02-23-2017, 16:05 | #13576 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem405.inf,%qcomdevice90080%;RELINK HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM29 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD IMEI: 01467100086113-0 PTH: 05 PTS: A45 PROV_ID: 4060O-2ARKUS3 SBTADDR: 20:A9:0E:FF:EFF SWIFIADDR: 20:A9:0E:EF:AD:22 HS_PN: SAA1GN0WA10C SSN: 96KB06CIFKZ03WN Bruteforcing data; This operation can take up to 30 minutes !!! Done; Work id: 078029F7 Done; SECURITY: XYA0UC00BR10 Size: 000002BF Backup saved to: 01467100086113-0 Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_23_02_2017_11_01_58.txt Time needed - 00:09:33 |
02-24-2017, 11:15 | #13577 (permalink) |
Freak Poster Join Date: Oct 2008 Location: Romania/Piatra Neamt
Member: 880649 Status: Offline Thanks Meter: 73 | HTC DESIRE 320 unlock MTKReader pack 6 Searching phone; Phone detected (PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Gadget VCOM Driver (COM259); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6582, E01 Sw version: MOLY.WR8.W1315.MD.WG.MP.V42.F4 Hw Version: CCI82_WE_UC81_KK_HSPA_HW Reading phone info; IMEI: 355xxx-06-02xxx Reading simlock info; Locked to: 226-01 code_cat_n: 59315064 enabled: yes tries: 10 code_cat_ns: 59315064 enabled: no tries: 10 code_cat_sp: 59315064 enabled: no tries: 10 code_cat_c: 59315064 enabled: no tries: 10 code_cat_sim: 59315064 enabled: no tries: 10 code_cat_ns_sp: 77778888 enabled: no tries: 11 code_cat_sim_c: 99990000 enabled: no tries: 11 Time needed - 00:02:58 Log file saved to: LOG_24_02_2017_12_04_51.txt |
02-24-2017, 14:44 | #13578 (permalink) |
Freak Poster Join Date: Jun 2011 Location: bruteforce locale
Member: 1589112 Status: Offline Sonork: 1618000 Thanks Meter: 139 | Alcatel cricked 6045o unlock done Alcatel cricked 6045o unlock done version 6.0.1 no need root or adb enable diag with this code ###2324# Software engine version: 1.0.0.10469 Searching phone ... MODEL : QCOM SERIES 46 COMPILED DATE : Jul 4 2016 17:36:00 RELEASE DATE : May 15 2016 22:00:00 FIRMWARE INFO : MPSS.DPM.2.0.2.c1-00140-M8936FAAAANUZM-2.55917.1 IMEI : 01449700411751-3 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; WORKING; SAVED: 4F76034BA1FA2BBF3E9B7CD2E41D1E32.bin UNLOCK CODE: N/A DONE; DOING EXTRA CALCULATION; AFTER UNLOCK YOU MUST RESTART THE PHONE MANUALLY; SIM_LOCK REMOVED ! RESET ! Log file saved to: LOG_24_02_2017_13_27_05.txt Time needed - 00:00:50 |
02-24-2017, 14:57 | #13579 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | Amazon fire unlock done by Furious Gold Software engine version: 1.0.0.10479 MODEL : QCOM SERIES 47 COMPILED DATE : Jan 27 2015 10:11:00 RELEASE DATE : Jan 8 2015 00:00:00 FIRMWARE INFO : PB_02_06_12 IMEI : 01428500120981-7 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; STARTING; READING; DONE; CHECKING SEC; DONE; UNLOCKING; DONE; READING; DONE; SIM_LOCK REMOVED ! AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY; Log file saved to: LOG_23_02_2017_23_44_56.txt Time needed - 00:00:25 Last edited by ghacks; 02-24-2017 at 14:59. Reason: i missing something |
02-25-2017, 19:55 | #13581 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | huawey y210 unlock done 2017-02-25 14:53:48.440 Autodetect started! 2017-02-25 14:53:49.293 Found COM port: COM279 2017-02-25 14:53:50.307 Start read phone info! 2017-02-25 14:53:50.309 Open port COM279 (DBAdapter Reserved Interface (COM279))... 2017-02-25 14:53:50.411 Phone authorize start 2017-02-25 14:53:50.417 Connecting to server... 2017-02-25 14:53:51.426 Connected! 2017-02-25 14:53:51.428 Read data from server... 2017-02-25 14:53:53.563 Read data from server success! 2017-02-25 14:53:54.821 Phone authorize success! 2017-02-25 14:53:54.826 Read secure info... 2017-02-25 14:53:54.918 Read basic info... 2017-02-25 14:53:55.008 Detect phone done! IMEI: 868096015579781 Firmware ver.: M7x25AV100R001C00B801_AMSS Jan 30 201317:00:31 SN: N5BBYB9390401017 Custom SN: 021XXEBY39030194 WiFi MAC: 50:9F:279:41:7B BlueTooth MAC: 50:9F:279:41:7A Vendor: orange Country: do M7x25AV100R001C00B801_BOOT M7x25AV100R001C00B801_AMSS Jan 30 201317:00:31 Y210-0100V100R001C00B004_EFS MSM7225A_Y210 .VerA Y210-0100V100R001C00B856_APPSBOOT Y210-0100V100R001C00B856_KERNEL Y210-0100V100R001C00B856_SYSIMG MSM7225AB IMEI 1 Sim Lock status: NET: locked, unlock retry counts: 0 NETSUB: unlocked SP: unlocked 2017-02-25 14:54:04.178 Autodetect started! 2017-02-25 14:54:05.052 Found COM port: COM279 2017-02-25 14:54:05.058 Open port COM279 (DBAdapter Reserved Interface (COM279))... 2017-02-25 14:54:05.169 Connecting to server... 2017-02-25 14:54:06.036 Connected! 2017-02-25 14:54:06.039 Read data from server... 2017-02-25 14:54:08.173 Read data from server success! 2017-02-25 14:54:08.348 Phone authorize start 2017-02-25 14:54:08.353 Phone authorize success! 2017-02-25 14:54:08.357 Read secure info... 2017-02-25 14:54:08.445 Read secure info success! 2017-02-25 14:54:08.448 Read basic info... 2017-02-25 14:54:08.539 Read basic info success! 2017-02-25 14:54:08.543 Unlocking start 2017-02-25 14:54:10.181 Read data from server... 2017-02-25 14:54:10.916 Read data from server success! 2017-02-25 14:54:10.920 Writing security data... 2017-02-25 14:54:11.258 Write security data success! 2017-02-25 14:54:11.681 Unlock done! 2017-02-25 14:54:11.690 Job finished! |
02-25-2017, 22:17 | #13582 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | ALCATEL 60450 UNLOCK DONE Software engine version: 1.0.0.10478 Searching phone ... MODEL : QCOM SERIES 46 COMPILED DATE : Oct 28 2015 16:23:00 RELEASE DATE : Aug 31 2015 03:00:00 FIRMWARE INFO : MPSS.DPM.2.0.2.c1.6-00022-M8936FAAAANUZM-1.26298.1.28320.1 IMEI : 01449700382631-2 BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; WORKING; SAVED: 929048D715975BDF97392CD9497D9A63.bin UNLOCK CODE: N/A DONE; DOING EXTRA CALCULATION; AFTER UNLOCK YOU MUST RESTART THE PHONE MANUALLY; SIM_LOCK REMOVED ! RESET ! Log file saved to: LOG_25_02_2017_17_15_16.txt Time needed - 00:00:51 |
02-26-2017, 08:14 | #13583 (permalink) |
Freak Poster Join Date: Jan 2014 Location: Iran-shz
Member: 2097579 Status: Offline Thanks Meter: 43 | Read bootloader code huawei honor 4X 2017-02-26 10:20:30.307 Autodetect started! 2017-02-26 10:20:30.895 Found COM port: COM77 2017-02-26 10:20:30.901 Open port COM77 (Android Adapter PCUI (COM77))... 2017-02-26 10:20:31.018 Connecting to server... 2017-02-26 10:20:31.616 Connected! 2017-02-26 10:20:31.618 Read data from server... 2017-02-26 10:20:33.818 Read data from server success! 2017-02-26 10:20:33.998 Phone authorize start 2017-02-26 10:20:37.436 Phone authorize success! 2017-02-26 10:20:37.439 Read secure info... 2017-02-26 10:20:40.684 Read secure info success! 2017-02-26 10:20:40.688 Read basic info... 2017-02-26 10:20:43.319 Read basic info success! 2017-02-26 10:20:43.324 Read bootloader code start 2017-02-26 10:20:43.336 Reading data from server... 2017-02-26 10:20:44.017 Reading data from server success! 2017-02-26 10:20:44.448 Reading data from server... 2017-02-26 10:20:44.897 Reading data from server success! 2017-02-26 10:20:45.320 Read bootloader code success! 2017-02-26 10:20:45.324 Job finished! Bootloader code ******************* |
02-26-2017, 09:51 | #13584 (permalink) |
Member: 2097579 Status: Offline Thanks Meter: 43 | Repair IMEI huawei honor 4X 2017-02-26 12:13:03.421 Autodetect started! 2017-02-26 12:13:04.022 Found COM port: COM77 Fixed IMEI 1 CRC: *************** Fixed IMEI 2 CRC: *************** 2017-02-26 12:13:04.041 Open port COM77 (Android Adapter PCUI (COM77))... 2017-02-26 12:13:04.162 Connecting to server... 2017-02-26 12:13:05.164 Connected! 2017-02-26 12:13:05.166 Read data from server... 2017-02-26 12:13:07.126 Read data from server success! 2017-02-26 12:13:08.223 Repairing start New IMEI 1 : *************** New IMEI 2 : *************** 2017-02-26 12:13:08.229 Phone authorize start 2017-02-26 12:13:10.748 Phone authorize success! 2017-02-26 12:13:14.031 Read basic info... 2017-02-26 12:13:16.639 Read secure info... 2017-02-26 12:13:16.647 Repair IMEI 1 start! 2017-02-26 12:13:16.653 Phone secure identify start 2017-02-26 12:13:20.970 Phone secure identify success! 2017-02-26 12:13:20.972 Reading data from server... 2017-02-26 12:13:23.605 Reading data from server success! 2017-02-26 12:13:25.572 Repair IMEI 1 Success! 2017-02-26 12:13:25.579 Repair IMEI 2 start! 2017-02-26 12:13:25.586 Phone secure identify start 2017-02-26 12:13:31.570 Phone secure identify success! 2017-02-26 12:13:31.575 Reading data from server... 2017-02-26 12:13:35.204 Reading data from server success! 2017-02-26 12:13:37.190 Repair IMEI 2 Success! 2017-02-26 12:13:37.211 Finished! |
02-28-2017, 10:19 | #13585 (permalink) |
Member: 880649 Status: Offline Thanks Meter: 73 | huawei CUN-L01 unlock ok Searching phone; (insert the USB cable in the powered off phone) Phone detected (PreLoader USB VCOM Port) Preparing to start MTK debug mode; Searching for debug port; (be sure drivers from support were installed) MTK debug mode entered; Baseband Chip: MT6735,S01 Sw version: Hw Version: CUN-L01C629B101 Baseband Chip: MT6735, E00 Sw version: MOLY.LR9.W1444.MD.LWTG.MP.V42.P35 Hw Version: HQ6753_65C_B1N_L1_HW Reading phone info; IMEI 1: 8697850222xx IMEI 2: N/A Open port success! 2017-02-28 11:11:41.093 Reading data from server... 2017-02-28 11:11:41.437 Reading data from server success! Reading simlock info; Gathering info; Simlock ok; SIM1 Locks cleared; Simlock ok; SIM1 Locks cleared; Simlock ok; SIM2 Locks cleared; Simlock ok; SIM2 Locks cleared; Simlock read end; 2017-02-28 11:11:44.343 Reading data from server... 2017-02-28 11:11:44.687 Reading data from server success! BOOT KEY read success! 2017-02-28 11:11:44.890 Reading data from server... 2017-02-28 11:11:45.234 Reading data from server success! FRP KEY read success! BOOT KEY: 589C2F4201FFDFC5 Use this command for unlock Bootloader: Fastboot oem unlock 589C2F4201FFDFC5 FRP KEY: 4D1896FB6ED80C18 Use this command for unlock FRP: Fastboot oem frp-unlock 4D1896FB6ED80C18 |
03-01-2017, 06:57 | #13586 (permalink) |
No Life Poster Join Date: Oct 2007 Location: india
Member: 618404 Status: Offline Thanks Meter: 311 | alcatel 1016g unlocking done............ alcatel 1016g unlocking done by selecting model no.1016 Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (@oem109.inf,%dvcdsc%;SCI USB2Serial) Preparing to sync; Port opened [COM14]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT Chip type: 6531 FdlStat: 0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00C8:0060:0016 - SIZE : 00400000 Reading phone info; PHONE INFO: 1016G-3AE8GB1 BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: 358734-07-150717-4 SW IMEI[1]: 352751-01-952326-7 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: ON FIXED NV BASE: 303C0000 Reading NV; NV saved to : NV_000000-00-000000-0_358734-07-150717-4_65310001_28_02_2017_15_48_56.spd IMEI: 358734-07-150717-4 UNLOCK CODE: 45415080 Re-programming; NV programmed; Done; Phone unlocked; Remove battery and cable; thxs furious team wbr, rajesh_ch |
03-01-2017, 16:53 | #13587 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Romania, Bistrita Age: 70
Member: 85467 Status: Offline Thanks Meter: 104 | Orange Rise 51 frp removed hy Orange Rise 51 - 5045y, frp removed ok Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM8)) Preparing to start flash mode; Preparing to open COM8 Connecting; Downloading DA; Initializing; Rid: 858e1c99f96198e3b57d7b7ba9d6ffe5 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem132.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM9; DEVICE INFO: BB CHIP: MT6735M_S00 [CA00, 00, 335, FF] HW_STORAGE_EMMC: 0x504E01FE 0x35394A31 0x1F29124B 0x1153A972 [SIZE=0x1D3600000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: 5045Y-2ARGRO3 USRDATA INFO: 0xB7800000 SIZE: 0x1BE00000 Factory Reset Protection successfully removed ! Time needed - 00:00:02 Log file saved to: LOG_1_03_2017_17_44_21.txt thx |
The Following User Says Thank You to gilica_gsm For This Useful Post: |
03-03-2017, 11:30 | #13588 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Romania,Buc
Member: 694535 Status: Offline Thanks Meter: 70 | Allview P6 life FRP done :D Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM51)) Preparing to start flash mode; Preparing to open COM51 Connecting; Downloading DA; Initializing; Rid: 4a98aa87a21c8a2cd6a03e20ed6c0d9a Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem122.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM95; DEVICE INFO: BB CHIP: MT6582_S01 [CA01, 01, 6582, FF] HW_STORAGE_EMMC: 0x4B000115 0x4D565837 0xC1130142 0x2371D6DA [SIZE=0x1D2880000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x93A80000 SIZE: 0x3EE00000 Factory Reset Protection successfully removed ! Time needed - 00:00:01 Log file saved to: LOG_3_03_2017_12_28_09.txt done thanks to hack3r2K |
The Following User Says Thank You to IM8 For This Useful Post: |
03-03-2017, 11:56 | #13589 (permalink) |
Freak Poster Join Date: Jul 2013 Location: Romania
Member: 1979249 Status: Online Thanks Meter: 63 | Allview P41 Emagic (MT 6580 FRP reset done) Select Wiko Lenny 2 --- Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM52)) Preparing to start flash mode; Preparing to open COM52 Connecting; Downloading DA; Initializing; Rid: 6cac82e9269930e3a5e531b65ec34da3 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem325.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM53; DEVICE INFO: BB CHIP: MT6580_S00 [CA00, 00, 6580, FF] HW_STORAGE_EMMC: 0x46000115 0x4D323237 0x035A0042 0xDF938FD2 [SIZE=0x1D2880000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x59800000 SIZE: 0x60000000 Factory Reset Protection successfully removed ! Time needed - 00:00:00 |
The Following User Says Thank You to Lvrajal For This Useful Post: |
03-04-2017, 17:31 | #13590 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Alcatel 4060A Unlocked ... Preparing to enter download mode; Preparing to open COM482 Connecting; Init; Port opened; Phone detected (@oem3.inf,%qcomdevice90080%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM20 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD IMEI: 01480200000AAA-8 PTH: 07 PTS: M5R PROV_ID: 4060A-2AAQUS3-R1 SBTADDR: 24:0D:C2:22:3A:AD SWIFIADDR: 24:0D:C2:2C:C2:09 HS_PN: SAA1GY0WA10C SSN: 48KB09BEUMAAAHT Work id: 080FF53D Done; SECURITY: X1M0UA04CL10 Size: 000002E2 Backup saved to: 01480200000AAA-8 Backup file(s) removed; Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_4_03_2017_14_33_28.txt Time needed - 00:01:59 |
The Following User Says Thank You to razib143 For This Useful Post: |
