved to: LOG_29_07_2016_18_42_12.txt |
07-29-2016, 22:49 | #13229 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | ALCATEL SONIC A851L UNLOCK DONE Software engine version: 1.0.0.9994 Searching phone ... MODEL : QCOM SERIES 37 COMPILED DATE : Jan 6 2014 15:08:00 RELEASE DATE : Oct 10 2013 03:00:00 FIRMWARE INFO : M8930B-AAAATAZM-3.2.25066 IMEI : 01363900105088-9 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; WORKING; SAVED: A1BB7DB026BC97A954AAF6538C6E1820.bin UNLOCK CODE: N/A DONE; SIM_LOCK REMOVED ! RESET ! Log file saved to: LOG_29_07_2016_17_48_24.txt Time needed - 00:00:54 |
07-30-2016, 12:29 | #13230 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Professional Mobile Unlocker Age: 41
Member: 617174 Status: Offline Sonork: 100.1622609 Thanks Meter: 579 | vodafone smart ultra 6 Unlock Done Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@usb.inf,%usb\composite.devicedesc%;USB Composite Device) Preparing to enter download mode; Preparing to open COM329 Connecting; Init; Port opened; Phone detected (@oem232.inf,%qcomdevice90080%;ALCATEL HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM155 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22D4 IMEI: 35690706889506-5 PTH: 15 PTS: W7N PROV_ID: V895N-2HVDGB2 SBTADDR: 18:E3:BC:AA:0F:98 SWIFIADDR: 18:E3:BC:AA:0F:99 HS_PN: SAA6197AAC0C SSN: 3PKC35CBJEZ01V2 Work id: 1482A96E Setup 1; Done; Setup 2; Done; Uploading; Done; SECURITY: X9W7FCN0BG00 Size: 00000430 Backup saved to: 35690706889506-5 Checking the simlock; Magic ok; Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_30_07_2016_17_23_26.txt Time needed - 00:00:25 |
