10-17-2009, 17:32 | #1366 (permalink) |
No Life Poster Join Date: Mar 2001 Location: ALBANIA(Tirana) Age: 51
Member: 3617 Status: Offline Thanks Meter: 579 | Blackberry 8900 Tmobile Usa Reading info ... IMEI: 358453021519003 Calculating ... MEP: MEP-04104-007 MEP2 CODE: 3832846305757090 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:13 |
10-18-2009, 08:17 | #1367 (permalink) |
Freak Poster Join Date: Mar 2008 Location: I Don,t Know Age: 38
Member: 718939 Status: Offline Thanks Meter: 90 | AgAin KP501 UNLock DONE Press power on ! Starting communication ... Platform: S-Gold3 ... Preloader sent .... Loader sent .... CODE: 00491401 Power on phone with original sim. Type 2945#*71001# and enter code. Done ! Time needed - 00:00:15 |
10-18-2009, 10:08 | #1368 (permalink) |
No Life Poster Join Date: Apr 2009 Location: lebanon Age: 37
Member: 1008455 Status: Offline Sonork: 0000 Thanks Meter: 99 | woooow Press power on ! Start auth ! SW Ver: P1.2JD01V01.04:ULC2GL Imei: 353081032746888 PhoneLock Reset success ! Unlocked ! Done ! Time needed - 00:00:19 ---------------------------------------- Press power on ! Start auth ! SW Ver: P1.2JD01V01.03:ULC2GL Imei: 358545028817098 PhoneLock Reset success ! Unlocked ! Done ! Time needed - 00:00:05 --------------------------------------- Press power on ! Start auth ! SW Ver: P1.2JD02V01.01 Imei: 358832025120829 PhoneLock Reset success ! Unlocked ! Done ! Time needed - 00:00:10 |
10-18-2009, 12:52 | #1369 (permalink) |
No Life Poster Join Date: Nov 2006 Location: *P*A*K*I*S*T*A*N
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | STORM unlocked Searching for usb device ... Reading info ... IMEI: 355xxxxxxxx Calculating ... MEP: MEP-15326-002 MEP2 CODE: 99418982 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:18 |
10-18-2009, 12:59 | #1370 (permalink) |
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | ALCATEL E810X unlocked Press power on ! Starting communication ... Authorisation passed ... Sending boot ... Sending EBOLA ViruS ! Phone infected. RSA Defeated ! Loader version: FuriouSTeaM GSM DEVELOPEMENT Trying baud rate change ... Baud rate changed ok ! FLASH 1 ID: 0001:227E 0201 MODE: E801/C64/E805 MCU ID: 0C32592C201602B7 ALGO TYPE: FF OTP IMEI: 359828000818782 PROVIDER: E801X-2ARGGB1 FW INFO: 71DBAC0107 CODES: NCK: 6722320508 RESET: 1273528969 Operation completed. Phone reseted ! |
10-18-2009, 13:27 | #1371 (permalink) |
Member: 718939 Status: Offline Thanks Meter: 90 | AgAiN BlAcK BeRRy 9500 uNlOCk DONE Searching for usb device ... Reading info ... IMEI: 359484022092566 Calculating ... MEP: MEP-06814-004 MEP2 CODE: 0793660229434813 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:12 |
10-19-2009, 09:48 | #1372 (permalink) |
No Life Poster Join Date: Dec 2005 Location: RIFF-XILINX
Member: 214827 Status: Offline Sonork: 100.1597158 Thanks Meter: 59 | WS-S1 unlock ok Software engine version: 1.0.0.3071 Searching phone ... MODEL : QCOM SERIES 2 COMPILED DATE : Oct 18 2007 02:01:00 RELEASE DATE : Aug 10 2007 08:00:00 FIRMWARE INFO : M6260A-KYRZ-2.1.3022 IMEI : 35776701300498-4 BLUETOOTH ADDR : 85 99 3A 40 12 00 MEMORY ID : 00AD:0036 MEMORY NAME : hynix_hycosehomf3p MEMORY INFO : 0200:0020:06BD INIT NAND ROUTINES; NAND INIT MADE; PROCESS STARTED; READING; ERASING; WRITING; RESET ! Time needed - 00:00:07 Unlock OK, with Furious........ work perfect THX Furious Team... BR |
The Following User Says Thank You to v11 For This Useful Post: |
10-19-2009, 10:05 | #1373 (permalink) |
No Life Poster Join Date: Apr 2007 Location: SL3 LBF IN Kamoke(Gujranwala)
Member: 481915 Status: Offline Sonork: 100.1604233 Thanks Meter: 476 | LG KU990i successfull unlocked and complete help LG KU990i successfull unlocked Note: 1- before unlock process read nvm and save it for emergency signal problem after unlock 2- by using pack5 do unlock and middle in process phone will restart automatically during 30 seconds 3- next a message will appear and phone restart again, this time phone will not power on complete still on usb charging battery signal blooming in middle of screen 4- mannually press power on button few seconds to show insert sim, in this condition phone should free of keypad lock - now press OK for next process, all will be done here is log: Software engine version: 1.0.0.3071 Searching phone ... MODEL : KU990i COMPILED DATE : Mar 22 2009 14:51:00 RELEASE DATE : Mar 12 2009 17:00:00 FIRMWARE INFO : KU990i-MSM6280-V10c-MAR-12-2009-XX IMEI : 357121031xxxxx-x BLUETOOTH ADDR : FF 6A 50 E5 25 00 MEMORY ID : 0098:00CA MEMORY NAME : toshiba_tya000bc00bogg MEMORY INFO : 0800:0040:06C3 LOADING INIT DATA; RESETTING PHONE ! WAITING FOR PHONE TO POWER ON 30 SEC; PHONE ONLINE; SW VERSION: [OK] Invalid Module Software Version IMEI: [OK] 357121031xxxxxx BLUETOOTH ADDR: [OK] 0025E5506AFF PLAYING MUSIC ... WAIT; DOING CONFIG; NAND INIT MADE; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:02:51 screen shot: http://i583.photobucket.com/albums/s...0iunlocked.jpg mianlinks |
10-19-2009, 10:12 | #1374 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Professional Mobile Unlocker Age: 41
Member: 617174 Status: Offline Sonork: 100.1622609 Thanks Meter: 579 | Software engine version: 1.0.0.3071 Searching phone ... MODEL : U310 COMPILED DATE : Oct 12 2006 14:55:00 RELEASE DATE : May 9 2006 17:00:00 FIRMWARE INFO : U310-MSM6250A-V10a-OCT-12-2006-H3G-IT IMEI : 35281801155010-9 BLUETOOTH ADDR : 21 69 5B A1 19 00 MEMORY ID : 0098:0076 MEMORY NAME : toshiba_ty90009800cogg MEMORY INFO : 0200:0020:0900 LOADING INIT DATA; RESETTING PHONE ! WAITING FOR PHONE TO POWER ON 30 SEC; PHONE ONLINE; SW VERSION: [OK] MODULE ERROR IMEI: [OK] 35281801155010900 BLUETOOTH ADDR: [OK] 21695BA11900 PLAYING MUSIC ... WAIT; DOING CONFIG; INJECTING VODKA; INJECTING JUICE; DRINKING; DANCING; STAT: ON NAND UNLOCK DONE; PROCESS STARTED; READING; ERASING; WRITING; READING; ERASING; WRITING; UNLOCKED ! Time needed - 00:02:15 |
The Following User Says Thank You to vodafoneserver For This Useful Post: |
10-19-2009, 11:03 | #1375 (permalink) |
Freak Poster Join Date: Feb 2009 Location: I LOVE PAKISTAN Age: 38
Member: 977491 Status: Offline Thanks Meter: 82 | 9500 storm unlock done. see report thanks furious team plz add more models of new security in pack 4. Searching for usb device ... Reading info ... IMEI: 3594840....29765 Calculating ... MEP: MEP-06814-004 MEP2 CODE: 4698770803513164 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:12 BR, themobileshop |
10-20-2009, 08:18 | #1377 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Bulgaria Asenovgrad Age: 42
Member: 239176 Status: Offline Sonork: 100.1602815 Thanks Meter: 851 | Searching for usb device ... Reading info ... IMEI: 354879018578939 Calculating ... MEP: MEP-12565-001 MEP2 CODE: 6401595462014560 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:11 |
10-21-2009, 08:17 | #1378 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Afghanistan Kabul
Member: 295886 Status: Offline Sonork: 100.1583369 Thanks Meter: 1,472 | KP170 unlocked successfully Press power on button ... Phone detected ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Requesting baudrate change ... Baudrate changed ... Flash ID(0): 0001:227E:3C00 Searching flash image ... Reading flash image ... Unlock finished ! Done ! Time needed - 00:01:02 |
10-21-2009, 08:25 | #1379 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Al-Ahsa Saudi Arabia Age: 35
Member: 253510 Status: Offline Sonork: 100.1672352 Thanks Meter: 3,534 | blackberry 8120 unlock done successfully unlock blackberry 8120 with furious gold::: here is screen shot::: regards m irfan khan linkdot GSM |
10-21-2009, 09:45 | #1380 (permalink) |
No Life Poster Join Date: Sep 2005 Location: -=HORIZON=-MobiSoft Rahwali GR Age: 38
Member: 181213 Status: Offline Sonork: 100.1586186 Thanks Meter: 201 | BB 9000 Mobilink unlocked Searching for usb device ... Reading info ... IMEI: 35????????????????? Calculating ... MEP: MEP-16472-001 MEP2 CODE: 1468272790394156 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:16 |
