Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > FuriousGold
FuriousGold FuriouS GOLD Support Area | Powered by FuriousTeam
Old 12-29-2016, 06:34   #13486 (permalink)
lifegood8's Avatar
Member: 757297
Thanks Meter: 36
Talking Huawei lua-l02 direct unlock done
Searching phone;
(insert the USB cable in the powered off phone)
Phone detected (MediaTek PreLoader USB VCOM (Android))
Preparing to start MTK debug mode;
Searching for debug port; (be sure drivers from support were installed)
MTK debug mode entered;
Baseband Chip: MT6735M,S01
Sw version:
Hw Version: ALPS.L1.MP3.V2.95_OT6735M.35GU.LU.L1_P1
Baseband Chip: MT6735, E00
Sw version: MOLY.LR9.W1444.MD.LWTG.MP.V48.P8
Hw Version: OT6735_65C_LU_L1_HW
Reading phone info;
IMEI 1: 86***********
IMEI 2: N/A
Open port success!
2016-12-29 08:26:16.394 Reading data from server...
2016-12-29 08:26:16.980 Reading data from server success!
Reading simlock info;
Gathering info;
Simlock ok;
SIM1 Locks cleared;
Simlock ok;
SIM2 Locks cleared;
Simlock read end;
Old 12-29-2016, 10:56   #13487 (permalink)
soulgsm's Avatar
Member: 1872225
Sonork: 100.1668729
Thanks Meter: 32
VDF500
Using library Brom_DLL_v7.1522.2
Searching phone in normal mode;
[connect the phone powered off to the usb cable]
Phone detected (PreLoader USB VCOM Port (COM7))
Preparing to start flash mode;
Preparing to open COM7
Connecting;
Downloading DA;
Initializing;
Rid: 5cc36749012d9e5c26a866a43eb320d7
Requesting baudrate change;
Done;
USB SPEED: USB_HIGH_SPEED
Switching to DA_HIGHSPEED_VCOM;
Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86;
If the detection fails, install manually the port from the device manager using usbvcom.inf;
DA_HIGHSPEED_VCOM (@oem107.inf,%mtk_sp_da%;DA USB VCOM Port)
TRYING TO OPEN COM8;
DEVICE INFO:
BB CHIP: MT6735M_S00 [CA00, 00, 335, FF]
HW_STORAGE_EMMC: 0x30000111 0x37473830 0xCF220030 0xFD43343A [SIZE=0x1D2C00000]
IMEI1 [OTP 0000]: 000000-00-000000-0
IMEI2 [OTP 0000]: 000000-00-000000-0
PROVIDER: V500-2BVDRO1
USRDATA INFO: 0x84000000 SIZE: 0x4EC00000
Searching data;
Locked to [SIM1]: 226-01
code_cat_n: 1113531683220808 enabled: yes tries: 10
code_cat_ns: 0089550815023381 enabled: no tries: 10
code_cat_sp: 4952391196892074 enabled: no tries: 10
code_cat_c: 2327674908451254 enabled: no tries: 10
code_cat_sim: 9409919598990412 enabled: no tries: 10
code_cat_ns_sp: 8391823918787605 enabled: no tries: 5
code_cat_sim_c: 8313251747747286 enabled: no tries: 5
Phone unlocked; Remove battery and cable;
Time needed - 00:00:07
Thank you
Old 12-30-2016, 08:39   #13488 (permalink)
totmititelu's Avatar
Member: 880649
Thanks Meter: 73
Samsung e2200 read codes done
Searching phone;
For an successful connection do the following:
1. Remove battery and usb cable
2. Insert the usb cable in the phone
3. Keep pressed the boot key and insert the battery
Phone detected (SCI USB2Serial)
Preparing to sync;
Port opened [COM4];
Mobile type: SPRD3
Connected;
Starting;
FDL sent;
Syncing;
Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT
Chip type: 6530 FdlStat: 0000
Starting auth;
HW IMEI : 000000-00-000000-0
Memory [CS0]: 00EF:0060:0018 - SIZE : 02000000
Reading phone info;
PHONE INFO: NONE
PHONE SN: R21DB9V9JS
MSL PASS: 5A255707060B150B2B5E4D2E073B0D2A
BT ADDR: C0:0D:5A:C96:30
SW IMEI[0]: 358414-05-159633-7
SW IMEI[1]: 000000-00-000000-0
SW IMEI[2]: 000000-00-000000-0
SW IMEI[3]: 910575-60-140046-8
SIMLOCK FLAG: ON
FIXED NV BASE: 31050000
Reading NV;
NV saved to : NV_000000-00-000000-0_358414-05-159633-7_65300000_30_12_2016_09_29_38.spd
Calculating ...
Freeze code: 64860618
NET lock: 46264291
Sub lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
Code reading finished; Remove battery and cable;
Old 12-30-2016, 18:35   #13489 (permalink)
razib143's Avatar
Member: 348877
Sonork: 1601289
Thanks Meter: 1,178
Wiko Lenny 2 Unlocked
Phone detected (PreLoader USB VCOM (Android) (COM92))
Preparing to open COM92
Connecting;
Downloading DA;
Initializing;
Rid: c7e6774e677eaaa89e1e25c1c844106e
Done;
DA_HIGHSPEED_VCOM (@oem1.inf,%vcom_da%;MediaTek DA USB VCOM (Android))
TRYING TO OPEN COM98;
DEVICE INFO:
BB CHIP: MT6580_S00 [CA00, 00, 6580, FF]
HW_STORAGE_EMMC: 0x46000115 0x4D37324A 0x04960242 0xBD7312D3 [SIZE=0xE9880000]
PROVIDER: N/A
USRDATA INFO: 0x59800000 SIZE: 0x60000000
Searching data;
Locked to [SIM1]: 228-01
code_cat_n: 87654321 enabled: yes tries: 5
code_cat_ns: 56781234 enabled: no tries: 5
code_cat_sp: 11112222 enabled: no tries: 5
code_cat_c: 33334444 enabled: no tries: 5
code_cat_sim: 55556666 enabled: no tries: 5
code_cat_ns_sp: 77778888 enabled: no tries: 5
code_cat_sim_c: 99990000 enabled: no tries: 5
Locked to [SIM2]: 228-01
Time needed - 00:00:38
Log file saved to: LOG_30_12_2016_17_02_26.txt
Old 01-02-2017, 16:53   #13490 (permalink)
razib143's Avatar
Member: 348877
Sonork: 1601289
Thanks Meter: 1,178
MTN C290 Unlocked :S
Searching phone;
Phone detected (@oem76.inf,%dvcdsc%;SCI USB2Serial)
Preparing to sync;
Port opened [COM45];
Mobile type: SPRD3
Connected;
Starting;
FDL sent;
Syncing;
Chip type: 6531 FdlStat: 0001
Starting auth;
Memory [CS0]: 00C8:0060:0016 - SIZE : 00400000
Reading phone info;
PHONE INFO: NONE
BT ADDR: 06:35:98:75:10:AB
SW IMEI[0]: 356041-07-5983AA-6
SW IMEI[1]: 356041-07-5983AA-4
SW IMEI[2]: 358570-01-0103AA-3
SW IMEI[3]: 910575-60-1400AA-8
SIMLOCK FLAG: ON
FIXED NV BASE: 303C0000
Uncompressing;
Done;
Re-programming;
FLS programmed;
Done;
Log file saved to: LOG_2_01_2017_15_30_28.txt
Time needed - 00:04:25
Old 01-02-2017, 23:56   #13491 (permalink)
GsmLiberty's Avatar
Member: 82759
Thanks Meter: 153
LG K420N reset FRP
LG K420N --- select LG K430N
Searching phone in emergency mode;
[connect the phone powered off keeping the volume up pressed to the usb cable]
Phone detected (USB\VID_1004&PID_633E&REV_0228)
Preparing to open COM195
Opened;
Authorising;
Authorized;
LAF_ERROR_ACCESS_DENIED
download_cable = USER
battery_level = 83
download_type =
download_speed = 0
usb_version = UHS
hardware_revision = rev_12
download_sw_version =
device_sw_version = K42010p
secure_device = U
laf_sw_version = 1.2
device_factory_version = LGK420nAT-00-V10b-260-01-MAY-24-2016+0
device_factory_out_version = LGK420nAT-00-V10p-GLOBAL-COM-MAY-24-2016+0
pid = CY19S160402001832
imei = 356600072xxxxxx
model_name = LG-K420n
device_build_type = U
chipset_platform = msm8916
target_operator = GLOBAL
target_country = COM
ap_factory_reset_status = 6
cp_factory_reset_status = 0
isDownloadNotFinish = 0
qem = 0
cupss_swfv = A1464059800-M1464059800-C1464062671-U1452845662-1
is_one_binary_dual_plan = 0
memory_size = 30535680
memory_id = Q316AB
bootloader_ver = MiniOS 3.0
islan_download = 0
skip_readwrite = 0
Linux version 3.10.49-g58186fe (lgmobile@LGEACI8R2) (gcc version 4.8 (GCC) ) #1 SMP PREEMPT Tue May 24 12:27:24 KST 2016
Factory Reset Protection successfully removed !
Time needed - 00:00:22
The Following User Says Thank You to GsmLiberty For This Useful Post:
Old 01-03-2017, 11:57   #13492 (permalink)
asad_nomy7's Avatar
Member: 570093
Thanks Meter: 1,067
Alcatel OT4060A Unlock successful.
Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ;
Phone detected (@oem199.inf,%qcomdevice90080%;ALCATEL HS-USB QDLoader 9008)
Preparing to open COM462
Connecting;
Loading;
Init;
Port opened;
Hello Received;
BOOT Loaded;
Getting config;
Getting mem info;
Found an eMMC memory 22CD
IMEI: 01469900736638-1
PTH: 06
PTS: M5K
PROV_ID: 4060A-2AAQUS3-R1
SBTADDR: 28:BE:03:84:54:F9
SWIFIADDR: 28:BE:03:9D:0C:B8
HS_PN: SAA1GY0WA10C
SSN: 48KB08CIKLZ04DM
Work id: 07B94370
Done;
SECURITY: X1M0UA02CL10 Size: 000002D4
Backup saved to: 01469900736638-1
Backup file(s) removed;
Unlocking;
SIM_LOCK REMOVED !
Log file saved to: LOG_3_01_2017_15_43_21.txt
Time needed - 00:00:35
Old 01-03-2017, 12:14   #13493 (permalink)
genci titi 2002's Avatar
Member: 193804
Sonork: 100.1684818
Thanks Meter: 1,690
Wink
Phone detected (USB Composite Device)
Preparing to enter download mode;
Preparing to open COM39
Connecting;
Init;
Port opened;
Phone detected (Android HS-USB QDLoader 9008)
Connecting;
Loading;
Init;
Port opened;
Hello Received;
BOOT Loaded;
Getting config;
Getting mem info;
IMEI: 01480200033806-4
PTH: 08
PTS: M5R
SBTADDR: 24:0D:C2:81:C7:F1
SWIFIADDR: 24:0D:C2:78:79:53
HS_PN: SAA1GY0WA10C
SSN: 48KB10CCHNZ006A
Work id: 092AE174
Done;
SECURITY: X1M0UA04CL10 Size: 000002E2
Backup saved to: 01480200033806-4
Unlocking;
SIM_LOCK REMOVED !
Log file saved to: LOG_3_01_2017_12_55_22.txt
Time needed - 00:00:34
Old 01-04-2017, 13:46   #13494 (permalink)
Member: 233142
Sonork: 100.1595099
Thanks Meter: 526
MobiWire ATOHI Unlock Done by selecting Doro 632
Old 01-05-2017, 12:28   #13495 (permalink)
Member: 2229851
Thanks Meter: 55
beeline pro4 MT6735m
Phone detected (MediaTek PreLoader USB VCOM (Android) (COM5))
Preparing to open COM5
Connecting;
Downloading DA;
Initializing;
Rid: 03dcf98d32931f8da0aa3660aa0ca684
Done;
DA_HIGHSPEED_VCOM (@oem44.inf,%vcom_da%;MediaTek DA USB VCOM (Android))
TRYING TO OPEN COM11;
DEVICE INFO:
HW_STORAGE_EMMC: 0x44000145 0x30303153 0xDC480138 0xBFB2302B [SIZE=0x1D2C00000]
PROVIDER: N/A
USRDATA INFO: 0x99000000 SIZE: 0x39C00000
Searching data;
File not found;
ST33A004
Locked to [SIM1]: 250-99
code_cat_n: 55348712 enabled: yes tries: 100
code_cat_ns: 56781234 enabled: no tries: 100
code_cat_sp: 11112222 enabled: no tries: 100
code_cat_c: 33334444 enabled: no tries: 100
code_cat_sim: 55556666 enabled: no tries: 100
code_cat_ns_sp: 77778888 enabled: no tries: 100
code_cat_sim_c: 99990000 enabled: no tries: 100
Time needed - 00:00:04
Old 01-05-2017, 14:11   #13496 (permalink)
Member: 193804
Sonork: 100.1684818
Thanks Meter: 1,690
Wink huawei y538 unlocked ok
Before detection connect cable to usb and enable Manufacture mode !
Qualcomm and HiSilicon: *#*#2846579#*#*
MTK: *#*#14789632#*#*
Windows: ##2846579#
ProjectMenu
1.Background setting
2.USB ports setting
Select Manufacture mode (for MTK other/debug mode)
2017-01-05 14:08:24.587 Autodetect started!
2017-01-05 14:08:33.398 Found COM port: COM148
2017-01-05 14:08:34.501 Start read phone info!
2017-01-05 14:08:34.504 Open port COM148 (DBAdapter Reserved Interface (COM148))...
2017-01-05 14:08:34.603 Phone authorize start
2017-01-05 14:08:34.607 Connecting to server...
2017-01-05 14:08:35.430 Connected!
2017-01-05 14:08:35.433 Read data from server...
2017-01-05 14:08:36.918 Read data from server success!
2017-01-05 14:08:38.587 Phone authorize success!
2017-01-05 14:08:38.590 Read secure info...
2017-01-05 14:08:38.933 Read basic info...
2017-01-05 14:08:39.012 Detect phone done!
Model: HUAWEIY538_A1
MEID: 86726002593557
pESN: 80D088A5
IMEI: 867260025935570
IMEI 0: 867260025935570
Firmware ver.: MSM8909C237B138_AMSS Oct 24 201519:04:45
SN: URX0216115000642
Custom SN: 023CPU1619009300
WiFi MAC: DC:EE:06:78:C3:A9
BlueTooth MAC: DC:EE:06:78:C9:EA
Vendor: sprint
Country: us
SL: 00000000
Y538C237B138_BOOT
Y538-C00B023_EFS_RFNV_C09
HL1Y538A1M
Y538C237B138_APPSBOOT
Y538C237B138_KERNEL
Y538C237B138_SYSTEM
Y538C237B138_RECOVERY
MSM8909
HUAWEI Y538_A1
C237
D138
MSM8909_Y538_A1_
IMEI 1 Sim Lock status:
NET: unknown
NETSUB: unknown
SP: unknown
2017-01-05 14:08:47.153 Autodetect started!
2017-01-05 14:08:47.972 Found COM port: COM148
2017-01-05 14:08:47.978 Open port COM148 (DBAdapter Reserved Interface (COM148))...
2017-01-05 14:08:48.082 Connecting to server...
2017-01-05 14:08:48.721 Connected!
2017-01-05 14:08:48.725 Read data from server...
2017-01-05 14:08:50.196 Read data from server success!
2017-01-05 14:08:50.333 Phone authorize start
2017-01-05 14:08:50.340 Phone authorize success!
2017-01-05 14:08:50.345 Read secure info...
2017-01-05 14:08:50.414 Read secure info success!
2017-01-05 14:08:50.419 Read basic info...
2017-01-05 14:08:50.436 Read basic info success!
2017-01-05 14:08:50.440 Unlocking start
2017-01-05 14:08:50.456 Reading secure data from server...
2017-01-05 14:08:52.220 Reading secure data from server success!
2017-01-05 14:08:52.277 Unlock done!
2017-01-05 14:08:52.302 Job finished!
Old 01-05-2017, 19:32   #13497 (permalink)
Member: 2216186
Sonork: 100.1668130
Thanks Meter: 120
Huawei H1611
2017-01-05 12:23:15.101 Autodetect started!
2017-01-05 12:23:15.997 Found COM port: COM363
2017-01-05 12:23:16.004 Open port COM363 (DBAdapter Reserved Interface (COM363))...
2017-01-05 12:23:16.152 Connecting to server...
2017-01-05 12:23:18.372 Connected!
2017-01-05 12:23:18.395 Read data from server...
2017-01-05 12:23:20.424 Read data from server success!
2017-01-05 12:23:20.638 Phone authorize start
2017-01-05 12:23:20.649 Phone authorize success!
2017-01-05 12:23:20.656 Read secure info...
2017-01-05 12:23:20.984 Read secure info success!
2017-01-05 12:23:20.991 Read basic info...
2017-01-05 12:23:21.130 Read basic info success!
2017-01-05 12:23:21.137 Unlocking start
2017-01-05 12:23:22.851 Read data from server...
2017-01-05 12:23:25.623 Read data from server success!
2017-01-05 12:23:25.629 Writing security data...
2017-01-05 12:23:25.859 Write security data success!
2017-01-05 12:23:26.298 Unlock done!
2017-01-05 12:23:26.308 Read bootloader code start
2017-01-05 12:23:26.318 Read data from server...
2017-01-05 12:23:27.417 Read data from server success!
2017-01-05 12:23:27.944 Read bootloader code success!
2017-01-05 12:23:27.951 Unlocking limitations...
2017-01-05 12:23:27.961 Reading data from server...
2017-01-05 12:23:28.550 Reading data from server success!
2017-01-05 12:23:28.974 Unlocking limitations success!
2017-01-05 12:23:28.986 Job finished!
Old 01-08-2017, 14:09   #13498 (permalink)
bright hlatini's Avatar
Member: 1614640
Thanks Meter: 468
Alcatel 4022D with Firefox OS unlock done
Searching phone;
Phone detected (@oem111.inf,%vcom_preloader%;MediaTek PreLoader USB VCOM (Android))
Preparing to start meta mode;
Debug Port found on MediaTek USB VCOM (Android) (COM145);
Preparing to connect meta mode;
Meta mode entered;
Baseband Chip: MT6572, E01
Sw version: MOLY.WR8.W1449.MD.WG.MP.V2.P5
Hw Version: JRDHZ72_W_FF_HSPA_HW
Reading phone info;
IMEI: 358808-06-272785-8
Locked to: 208-01
code_cat_n: 23358476 enabled: yes tries: 0
code_cat_ns: 40983194 enabled: no tries: 10
code_cat_sp: 40723134 enabled: no tries: 10
code_cat_c: 40455433 enabled: no tries: 10
code_cat_sim: 21750872 enabled: no tries: 10
code_cat_ns_sp: 53297761 enabled: no tries: 5
code_cat_sim_c: 86817778 enabled: no tries: 5
Unlocking SIM2 too.
Time needed - 00:01:16
Log file saved to: LOG_8_01_2017_15_06_05.txt
Old 01-09-2017, 06:32   #13499 (permalink)
Member: 579694
Thanks Meter: 75
Searching phone;
Phone detected (MediaTek PreLoader USB VCOM Port)
Baseband Chip: MT6735,S01
Sw version:
Hw Version: LYO-L02C718B122
Sw version: MOLY.LR9.W1444.MD.LWTG.MP.V42.P40
Hw Version: HQ6753_65C_B1N_L1_HW
Reading phone info;
IMEI 1: 861947031103963
IMEI 2: N/A
Open port success!
2017-01-09 12:28:35.581 Reading data from server...
2017-01-09 12:28:36.385 Reading data from server success!
Gathering info;
Simlock ok;
SIM1 Locks cleared;
Simlock ok;
SIM2 Locks cleared;
Simlock read end;
Old 01-09-2017, 11:29   #13500 (permalink)
Member: 880649
Thanks Meter: 73
MOBIWIRE AYASHA unlock ok
pack 6\OTZFlasher selectat ca OT-1052G/1052D
Using library Brom_DLL_v5.1428.0
Searching phone;
(for some models keep SPACE or * (STAR) key pressed before inserting the cable)
Phone detected (MTK USB Port (COM19))
Meta mode entered;
Baseband Chip: MT6261
Sw version: V02_160825_MBW_Ayasha_SKU1_MP
Hw Version: SAGETEL61M_11C_HW
Reading phone info;
IMEI: 352441-08-04XXXX
Reading security;
Done;
Checking;
Preparing;
Writing security;
Time needed - 00:00:17
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.38749 seconds with 10 queries
