Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > FuriousGold
FuriousGold FuriouS GOLD Support Area | Powered by FuriousTeam
Old 07-03-2017, 18:28   #13801 (permalink)
Member: 2382052
Thanks Meter: 1,511
ALCATEL 5056A UNLOCK DONE
Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ;
Phone detected (@oem84.inf,%qcomdevice90080%;Qualcomm HS-USB QDLoader 9008)
Preparing to start flash mode;
Preparing to open COM63
Connecting;
Loading;
Init;
Port opened;
Hello Received;
BOOT Loaded;
Getting config;
Getting mem info;
Found an eMMC memory 22CD
IMEI: 01460800369601-4
PTH: 13
PTS: A4U
PROV_ID: 5056A-2GRGDO1-1
SBTADDR: 4C:4E:03:8B:53:33
SWIFIADDR: 4C:4E:03:CA:8A:69
HS_PN: SAA1F51WA10C
SSN: L3KC09CO1HA001K
Work id: 08A0ABED
Done;
Stype: 00000001
SECURITY: XHA0NJ04BR10 Size: 000002B1
Backup saved to: 01460800369601-4
Unlocking;
SIM_LOCK REMOVED !
Log file saved to: LOG_3_07_2017_13_26_08.txt
Time needed - 00:00:46
Old 07-03-2017, 21:49   #13802 (permalink)
Member: 2382052
Thanks Meter: 1,511
ZTE Z221 UNLOCK DONE
Software engine version: 1.0.0.10517
Searching phone ...
MODEL : QCOM SERIES 10
COMPILED DATE : Aug 8 2011 19:45:00
RELEASE DATE : Apr 19 2011 08:00:00
FIRMWARE INFO : ATT_AM_P671B40V1.0.0B09-S
IMEI : 86380601866880-2
BLUETOOTH ADDR : 47 A5 DA 81 E0 8C
INIT NAND ROUTINES;
NAND INIT MADE;
PHONE CODE: 0000
READING;
CALCULATING;
BEFORE BACKUP: 0D0A2225DBA14CB738A8889040C1E0E9.bin
ERASING;
WRITING;
READING;
AFTER BACKUP: F463B9ABAEE7EA22D755811B2614650B.bin
UNLOCKED;
RESET !
Log file saved to: LOG_3_07_2017_16_47_46.txt
Time needed - 00:00:07
Old 07-04-2017, 08:25   #13803 (permalink)
mishiko_gsm's Avatar
Member: 85537
Thanks Meter: 66
lenovo beeline pro 6 frp done
i removed frp beeline pro 6 ,in software i choice lenovo vibe .
Using library Brom_DLL_v7.1522.2
Searching phone in normal mode;
[connect the phone powered off to the usb cable]
Phone detected (MediaTek PreLoader USB VCOM (Android) (COM9))
Preparing to open COM9
Connecting;
Downloading DA;
Initializing;
Rid: 005de7b37eaefbe4a2d7b9fad8e2711b
Requesting baudrate change;
Done;
USB SPEED: USB_HIGH_SPEED
Switching to DA_HIGHSPEED_VCOM;
Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86;
If the detection fails, install manually the port from the device manager using usbvcom.inf;
DA_HIGHSPEED_VCOM (@oem297.inf,%vcom_da%;MediaTek DA USB VCOM (Android))
TRYING TO OPEN COM11;
DEVICE INFO:
BB CHIP: MT6735M_S00 [CA00, 00, 335, FF]
HW_STORAGE_EMMC: 0x46000115 0x4D32584E 0xC0640142 0x71141ED4 [SIZE=0x1D2880000]
IMEI1 [OTP 0000]: 000000-00-000000-0
IMEI2 [OTP 0000]: 000000-00-000000-0
PROVIDER: N/A
USRDATA INFO: 0x99000000 SIZE: 0x39880000
Factory Reset Protection successfully removed !
Time needed - 00:00:00
thanks furious team.
The Following 2 Users Say Thank You to mishiko_gsm For This Useful Post:
Old 07-04-2017, 15:04   #13804 (permalink)
Member: 2382052
Thanks Meter: 1,511
ALCATEL TRU 5065N FRP DONE
Phone detected (@oem408.inf,%qcdownloaddiag%;Qualcomm HS-USB QDLoader 9008)
Preparing to open COM122
Connecting;
Loading;
Init;
Port opened;
Hello Received;
BOOT Loaded;
Getting config;
Getting mem info;
IMEI: 01470500018345-7
PTH: 02
PTS: N5Q
PROV_ID: 5065N-2CE4US1
SBTADDR: 20:A9:0EB:63:C0
SWIFIADDR: 20:A9:0E7:E1:3D
HS_PN: SAA34NBAA10C
SSN: 98KJ09CQ7KZ04L9
Work id: 02379981
Done;
Stype: 00000001
SECURITY: X8C0LS01BR20 Size: 000002A5
Backup saved to: 01470500018345-7
Unlocking;
SIM_LOCK REMOVED !
FRP has been Reset Successfully;
Erase Setup Done;
Erase Done;
FRPEx Done;
Log file saved to: LOG_4_07_2017_10_01_05.txt
Time needed - 00:01:08
Old 07-04-2017, 15:55   #13805 (permalink)
jesedavidfrv's Avatar
Member: 914317
Sonork: 100.1601159
Thanks Meter: 66
5056n unlocked done!!
connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ;
phone detected (@oem122.inf,%qcomdevice90010%;alcatel hs-usb diagnostics 9001)
preparing to enter download mode;
preparing to open com506
connecting;
init;
port opened;
phone detected (@oem161.inf,%qcomdevice90080%;qualcomm hs-usb qdloader 9008)
preparing to start flash mode;
preparing to open com227
connecting;
loading;
init;
port opened;
hello received;
boot loaded;
getting config;
getting mem info;
found an emmc memory 22cd
imei: 01465000xxxx99-9
pth: 08
pts: B6g
prov_id: 5056n-2atbus7
sbtaddr: Cc:fd:17:5f:0e:cb
swifiaddr: Cc:fd:17:4c:8c:a7
hs_pn: Saa1f5bwa10c
ssn: N6kb11cb3pz005q
bruteforcing data; this operation can take up to 30 minutes !!!
Done;
work id: 09499a5d
done;
stype: 00000001
security: Xub0up02br10 size: 000002c3
backup saved to: 01465000xxxx99-9
unlocking;
sim_lock removed !
Log file saved to: Log_4_07_2017_09_46_00.txt
time needed - 00:15:23
Old 07-05-2017, 19:03   #13806 (permalink)
Member: 2382052
Thanks Meter: 1,511
ALCATEL 2001A UNLOCK DONE
Using library Brom_DLL_v5.1316.1
Searching phone;
(for some models keep SPACE or * (STAR) key pressed before inserting the cable)
Phone detected (MediaTek USB Port (COM936))
Preparing to start meta mode;
Requesting authorization;
Done;
Meta mode entered;
Baseband Chip: MT6250
Sw version: MAUI.11B.W12.24.MP.V2.F42
Hw Version: JRDHZ50_12864_11B_24MP_HW
Reading phone info;
IMEI: 013765-00-160355-7
Reading security;
Done;
Checking;
Preparing;
Writing security;
Phone unlocked; Remove battery and cable;
Time needed - 00:00:27
Log file saved to: LOG_5_07_2017_13_56_02.txt
Old 07-05-2017, 21:18   #13807 (permalink)
Member: 2382052
Thanks Meter: 1,511
ALCATEL 4060O FRP UNLOCK DONE
Connecting;
Loading;
Init;
Port opened;
Hello Received;
BOOT Loaded;
Getting config;
Getting mem info;
IMEI: 01467100105588-0
PTH: 06
PTS: A45
PROV_ID: 4060O-2ARKUS3
SBTADDR: 28:BE:03:293:F8
SWIFIADDR: 28:BE:03:2D:F5:B3
HS_PN: SAA1GN0WA10C
SSN: 96KB06CIQKZ04VL
Bruteforcing data; This operation can take up to 30 minutes !!!
Done;
Work id: 06D4C3BD
Done;
Stype: 00000001
Backup saved to: 01467100105588-0
Unlocking;
SIM_LOCK REMOVED !
Log file saved to: LOG_5_07_2017_16_10_07.txt
Time needed - 00:25:18
Old 07-05-2017, 22:05   #13808 (permalink)
Member: 2382052
Thanks Meter: 1,511
ALCATEL 6045O UNLOCK DONE
Software engine version: 1.0.0.10516
Searching phone ...
MODEL : QCOM SERIES 46
COMPILED DATE : Oct 28 2015 16:23:00
RELEASE DATE : Aug 31 2015 03:00:00
FIRMWARE INFO : MPSS.DPM.2.0.2.c1.6-00022-M8936FAAAANUZM-1.26298.1.28320.1
IMEI : 01449700227612-1
BLUETOOTH ADDR : 00 00 00 00 00 00
DONE;
WORKING;
SAVED: 69D9571DD0145322E30500E3219E7287.bin
UNLOCK CODE: N/A
DONE;
DOING EXTRA CALCULATION;
AFTER UNLOCK YOU MUST RESTART THE PHONE MANUALLY;
RESET !
Log file saved to: LOG_5_07_2017_17_04_12.txt
Time needed - 00:00:50
Old 07-06-2017, 00:44   #13809 (permalink)
Member: 642071
Thanks Meter: 54
Y625 unlock done
Software engine version: 1.0.0.10485
Searching phone ...
MODEL : QCOM SERIES 42
COMPILED DATE : May 14 2015 09:22:00
RELEASE DATE : Mar 4 2015 22:00:00
FIRMWARE INFO : 8x10_PL190335_20141120
IMEI : 86634?*********
DONE;
FIRMWARE: Y625-U13V100R001C54B100
SN: T6ZBBBB562502059
IMEI: 86634002300501-3
REQUESTING AUTH;
CALCULATING;
AUTH DONE;
SIM_LOCK REMOVED !
AFTER UNLOCK YOU MUST POWER OFF/ON THE PHONE MANUALLY;
Log file saved to: LOG_5_07_2017_18_27_40.txt
Old 07-06-2017, 14:25   #13810 (permalink)
Member: 2351647
Thanks Meter: 37
Cool Unlock Alcatel 9001D frp with furiousgold
.:hack3r2k:. thanks bro
Phone detected (@usb.inf,%usb\composite.devicedesc%;Périphérique USB composite)
Preparing to enter download mode;
Preparing to open COM53
Connecting;
Init;
Port opened;
Phone detected (@oem146.inf,%qcomserialportdesc90080%;Android HS-USB QDLoader 9008)
Preparing to open COM15
Connecting;
Loading;
Init;
Port opened;
Hello Received;
BOOT Loaded;
Getting config;
Getting mem info;
IMEI: 358344071264*****
PTH: 09
PTS: D25
PROV_ID: 9001D-2AALWE1
SBTADDR: CC:FD:172:92:85
SWIFIADDR: CC:FD:17:E4:E2:14
HS_PN: SAA1FA2AA10C
SSN: A4KE15COLEA00B7
Done;
Work id: 060B978C
Done;
Stype: 00000001
SECURITY: XMD0L502BR00 Size: 000002A5
Backup saved to: 358344071264****
Unlocking;
SIM_LOCK REMOVED !
Erase Setup Done;
Erase Done;
Erase Done;
Erase Done;
FRPEx Done;
Log file saved to: LOG_6_07_2017_09_57_05.txt
Time needed - 00:27:31
Old 07-07-2017, 09:00   #13811 (permalink)
Member: 1957238
Thanks Meter: 80
be mobie m103 made by zest unlock done by writing patched firmware with furious gold spd tool pack 2
thamks furious g box
Old 07-08-2017, 04:21   #13812 (permalink)
Member: 2250932
Sonork: pktech
Thanks Meter: 92
Thumbs up ALCATEL ONETOUCH 10:16 - Network Unlocking By SPD SERVICE TOOL
Old 07-08-2017, 15:09   #13813 (permalink)
2201's Avatar
Member: 2639338
Thanks Meter: 133
Samsung gt e1205y sim lock removed
Here is a full Log of operation
Searching phone;
For an successful connection do the following:
1. Remove battery and usb cable
2. Insert the usb cable in the phone
3. Keep pressed the boot key and insert the battery
Phone detected (@oem18.inf,%dc_diag%;SPRD U2S Diag)
Preparing to sync;
Port opened [COM48];
Mobile type: SPRD3
Connected;
Starting;
FDL sent;
Syncing;
Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT
Chip type: 6530 FdlStat: C000
Starting auth;
HW IMEI : 000000-00-000000-0
Memory [CS0]: 00C8:0060:0017 - SIZE : 00800000
Reading phone info;
PHONE INFO: GT-E1205ZKYKEN
PHONE SN: R21F61Y8N9
MSL PASS: 4839063F3D435D2E54184C512E295332
BT ADDR: FF:FF:FF:FF:FF:FF
SW IMEI[0]: FURIOUSTHEBESTTEAM
SW IMEI[1]: FURIOUSTHEBESTTEAM
SW IMEI[2]: FURIOUSTHEBESTTEAM
SW IMEI[3]: FURIOUSTHEBESTTEAM
SIMLOCK FLAG: ON
FIXED NV BASE: 30750000
Reading NV;
NV saved to : NV_000000-00-000000-0_FURIOUSTHEBESTTEAM_6530C000_1_01_2002_00_29_09.s pd
Calculating ...
Freeze code: 37920317
NET lock: 68695851
Sub lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
Re-programming;
NV programmed;
Done;
Old 07-08-2017, 16:37   #13814 (permalink)
Member: 2382052
Thanks Meter: 1,511
ALCATEL 5065N UNLOCK DONE
Connecting;
Loading;
Init;
Port opened;
Hello Received;
BOOT Loaded;
Getting config;
Getting mem info;
IMEI: 01470500032342-6
PTH: 03
PTS: N5Q
SBTADDR: 20:A9:0E:E1:64:90
SWIFIADDR: 20:A9:0E:E3:12:40
HS_PN: SAA34NBAA10C
SSN: 98KJ09CQCKZ00S3
Work id: 0237AED8
Done;
Stype: 00000001
SECURITY: X2N0UP00CL10 Size: 000002C3
Backup saved to: 01470500032342-6
Unlocking;
SIM_LOCK REMOVED !
Log file saved to: LOG_7_07_2017_23_32_50.txt
Time needed - 00:00:54
Old 07-09-2017, 12:27   #13815 (permalink)
gayansuranga's Avatar
Member: 230004
Thanks Meter: 174
Searching phone...
(insert the USB cable in the powered off phone)
Phone detected (MediaTek PreLoader USB VCOM Port)
Preparing to start MTK debug mode;
Searching for debug port... (be sure drivers from support were installed!)
MTK debug mode entered
Baseband Chip: MT6735M,S01
Sw version:
Hw Version: ALPS.L1.MP3.V2.95_OT6735M.35GU.L1_P91
Baseband Chip: MT6735, E00
Sw version: MOLY.LR9.W1444.MD.LWTG.MP.V48.P8
Hw Version: OT6735_65C_LU_L1_HW
Reading info...
IMEI 1: 869821021307268
IMEI 2: N/A
Open port success!
2017-07-09 16:44:55.622 Reading data from server...
2017-07-09 16:44:56.325 Reading data from server success!
Reading simlock info;
Gathering info;
SIM UNLOCK CODE: 07156117
Simlock read end;
yes good job FG
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.37430 seconds with 11 queries
