08-06-2016, 17:02 | #13246 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | Software engine version: 1.0.0.10264 Searching phone ... MODEL : QCOM SERIES 37 COMPILED DATE : Jan 6 2014 15:08:00 RELEASE DATE : Oct 10 2013 03:00:00 FIRMWARE INFO : M8930B-AAAATAZM-3.2.25066 IMEI : 01363900140212-2 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; WORKING; SAVED: 110665A244806AADAA660025733B7598.bin UNLOCK CODE: N/A DONE; RESET ! Log file saved to: LOG_6_08_2016_17_57_35.txt Time needed - 00:00:37 |
08-08-2016, 04:12 | #13248 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Into the Unknown
Member: 121461 Status: Offline Thanks Meter: 49 | Unlock pop2 4 40450 successfully For those who dont know i unlocked a pop2 4 model 40450 successfully using my furious Gold Pack 5 and selected model 4045L: Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@usb.inf,%usb\composite.devicedesc%;USB Composite Device) Preparing to enter download mode; Preparing to open COM24 Connecting; Init; Port opened; Phone detected (@oem180.inf,%qcomserialportdesc90080%;Android HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM27 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22D4 IMEI: 865948020****** PTH: 03 PTS: LHL PROV_ID: 4045O-2AC9CP1 SBTADDR: 948:59:BB:E5:62 SWIFIADDR: 948:59:BB:E5:63 HS_PN: SAA1B16AAA0C SSN: QUKC04BN7KY00FF Work id: 09B47FB4 Setup 1; Done; Setup 2; Done; Setup 3; Done; Uploading; Done; SECURITY: X5LHLDL1BG00 Size: 00000430 Backup saved to: 865948020***** Backup file(s) removed; Checking the simlock; Magic ok; Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_7_08_2016_23_06_43.txt Time needed - 00:00:38 |
The Following User Says Thank You to Linkz For This Useful Post: |
08-08-2016, 09:20 | #13249 (permalink) |
No Life Poster Join Date: Oct 2007 Location: india
Member: 618404 Status: Offline Thanks Meter: 311 | y221-u53 unlocking done by selecting y220 pack6 Using library Brom_DLL_v7.1413.5 Connecting; Be sure you unlock the phone screen; BRAND: HUAWEI MODEL: HUAWEI Y221-U53 ANDROID: v4.4.2 CPU: MT6572 IMEI: Trying to get root access; Done; Reading simlock data; Done; Locked to [SIM1]: FFF-FF code_cat_n: 12345678 enabled: no tries: 255 code_cat_ns: 16716014 enabled: yes tries: 255 code_cat_sp: 11112222 enabled: no tries: 255 code_cat_c: 33334444 enabled: no tries: 255 code_cat_sim: 55556666 enabled: no tries: 255 code_cat_ns_sp: 77778888 enabled: no tries: 255 code_cat_sim_c: 99990000 enabled: no tries: 255 Time needed - 00:00:13 |
08-08-2016, 22:54 | #13250 (permalink) |
No Life Poster Join Date: Nov 2006
Member: 384641 Status: Offline Thanks Meter: 31 | Unlock Alcatel Idol 3 OT 6045O Software engine version: 1.0.0.10264 Searching phone ... MODEL : QCOM SERIES 46 COMPILED DATE : Oct 28 2015 16:23:00 RELEASE DATE : Aug 31 2015 03:00:00 FIRMWARE INFO : MPSS.DPM.2.0.2.c1.6-00022-M8936FAAAANUZM-1.26298.1.28320.1 IMEI : XXXXXX00X00XXX-0 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; WORKING; SAVED: 0846982646F60DB038A879936E45FBFD.bin UNLOCK CODE: N/A DONE; DOING EXTRA CALCULATION; AFTER UNLOCK YOU MUST RESTART THE PHONE MANUALLY; SIM_LOCK REMOVED ! RESET ! |
The Following User Says Thank You to siscel For This Useful Post: |
08-09-2016, 09:52 | #13251 (permalink) |
Freak Poster Join Date: Mar 2006 Location: kenya karatina
Member: 251792 Status: Offline Thanks Meter: 21 | SPD SERVICE TOOL - Update 1.0.0.2045 unlocke itel 2180 orange kenya using this ITEL_2180_EN_FR_ARB_HAUSA_SWAHILI_ORANGE_KENYA-2PATCHED.spd |
The Following User Says Thank You to paulkk For This Useful Post: |
08-09-2016, 18:33 | #13252 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | HUAWEY G620 A2 UNLOCK DONE ProjectMenu 1.Background setting 2.USB ports setting Select Manufacture mode (for MTK other/debug mode) 2016-08-09 13:30:23.049 Autodetect started! 2016-08-09 13:30:24.892 Found COM port: COM284 2016-08-09 13:30:25.959 Start read phone info! 2016-08-09 13:30:25.961 Open port COM284 (DBAdapter Reserved Interface (COM284))... 2016-08-09 13:30:26.067 Phone authorize start 2016-08-09 13:30:26.072 Connecting to server... 2016-08-09 13:30:27.023 Connected! 2016-08-09 13:30:27.025 Read data from server... 2016-08-09 13:30:28.800 Read data from server success! 2016-08-09 13:30:30.566 Phone authorize success! 2016-08-09 13:30:30.568 Read secure info... 2016-08-09 13:30:30.686 Read basic info... 2016-08-09 13:30:30.710 Detect phone done! Model: HUAWEIH891L IMEI: 866164021264525 Firmware ver.: MSM8226C421B166_AMSS May 29 201519:34:06 SN: 7MY7N15806007324 Custom SN: 7N3DGY158A019951 WiFi MAC: 04:02:1F:8B:9D:1F BlueTooth MAC: 04:02:1F:8B:AD:88 Vendor: consumercellular Country: us SL: 00000000 MSM8226C421B166_BOOT MSM8226C421B166_AMSS May 29 201519:34:06 G620-A2-C00B004_EFS_RFNV_A01 HL1H891LM G620-A2V100R001C421B166_APPSBOOT G620-A2V100R001C421B166_KERNEL G620-A2V100R001C421B166_SYSTEM G620-A2V100R001C421B166_RECOVERY MSM8926 IMEI 1 Sim Lock status: NET: unlocked NETSUB: unlocked SP: locked, unlock retry counts: 10 2016-08-09 13:30:51.284 Autodetect started! 2016-08-09 13:30:52.996 Found COM port: COM284 2016-08-09 13:30:53.001 Open port COM284 (DBAdapter Reserved Interface (COM284))... 2016-08-09 13:30:53.102 Connecting to server... 2016-08-09 13:30:54.575 Connected! 2016-08-09 13:30:54.579 Read data from server... 2016-08-09 13:30:56.587 Read data from server success! 2016-08-09 13:30:56.741 Phone authorize start 2016-08-09 13:30:56.748 Phone authorize success! 2016-08-09 13:30:56.751 Read secure info... 2016-08-09 13:30:56.869 Read secure info success! 2016-08-09 13:30:56.872 Read basic info... 2016-08-09 13:30:56.895 Read basic info success! 2016-08-09 13:30:56.899 Unlocking start 2016-08-09 13:30:58.163 Read data from server... 2016-08-09 13:30:59.976 Read data from server success! 2016-08-09 13:30:59.979 Writing security data... 2016-08-09 13:31:00.185 Write security data success! 2016-08-09 13:31:00.591 Unlock done! 2016-08-09 13:31:00.598 Job finished! |
08-10-2016, 12:28 | #13253 (permalink) | ||||||
Banned Join Date: Nov 2010 Location: :::LONDON:::
Member: 1442994 Status: Offline Thanks Meter: 899 | Pop3 5.5 unlocked in few seconds Quote:
The Following User Says Thank You to AbDuLlAH kHaWaR For This Useful Post: |
08-12-2016, 13:54 | #13254 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Moldova
Member: 614304 Status: Offline Thanks Meter: 150 | Micromax BOLT D303 Unlock Done !!! PACK6 MTK READER ! Searching phone; Phone detected (MediaTek PreLoader USB VCOM (Android)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Mobistel Cynus T1-CDC Serial (COM215); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6572, E01 Sw version: MOLY.WR8.W1315.MD.WG.MP.V36.P4 Hw Version: TINNO72_WE_72_KK_HSPA_HW Reading phone info; IMEI: 911467-4*******3-3 Reading simlock info; Locked to: 250-02 code_cat_n: 86095550 enabled: yes tries: 255 code_cat_ns: 56781234 enabled: no tries: 255 code_cat_sp: 11112222 enabled: no tries: 255 code_cat_c: 33334444 enabled: no tries: 255 code_cat_sim: 55556666 enabled: no tries: 255 code_cat_ns_sp: 77778888 enabled: no tries: 255 code_cat_sim_c: 99990000 enabled: no tries: 255 Unlocking SIM2 too. Time needed - 00:01:02 Log file saved to: LOG_12_08_2016_15_48_42.txt |
08-12-2016, 16:21 | #13255 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Africa.uganda
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 247 | Fero f180 unlocked Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (@oem146.inf,%usbcomm_dl%;SPRD U2S Diag) Preparing to sync; Port opened [COM26]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT Chip type: 6531 FdlStat: 0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00C8:0060:0016 - SIZE : 00400000 Reading phone info; PHONE INFO: NONE BT ADDR: 72:38:6E:00:16:20 SW IMEI[0]: 359431-07-128030-3 SW IMEI[1]: 359431-07-128031-1 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: ON FIXED NV BASE: 30398000 Uncompressing; Done; Re-programming; FLS programmed; Done; Remove battery and cable; Log file saved to: LOG_12_08_2016_18_19_03.txt Time needed - 00:01:49 |
The Following User Says Thank You to ibrajinja For This Useful Post: |
08-16-2016, 11:33 | #13256 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Professional Mobile Unlocker Age: 41
Member: 617174 Status: Offline Sonork: 100.1622609 Thanks Meter: 579 | Vodafone 785 Flash Done pack 6 Using library Brom_DLL_v7.1413.5 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (PreLoader USB VCOM Port (COM45)) Preparing to start flash mode; Preparing to open COM45 Connecting; Downloading DA; Initializing; Rid: 75476160056016cbdaf5d0879d2b74ca Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem83.inf,%mtk_sp_da%;DA USB VCOM Port) TRYING TO OPEN COM58; DEVICE INFO: BB CHIP: MT6572_S00 [CA01, 00, 6572, FF] HW_STORAGE_EMMC: 0x30000111 0x39473430 0x9ED61030 0xFD711168 [SIZE=0xEC480000] IMEI1 [OTP 0001]: 355250-06-557901-5 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: V785-2BVDGB1 USRDATA INFO: 0x61B80000 SIZE: 0x8A900000 Loading the file ... Cfg done ... Formatting file system now... Done; Downloading bootloader... Done; Downloading images... Done; Success; Time needed - 00:02:48 |
08-16-2016, 13:40 | #13257 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Huawei Y6 SCL-L01 Direct Unlock done.. 8/16/2016 12:01:41 PM FlyCaptain Huawei Module v2.0.0.0095 Furious Gold Pack 7 2016-08-16 12:01:57.322 Autodetect started! 2016-08-16 12:01:59.137 Found COM port: COM196 2016-08-16 12:02:00.338 Start read phone info! 2016-08-16 12:02:00.354 Open port COM196 (DBAdapter Reserved Interface (COM196))... 2016-08-16 12:02:00.463 Phone authorize start 2016-08-16 12:02:00.478 Connecting to server... 2016-08-16 12:02:02.116 Connected! 2016-08-16 12:02:02.132 Read data from server... 2016-08-16 12:02:04.103 Read data from server success! 2016-08-16 12:02:06.162 Phone authorize success! 2016-08-16 12:02:06.178 Read secure info... 2016-08-16 12:02:06.302 Read basic info... 2016-08-16 12:02:06.349 Detect phone done! Model: HUAWEISCL-L01 IMEI: 867538027229559 SUB_IMEI: 8675380272AAAAA Firmware ver.: MSM8909C900B140_AMSS Oct 6 201518:13:39 SN: NQL7N1612700AAAA Custom SN: 7N3FSE161W041086 WiFi MAC: 1C:67:58:39:5F:FA BlueTooth MAC: 1C:67:58:39:67:F3 Vendor: swisscom Country: ch SL: 00000000 SCL-L01C293B130_BOOT MSM8909C900B140_AMSS Oct 6 201518:13:39 SCL-L01_C00B007_EFS_RFNV_B05 HL3SCALEM SCL-L01C293B130_APPSBOOT SCL-L01C293B130_KERNEL SCL-L01C293B130_SYSTEM SCL-L01C293B130_RECOVERY MSM8909 HUAWEI SCL-L01 C293 D001 IMEI 1 Sim Lock status: NET: unknown NETSUB: unknown SP: unknown 2016-08-16 12:02:11.809 Autodetect started! 2016-08-16 12:02:13.572 Found COM port: COM196 2016-08-16 12:02:13.588 Open port COM196 (DBAdapter Reserved Interface (COM196))... 2016-08-16 12:02:13.744 Connecting to server... 2016-08-16 12:02:15.314 Connected! 2016-08-16 12:02:15.329 Read data from server... 2016-08-16 12:02:17.232 Read data from server success! 2016-08-16 12:02:17.499 Phone authorize start 2016-08-16 12:02:17.514 Phone authorize success! 2016-08-16 12:02:17.530 Read secure info... 2016-08-16 12:02:17.701 Read secure info success! 2016-08-16 12:02:17.717 Read basic info... 2016-08-16 12:02:17.748 Read basic info success! 2016-08-16 12:02:17.764 Unlocking start 2016-08-16 12:02:17.811 Reading secure data from server... 2016-08-16 12:02:20.041 Reading secure data from server success! 2016-08-16 12:02:20.166 Unlock done! 2016-08-16 12:02:20.213 Job finished! |
08-16-2016, 14:56 | #13258 (permalink) |
Freak Poster Join Date: Sep 2015
Member: 2453225 Status: Offline Sonork: l Thanks Meter: 31 | alcatel pop s9 7050y unlock Software engine version: 1.0.0.10264 Searching phone ... MODEL: QCOM SERIES 41 COMPILED DATE: Sep 17 2014 18:30:00 RELEASE DATE: May 22 2014 23:00:00 FIRMWARE INFO: MPSS. DI. 2.0 c 11.1-00012-M8926DAAAANAZM-1 IMEI: 86440902016288-7 BLUETOOTH ADDR: 000 000 000 000 000 000 DONE; WORKING; Saved: URB7D77AF9672C8A303C82B686C8837428.bin UNLOCK CODE: N/A DONE; DOING EXTRA CALCULATION; AFTER UNLOCK YOU MUST RESTART THE PHONE MANUALLY; SIM_LOCK REMOVED! RESET! |
08-16-2016, 16:43 | #13259 (permalink) |
Freak Poster Join Date: Sep 2007 Location: Corral de Bustos, Argentina
Member: 578880 Status: Offline Thanks Meter: 144 | HUAWEI SCL-L03 (Personal Argentina) Unlock Done Model: HUAWEISCL-L03 IMEI: 8675390XXXXXXXX SUB_IMEI: 8675390XXXXXXXX Firmware ver.: MSM8909C900B130_AMSS Sep 8 201517:25:25 SN: FTDJA16205011369 Custom SN: DU3FSG15BM035396 WiFi MAC: 1C:67:58:E3:5D:14 BlueTooth MAC: 1C:67:58:E32:44 Vendor: personal Country: ar SL: 00000000 SCL-L03C469B130_BOOT MSM8909C900B130_AMSS Sep 8 201517:25:25 SCL-L03_C00B006_EFS_RFNV_B05 HL3SCALEM SCL-L03C469B130_APPSBOOT SCL-L03C469B130_KERNEL SCL-L03C469B130_SYSTEM SCL-L03C469B130_RECOVERY MSM8909 HUAWEI SCL-L03 C110 D001 IMEI 1 Sim Lock status: NET: unknown NETSUB: unknown SP: unknown 2016-08-16 12:24:53.157 Autodetect started! 2016-08-16 12:24:54.847 Found COM port: COM470 2016-08-16 12:24:54.857 Open port COM470 (DBAdapter Reserved Interface (COM470))... 2016-08-16 12:24:54.974 Connecting to server... 2016-08-16 12:24:56.263 Connected! 2016-08-16 12:24:56.270 Read data from server... 2016-08-16 12:24:58.572 Read data from server success! 2016-08-16 12:24:58.779 Phone authorize start 2016-08-16 12:24:58.790 Phone authorize success! 2016-08-16 12:24:58.797 Read secure info... 2016-08-16 12:24:58.910 Read secure info success! 2016-08-16 12:24:58.916 Read basic info... 2016-08-16 12:24:58.946 Read basic info success! 2016-08-16 12:24:58.952 Unlocking start 2016-08-16 12:24:58.986 Reading secure data from server... 2016-08-16 12:25:01.504 Reading secure data from server success! 2016-08-16 12:25:01.609 Unlock done! 2016-08-16 12:25:01.639 Job finished! Thanks Furious Gold Team |
08-17-2016, 13:34 | #13260 (permalink) |
Freak Poster Join Date: Jul 2009 Location: paraguay
Member: 1086987 Status: Offline Sonork: 1617504 Thanks Meter: 109 | Software engine version: 1.0.0.9858 Searching phone ... MODEL : QCOM SERIES 48 COMPILED DATE : Nov 16 2015 18:42:00 RELEASE DATE : Jun 25 2015 03:00:00 FIRMWARE INFO : 8909_r011302105.1_20150715 IMEI : 86782002391116-0 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; FIRMWARE: Y560-L03V100R001C464B043 SN: U5UBBBE610803785 IMEI: 86782002391116-0 REQUESTING AUTH; CALCULATING; AUTH DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Log file saved to: LOG_17_08_2016_08_32_50.txt |
