Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > FuriousGold
FuriousGold FuriouS GOLD Support Area | Powered by FuriousTeam
Old 09-12-2016, 17:48   #13306 (permalink)
Member: 2382052
Thanks Meter: 1,511
huawey y538 unlock done
2016-09-12 12:45:50.716 Autodetect started!
2016-09-12 12:45:52.382 Found COM port: COM612
2016-09-12 12:45:52.386 Open port COM612 (DBAdapter Reserved Interface (COM612))...
2016-09-12 12:45:52.498 Connecting to server...
2016-09-12 12:45:54.646 Connected!
2016-09-12 12:45:54.648 Read data from server...
2016-09-12 12:45:56.646 Read data from server success!
2016-09-12 12:45:56.790 Phone authorize start
2016-09-12 12:46:01.451 Phone authorize success!
2016-09-12 12:46:01.457 Read secure info...
2016-09-12 12:46:01.533 Read secure info success!
2016-09-12 12:46:01.536 Read basic info...
2016-09-12 12:46:01.552 Read basic info success!
2016-09-12 12:46:01.555 Unlocking start
2016-09-12 12:46:01.570 Reading secure data from server...
2016-09-12 12:46:04.626 Reading secure data from server success!
2016-09-12 12:46:04.693 Unlock done!
2016-09-12 12:46:04.712 Job finished!
Old 09-13-2016, 16:02   #13307 (permalink)
ibrajinja's Avatar
Member: 562975
Sonork: better tomorow
Thanks Meter: 247
Wink HUAWEI Y300-u11 unlocked
Searching phone;
Phone detected (@oem49.inf,%vcom_preloader%;MediaTek PreLoader USB VCOM (Android))
Preparing to start meta mode;
Searching for debug port; (be sure drivers from support were installed)
Debug Port found on Android Adapter PCUI (COM27);
Preparing to connect meta mode;
Meta mode entered;
Baseband Chip: MT6572, E01
Sw version: MOLY.WR8.W1315.MD.WG.MP.V15.P11
Hw Version: HUAWEI72_WE_JB3_HSPA_HW
Reading phone info;
IMEI: 867599-02-340136-0
Reading simlock info;
Locked to: 641-10
code_cat_n: 1505725322541611 enabled: yes tries: 10
code_cat_ns: 56781234 enabled: no tries: 10
code_cat_sp: 11112222 enabled: no tries: 10
code_cat_c: 33334444 enabled: no tries: 10
code_cat_sim: 55556666 enabled: no tries: 10
code_cat_ns_sp: 77778888 enabled: no tries: 10
code_cat_sim_c: 99990000 enabled: no tries: 10
Unlocking SIM2 too.
Time needed - 00:01:45
Log file saved to: LOG_13_09_2016_17_56_37.txt
Old 09-14-2016, 20:30   #13308 (permalink)
Member: 2382052
Thanks Meter: 1,511
zte z222 unlock done
Software engine version: 1.0.0.10319
Searching phone ...
MODEL : QCOM SERIES 10
COMPILED DATE : Mar 28 2014 08:52:00
RELEASE DATE : Dec 30 2011 06:00:00
FIRMWARE INFO : ATT_AM_P671B41V1.0.0B13-S
IMEI : 86609902520620-7
BLUETOOTH ADDR : 1B D4 1E D7 37 D4
FON;
INIT NAND ROUTINES;
NAND INIT MADE;
PHONE CODE: 0000
READING;
CALCULATING;
BEFORE BACKUP: 7ECC4C173C288BBEB584F2FD1D0D1B21.bin
ERASING;
WRITING;
READING;
AFTER BACKUP: 17E1F6C2C2933818FC0D400C8E8123DA.bin
UNLOCKED;
FOFF;
RESET !
Log file saved to: LOG_14_09_2016_15_28_46.txt
Time needed - 00:00:27
Old 09-15-2016, 07:23   #13309 (permalink)
Member: 2250932
Sonork: pktech
Thanks Meter: 92
Wiko Sunny Unlock Successfully FuriousGold -MTK Reader
Old 09-15-2016, 21:56   #13310 (permalink)
Member: 2382052
Thanks Meter: 1,511
BLU jenny tv unlock done
Using library Brom_DLL_v5.1316.1
Searching phone;
(for some models keep SPACE or * (STAR) key pressed before inserting the cable)
Phone detected (USB Single Port (COM22))
Meta mode entered;
Baseband Chip: MT6261
Sw version: BLU_T266T_V03_DOMINICANA
Hw Version: S268_V01
Reading phone info;
IMEI: 354333-06-897493-7
Reading security;
Done;
Checking;
Preparing;
Writing security;
Phone unlocked; Remove battery and cable;
Time needed - 00:00:08
Log file saved to: LOG_15_09_2016_16_54_57.txt
Old 09-16-2016, 11:39   #13311 (permalink)
..::Waqar::..'s Avatar
Member: 904753
Sonork: 100.1583681
Thanks Meter: 2,677
Alcatle 5054O Unlock Success by Furious Gold
Here is LOG
Connecting;
Check your phone and "Always allow from this computer" and select "OK".
Connected;
BRAND: TCL
MODEL: ALCATEL_5054O
ANDROID: v5.1.1
CPU: QCOM
IMEI: NA
KERNEL: Linux version 3.10.49-g6e268a6 (android-bld@bld71) (gcc version 4.8 (GCC) ) #1 SMP PREEMPT Thu Feb 4 00:19:54 CST 2016
Cleaning;
Loading files;
Done;
Reconnecting;
Getting memory info;
Done;
Gathering info;
Done;
Cleaning done;
Setting permissions;
Reading data;
Getting data size;
00001246 bytes
Decompressing;
IMEI: 014556000111588
PTH: 12
PTS: GAF
PROV_ID: 5054O-2KRKUS3-R
SBTADDR: F0:34:04:23:EF:48
SWIFIADDR: F0:34:04:23:EF:49
HS_PN: SAA35HPAA10C
SSN: F1KG07BDJFZ01KI
Getting data size;
00302874 bytes
Decompressing;
Mounting the partition;
Done;
Done;
Done;
Getting data size;
00001790 bytes
Decompressing;
Bruteforcing data; This operation can take up to 30 minutes !!!
Done;
Work id: 03A0B40B
Calculating security;
Calc 0000 ;
Calc 0001 ;
Calc 0002 ;
Calc 0003 ;
SIM_LOCK REMOVED !
BR.
Waqar
Old 09-17-2016, 08:17   #13312 (permalink)
sebY7676's Avatar
Member: 637351
Thanks Meter: 167
V785 unlocked
Using library Brom_DLL_v7.1413.5
Searching phone;
Phone detected (PreLoader USB VCOM Port)
Preparing to start flash mode;
Preparing to open COM25
Connecting;
Downloading DA;
Initializing;
Rid: ad61063d9edb98e4b061402a0e5b47f9
Requesting baudrate change;
Done;
USB SPEED: USB_HIGH_SPEED
Switching to DA_HIGHSPEED_VCOM;
Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver\x86;
If the detection fails, install manually the port from the device manager using usbvcom.inf;
DA_HIGHSPEED_VCOM (DA USB VCOM Port)
TRYING TO OPEN COM42;
DEVICE INFO:
BB CHIP: MT6572_S00 [CA01, 00, 6572, FF]
HW_STORAGE_EMMC: 0x30000111 0x39473430 0x829C1030 0xE7AF6AD7  [SIZE=0xEC480000]
IMEI1 [OTP 0001]: 359729-05-7xxxxx-x
IMEI2 [OTP 0001]: 000000-00-000000-0
PROVIDER: V785-2BVDGB1
USRDATA INFO: 0x61B80000 SIZE: 0x8A900000
Searching data;
Locked to [SIM1]:    234-15
code_cat_n:    32145107 enabled:    yes    tries: 7
code_cat_ns:    32362234 enabled:    no    tries: 10
code_cat_sp:    33235386 enabled:    no    tries: 10
code_cat_c:    33136091 enabled:    no    tries: 10
code_cat_sim:    30371053 enabled:    no    tries: 10
code_cat_ns_sp:    53297761 enabled:    no    tries: 5
code_cat_sim_c:    86817778 enabled:    no    tries: 5
Time needed - 00:00:16
Old 09-17-2016, 08:18   #13313 (permalink)
sebY7676's Avatar
Member: 637351
Thanks Meter: 167
4013x unlocked
Searching phone;
Connecting;
Downloading DA;
Initializing;
Rid: dce1f9ef22bf669f47de2c0ef5fab6c4
Done;
DEVICE INFO:
HW_STORAGE_EMMC: 0x46000115 0x43355835 0xC9660142 0xFF5247C4  [SIZE=0xE9880000]
IMEI1 [OTP 0001]: 356257-06-30xxxx-x
PROVIDER: 4013X-2ARGRO1
USRDATA INFO: 0x6E380000 SIZE: 0x7B500000
Searching data;
Locked to [SIM1]:    226-10
code_cat_n:    0680660310 enabled:    yes    tries: 8
code_cat_ns:    1855743165 enabled:    no    tries: 10
code_cat_sp:    3329931288 enabled:    no    tries: 10
code_cat_c:    3005266738 enabled:    no    tries: 10
code_cat_sim:    2651119786 enabled:    no    tries: 10
code_cat_ns_sp:    1667549585 enabled:    no    tries: 5
code_cat_sim_c:    1625824075 enabled:    no    tries: 5
Old 09-17-2016, 08:22   #13314 (permalink)
sebY7676's Avatar
Member: 637351
Thanks Meter: 167
v895n unlocked
Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ;
Phone detected (USB Composite Device)
Preparing to enter download mode;
Preparing to open COM199
Connecting;
Init;
Port opened;
Phone detected (Android HS-USB QDLoader 9008)
Preparing to open COM76
Connecting;
Loading;
Init;
Port opened;
Hello Received;
BOOT Loaded;
Getting config;
Getting mem info;
Found an eMMC memory 22D4
IMEI:        356907065xxxxx-x
PTH:        13
PTS:        W7A
PROV_ID:        V895N-2HVDRO1
SBTADDR:    8C:99:E6:C6:82:81
SWIFIADDR:    8C:99:E6:C6:82:82
HS_PN:        SAA6197AAC0C
SSN:        3PKC34CB2NY02D8
Work id:        130DC8DE
Setup 1;
Done;
Setup 2;
Done;
Uploading;
Done;
SECURITY: X9W7FLA0BG00 Size: 00000430
Backup saved to: 35690706572944-0
Checking the simlock;
Magic ok;
Unlocking;
SIM_LOCK REMOVED !
Log file saved to: LOG_16_09_2016_10_13_38.txt
Time needed - 00:02:57
Old 09-19-2016, 13:11   #13315 (permalink)
razib143's Avatar
Member: 348877
Sonork: 1601289
Thanks Meter: 1,178
Wiko Lenny2 Direct uNlock done..
Using library Brom_DLL_v7.1522.2
Searching phone in normal mode;
[connect the phone powered off to the usb cable]
Phone detected (PreLoader USB VCOM Port (COM92))
Preparing to open COM92
Connecting;
Downloading DA;
Initializing;
Rid: ca85d97546d5bfb264185631c398dc5c
Done;
Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86;
DA_HIGHSPEED_VCOM (@oem118.inf,%mtk_sp_da%;DA USB VCOM Port)
TRYING TO OPEN COM98;
DEVICE INFO:
BB CHIP: MT6580_S00 [CA00, 00, 6580, FF]
HW_STORAGE_EMMC: 0x46000115 0x4D37324A 0xDC440242 0xFF539E9A [SIZE=0xE9880000]
IMEI1 [OTP 0000]: 000000-00-000000-0
IMEI2 [OTP 0000]: 000000-00-000000-0
PROVIDER: N/A
USRDATA INFO: 0x59800000 SIZE: 0x90080000
Searching data;
Locked to [SIM1]: 228-02
code_cat_n: 87654321 enabled: yes tries: 5
code_cat_ns: 56781234 enabled: no tries: 5
code_cat_sp: 11112222 enabled: no tries: 5
code_cat_c: 33334444 enabled: no tries: 5
code_cat_sim: 55556666 enabled: no tries: 5
code_cat_ns_sp: 77778888 enabled: no tries: 5
code_cat_sim_c: 99990000 enabled: no tries: 5
Locked to [SIM2]: 228-02
Time needed - 00:00:52
Log file saved to: LOG_19_09_2016_10_55_32.txt
Old 09-19-2016, 17:41   #13316 (permalink)
razib143's Avatar
Member: 348877
Sonork: 1601289
Thanks Meter: 1,178
Huawei Kestrel Direct unlock done..
2016-09-19 16:36:28.512 Autodetect started!
2016-09-19 16:36:30.386 Found COM port: COM196
2016-09-19 16:36:30.402 Open port COM196 (DBAdapter Reserved Interface (COM196))...
2016-09-19 16:36:30.542 Connecting to server...
2016-09-19 16:36:32.118 Connected!
2016-09-19 16:36:32.133 Read data from server...
2016-09-19 16:36:34.442 Read data from server success!
2016-09-19 16:36:34.723 Phone authorize start
2016-09-19 16:36:34.739 Phone authorize success!
2016-09-19 16:36:34.754 Read secure info...
2016-09-19 16:36:34.910 Read secure info success!
2016-09-19 16:36:34.926 Read basic info...
2016-09-19 16:36:34.973 Read basic info success!
2016-09-19 16:36:34.988 Unlocking start
2016-09-19 16:36:35.441 Read data from server...
2016-09-19 16:36:37.687 Read data from server success!
2016-09-19 16:36:37.687 Writing security data...
2016-09-19 16:36:37.905 Write security data success!
2016-09-19 16:36:38.202 Unlock done!
2016-09-19 16:36:38.233 Job finished!
Old 09-20-2016, 20:38   #13317 (permalink)
razib143's Avatar
Member: 348877
Sonork: 1601289
Thanks Meter: 1,178
Rook from EE Unlock done
Phone detected (MediaTek PreLoader USB VCOM (Android) (COM150))
Preparing to open COM150
Connecting;
Downloading DA;
Initializing;
Rid: 9d1ac4030f6803c28997a600cad4dcbf
Done;
USB SPEED: USB_FULL_SPEED
DEVICE INFO:
BB CHIP: MT6735M_S00 [CA00, 00, 335, FF]
HW_STORAGE_EMMC: 0x51000115 0x4D533237 0x8B850042 0x19921BDC [SIZE=0x1D2880000]
PROVIDER: N/A
USRDATA INFO: 0x99000000 SIZE: 0x39880000
Searching data;
Locked to [SIM1]: 234-30
code_cat_n: 8089986872054619 enabled: yes tries: 9
Time needed - 00:00:15
Log file saved to: LOG_20_09_2016_16_44_12.txt
Old 09-21-2016, 17:01   #13318 (permalink)
Member: 2382052
Thanks Meter: 1,511
zte f555 unlock done
Software engine version: 1.0.0.10322
Searching phone ...
MODEL : QCOM SERIES 26
COMPILED DATE : Sep 30 2013 02:16:00
RELEASE DATE : Apr 24 2012 22:00:00
FIRMWARE INFO : MPCS_US_P671A91V1.0.0B05-S
IMEI : 35181904004664-9
BLUETOOTH ADDR : 73 89 51 B6 E8 78
INIT NAND ROUTINES;
NAND INIT MADE;
PHONE CODE: 0000
READING;
CALCULATING;
BEFORE BACKUP: FD301E27A44C3781CD79E6AD23FA0BC7.bin
ERASING;
WRITING;
READING;
AFTER BACKUP: D6D970C4423B8CA67F77EFE4BDB68E3E.bin
UNLOCKED;
RESET !
Log file saved to: LOG_21_09_2016_11_52_47.txt
Time needed - 00:00:07
Old 09-21-2016, 22:20   #13319 (permalink)
Member: 2382052
Thanks Meter: 1,511
2016-09-21 17:18:24.263 Autodetect started!
2016-09-21 17:18:25.890 Found COM port: COM612
2016-09-21 17:18:26.963 Start read phone info!
2016-09-21 17:18:26.967 Open port COM612 (DBAdapter Reserved Interface (COM612))...
2016-09-21 17:18:27.078 Phone authorize start
2016-09-21 17:18:27.083 Connecting to server...
2016-09-21 17:18:28.928 Connected!
2016-09-21 17:18:28.932 Read data from server...
2016-09-21 17:18:31.067 Read data from server success!
2016-09-21 17:18:33.699 Phone authorize success!
2016-09-21 17:18:33.703 Read secure info...
2016-09-21 17:18:33.787 Read basic info...
2016-09-21 17:18:33.812 Detect phone done!
Model: HUAWEIY538_A1
MEID: 86726002396351
pESN: 80382C73
IMEI: 867260023963517
IMEI 0: 867260023963517
Firmware ver.: MSM8909C237B150_AMSS Dec 18 201506:44:29
SN: URX0215C05000779
Custom SN: 023CPU15C4003831
WiFi MAC: 48B:50:B7:0F:8F
BlueTooth MAC: 48B:50:B7:150
Vendor: sprint
Country: us
SL: 00000000
Y538C237B150_BOOT
Y538-C00B023_EFS_RFNV_C09
HL1Y538A1M
Y538C237B150_APPSBOOT
Y538C237B150_KERNEL
Y538C237B150_SYSTEM
Y538C237B150_RECOVERY
MSM8909
HUAWEI Y538_A1
C237
D150
MSM8909_Y538_A1_
IMEI 1 Sim Lock status:
NET: unknown
NETSUB: unknown
SP: unknown
2016-09-21 17:19:03.646 Autodetect started!
2016-09-21 17:19:05.314 Found COM port: COM612
2016-09-21 17:19:05.320 Open port COM612 (DBAdapter Reserved Interface (COM612))...
2016-09-21 17:19:05.434 Connecting to server...
2016-09-21 17:19:07.116 Connected!
2016-09-21 17:19:07.122 Read data from server...
2016-09-21 17:19:09.299 Read data from server success!
2016-09-21 17:19:09.686 Phone authorize start
2016-09-21 17:19:09.695 Phone authorize success!
2016-09-21 17:19:09.701 Read secure info...
2016-09-21 17:19:09.785 Read secure info success!
2016-09-21 17:19:09.790 Read basic info...
2016-09-21 17:19:09.816 Read basic info success!
2016-09-21 17:19:09.822 Unlocking start
2016-09-21 17:19:09.843 Reading secure data from server...
2016-09-21 17:19:12.753 Reading secure data from server success!
2016-09-21 17:19:12.831 Unlock done!
2016-09-21 17:19:12.847 Job finished!
Old 09-21-2016, 22:42   #13320 (permalink)
Member: 2382052
Thanks Meter: 1,511
alcatel 3022g unlock done
Searching phone;
For an successful connection do the following:
1. Remove battery and usb cable
2. Insert the usb cable in the phone
3. Keep pressed the boot key and insert the battery
Phone detected (@oem220.inf,%dc_diag%;SPRD U2S Diag)
Preparing to sync;
Port opened [COM439];
Mobile type: SPRD3
Connected;
Starting;
FDL sent;
Syncing;
Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT
Chip type: 6531 FdlStat: 0001
Starting auth;
HW IMEI : 000000-00-000000-0
Memory [CS0]: 00C8:0060:0017 - SIZE : 00800000
Reading phone info;
PHONE INFO: 3022G-3ARGDO1
BT ADDR: D4:B6:4A:598:94
SW IMEI[0]: 014227-00-217478-0
SW IMEI[1]: 352751-01-952326-7
SW IMEI[2]: 358570-01-010389-3
SW IMEI[3]: 910575-60-140046-8
SIMLOCK FLAG: ON
FIXED NV BASE: 30640000
Reading NV;
NV saved to : NV_000000-00-000000-0_014227-00-217478-0_65310001_21_09_2016_17_40_10.spd
IMEI: 014227-00-217478-0 UNLOCK CODE: 38056513
Re-programming;
NV programmed;
Done;
Log file saved to: LOG_21_09_2016_17_40_30.txt
Time needed - 00:00:37
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.38810 seconds with 10 queries
