08-24-2017, 01:22 | #13906 (permalink) |
Freak Poster Join Date: Feb 2015 Location: guyane francaise
Member: 2351647 Status: Offline Thanks Meter: 37 | alcatel ot-7048X unlock ok Phone detected (@usb.inf,%usb\composite.devicedesc%;Périphérique USB composite) Preparing to enter download mode; Preparing to open COM70 Connecting; Init; Port opened; Phone detected (@oem185.inf,%qcomdevice90080%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM45 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22D4 IMEI: 8670230213949**** PTH: 07 PTS: FML PROV_ID: 7048X-2CALWE7 SBTADDR: 18:E3:BC1:B60 SWIFIADDR: 18:E3:BC1:B61 HS_PN: SAA64HAABJ1C SSN: 5WKB26BCKFZ00ID Work id: 19B3F825 Setup 1; Done; Setup 2; Done; Setup 3; Done; Uploading; Done; SECURITY: X7FMAZL4BQ00 Size: 00000430 Backup saved to: 86702302139491-5 Checking the simlock; Magic ok; ERROR: SIM_LOCK not enabled; FRP has been Reset Successfully; Erase Setup Done; Erase Done; Erase Done; FRPEx Done; |
08-24-2017, 01:39 | #13907 (permalink) |
Member: 2351647 Status: Offline Thanks Meter: 37 | alcatel ot-5056D unlock frp ok Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem185.inf,%qcomdevice90080%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM45 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD IMEI: 356999071164***** PTH: 12 PTS: A4F PROV_ID: 5056D-2JALWE1 SBTADDR: 20:A9:0E:00:39:81 SWIFIADDR: 20:A9:0E:04:A51 HS_PN: SAA1F52WA10C SSN: J2KC04BQ4IZ0204 Work id: 05349E6B Done; Stype: 00000001 SECURITY: XHA0L501BR20 Size: 000002A5 Backup saved to: 35699907116473-8 Unlocking; SIM_LOCK REMOVED ! FRP has been Reset Successfully; Erase Setup Done; Erase Done; Erase Done; Erase Done; FRPEx Done; Log file saved to: LOG_23_08_2017_21_36_47.txt |
08-24-2017, 14:52 | #13908 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | blu zoey tt166 unlock done Using library Brom_DLL_v5.1316.1 Searching phone; (for some models keep SPACE or * (STAR) key pressed before inserting the cable) Phone detected (MediaTek USB Port (COM37)) Preparing to start meta mode; Meta mode entered; Baseband Chip: MT6260 Sw version: MAUI.11B.W13.08.MP.V1.F11 Hw Version: 60M_11B_HW Reading phone info; IMEI: 359686-05-537086-3 Reading security; Done; Checking; Preparing; Writing security; Phone unlocked; Remove battery and cable; Time needed - 00:00:08 Log file saved to: LOG_24_08_2017_09_50_29.txt |
08-24-2017, 17:17 | #13909 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Preparing to enter download mode; Preparing to open COM366 Connecting; Init; Port opened; Phone detected (@oem274.inf,%qcomdevice90080%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM17 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD IMEI: 014699004AAAA4-6 PTH: 04 PTS: M5K PROV_ID: 4060A-2AAQUS3-R1 SBTADDR: 28:BE:03:0D:B3:2B SWIFIADDR: 28:BE:03:27:B2:EC HS_PN: SAA1GY0WA10C SSN: 48KB08CCKKZ054P Work id: 061B1228 Done; Stype: 00000001 SECURITY: X1M0UA02CL10 Size: 000002D4 Backup saved to: 014699004AAAAA4-6 Backup file(s) removed; Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_24_08_2017_16_15_44.txt Time needed - 00:01:12 |
08-25-2017, 09:36 | #13910 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | Model: HUAWEIH1611 IMEI: 861384030158170 SUB_IMEI: 861384030158170 Firmware ver.: MSM8939C07B130_AMSS Aug 31 201601:39:55 SN: A9M0216830009820 Custom SN: 023XQB168S004641 WiFi MAC: 8C:EB:C60:89:57 BlueTooth MAC: 8C:EB:C60:91:28 Vendor: att Country: us SL: 00000000 H1611C07B130_BOOT MSM8939C07B130_AMSS Aug 31 201601:39:55 H1611_C00B013_EFS_RFNV_B08 HL1H1611M H1611C07B130_APPSBOOT H1611C07B130_KERNEL H1611C07B130_SYSTEM H1611C07B130_RECOVERY MSM8939 HUAWEI H1611 C07 D130 MSM8939_H1611_ IMEI 1 Sim Lock status: NET: locked, unlock retry counts: 10 NETSUB: unlocked SP: unlocked 2017-08-25 10:31:48.329 Autodetect started! 2017-08-25 10:31:49.160 Found COM port: COM365 2017-08-25 10:31:49.167 Open port COM365 (DBAdapter Reserved Interface (COM365))... 2017-08-25 10:31:49.275 Connecting to server... 2017-08-25 10:31:49.860 Connected! 2017-08-25 10:31:49.865 Read data from server... 2017-08-25 10:31:51.432 Read data from server success! 2017-08-25 10:31:51.614 Phone authorize start 2017-08-25 10:31:52.266 Phone authorize success! 2017-08-25 10:31:52.273 Read secure info... 2017-08-25 10:31:52.589 Read secure info success! 2017-08-25 10:31:52.594 Read basic info... 2017-08-25 10:31:52.664 Read basic info success! 2017-08-25 10:31:52.669 Unlocking start 2017-08-25 10:31:53.681 Read data from server... 2017-08-25 10:31:56.465 Read data from server success! 2017-08-25 10:31:56.468 Writing security data... 2017-08-25 10:31:56.731 Write security data success! 2017-08-25 10:31:56.898 Unlock done! 2017-08-25 10:31:56.910 Job finished! |
08-25-2017, 13:35 | #13911 (permalink) |
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | Model: PRA-LX1 IMEI: 862550035040857 Firmware ver.: PRA-LX1C432B106 SN: 9DCDU17222000094 IMEI1:862550035069187 FB LockState: LOCKED USER LockState: LOCKED locked Battery state: 2081mv 2017-08-25 14:32:23.797 Erase FRP start 2017-08-25 14:32:27.262 Reading phone info... 2017-08-25 14:32:27.722 Read phone info success! Model: PRA-LX1 IMEI: 862550035040857 Firmware ver.: PRA-LX1C432B106 SN: 9DCDU17222000094 2017-08-25 14:32:27.757 Reading Certify data... 2017-08-25 14:32:27.916 Reading Certify data success! 2017-08-25 14:32:27.922 Signing Certify data... 2017-08-25 14:32:29.819 Erase FRP done! |
08-26-2017, 08:55 | #13912 (permalink) |
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | Model: HUAWEI SCL-L01 Firmware ver.: SCL-L01C150B140 SN: NQL7N15B05000489 FB LockState: LOCKED widevine LockState: LOCKED Bootloader Lock State: LOCKED Root State: UNROOT Bootloader WidevineKey: WidevineKey_VALID System State: need to verify Boot image need to be verified Recovery image need to be verified Bootloader Version: 001.001.000 Battery state: 3790mv 2017-08-26 09:49:39.886 Erase FRP start 2017-08-26 09:49:44.375 Reading phone info... 2017-08-26 09:49:44.834 Read phone info success! Model: HUAWEI SCL-L01 Firmware ver.: SCL-L01C150B140 SN: NQL7N15B05000489 2017-08-26 09:49:44.862 Reading Certify data... 2017-08-26 09:49:45.020 Reading Certify data success! 2017-08-26 09:49:45.026 Signing Certify data... 2017-08-26 09:49:48.124 Erase FRP done! |
08-26-2017, 12:15 | #13913 (permalink) |
Freak Poster Join Date: Dec 2015 Location: ghana
Member: 2499853 Status: Offline Thanks Meter: 34 | Huawei vns-l31 unlock done THANK YOU FURIOUS GLOD 2017-08-26 11:09:33.397 Autodetect started! 2017-08-26 11:09:34.086 Found COM port: COM246 2017-08-26 11:09:34.092 Open port COM246 (Android Adapter PCUI (COM246))... 2017-08-26 11:09:34.199 Connecting to server... 2017-08-26 11:09:35.203 Connected! 2017-08-26 11:09:35.228 Read data from server... 2017-08-26 11:09:36.848 Read data from server success! 2017-08-26 11:09:37.200 Phone authorize start 2017-08-26 11:09:41.991 Phone authorize success! 2017-08-26 11:09:41.997 Read secure info... 2017-08-26 11:09:50.848 Read secure info success! 2017-08-26 11:09:50.854 Read basic info... 2017-08-26 11:09:54.576 Read basic info success! 2017-08-26 11:09:54.583 Unlocking start 2017-08-26 11:09:54.591 Phone secure identify start 2017-08-26 11:09:58.521 Phone secure identify success! 2017-08-26 11:09:58.529 Reading data from server... 2017-08-26 11:09:59.026 Reading data from server success! 2017-08-26 11:10:00.137 Unlock done! 2017-08-26 11:10:00.142 Job finished! |
08-26-2017, 12:21 | #13914 (permalink) |
Member: 2499853 Status: Offline Thanks Meter: 34 | HUAWEI VNS-L31 UNLOCK DONE 2017-08-26 11:09:33.397 Autodetect started! 2017-08-26 11:09:34.086 Found COM port: COM246 2017-08-26 11:09:34.092 Open port COM246 (Android Adapter PCUI (COM246))... 2017-08-26 11:09:34.199 Connecting to server... 2017-08-26 11:09:35.203 Connected! 2017-08-26 11:09:35.228 Read data from server... 2017-08-26 11:09:36.848 Read data from server success! 2017-08-26 11:09:37.200 Phone authorize start 2017-08-26 11:09:41.991 Phone authorize success! 2017-08-26 11:09:41.997 Read secure info... 2017-08-26 11:09:50.848 Read secure info success! 2017-08-26 11:09:50.854 Read basic info... 2017-08-26 11:09:54.576 Read basic info success! 2017-08-26 11:09:54.583 Unlocking start 2017-08-26 11:09:54.591 Phone secure identify start 2017-08-26 11:09:58.521 Phone secure identify success! 2017-08-26 11:09:58.529 Reading data from server... 2017-08-26 11:09:59.026 Reading data from server success! 2017-08-26 11:10:00.137 Unlock done! 2017-08-26 11:10:00.142 Job finished! |
08-26-2017, 17:17 | #13915 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | alcatel 5044r frp and unlock done Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem83.inf,%qcomdevice90080%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM219 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD IMEI: 01482700093236-8 PTH: 02 PTS: Y58 PROV_ID: 5044R-2AAQUS1-R1 SBTADDR: 4C:4E:03:C5:092 SWIFIADDR: 4C:4E:03:92:55:9F HS_PN: SAA1HQ0WA10C SSN: TCKC04CK4HA04MG Bruteforcing data; This operation can take up to 30 minutes !!! Done; Work id: 0A39CD44 Done; Stype: 00000001 SECURITY: XAY5UA80CL10 Size: 000002E2 Backup saved to: 01482700093236-8 Unlocking; SIM_LOCK REMOVED ! FRP has been Reset Successfully; Erase Setup Done; Erase Done; Erase Done; FRPEx Done; Log file saved to: LOG_26_08_2017_12_15_24.txt Time needed - 00:11:30 |
08-26-2017, 17:27 | #13916 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | alcatel 4060o unlock done Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem83.inf,%qcomdevice90080%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM219 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD IMEI: 01467100407665-1 PTH: 09 PTS: A45 PROV_ID: 4060O-2ARKUS3 SBTADDR: 4C:4E:03:CAA:35 SWIFIADDR: 4C:4E:03:87:5D:EE HS_PN: SAA1GN0WA10C SSN: 96KB08BA5HA01GD Bruteforcing data; This operation can take up to 30 minutes !!! Done; Work id: 066A73FD Done; Stype: 00000001 SECURITY: XYA0UC00BR10 Size: 000002BF Backup saved to: 01467100407665-1 Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_26_08_2017_12_25_46.txt Time needed - 00:07:28 |
08-28-2017, 12:08 | #13917 (permalink) |
No Life Poster Join Date: Apr 2011 Location: algerie Age: 54
Member: 1562854 Status: Offline Sonork: 1245 Thanks Meter: 259 | Tactile messaging cu unlocked Code: Software engine version: 1.0.0.10533 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Apr 8 2011 10:17:00 RELEASE DATE : Apr 13 2010 23:00:00 FIRMWARE INFO : ORG_FR_P671A80V1.0.0B18-S IMEI : 35635304012513-3 BLUETOOTH ADDR : CC 31 CA C7 64 C8 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; SP NEW DETECTED; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 208 MNC: 1) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Log file saved to: LOG_28_08_2017_11_04_52.txt |
08-28-2017, 22:11 | #13918 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | ALCATEL 5045A UNLOCK DONE Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM50)) Preparing to start flash mode; Preparing to open COM50 Connecting; Downloading DA; Initializing; Rid: c9b6da256656e7fa297213f1de152c22 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem81.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM89; DEVICE INFO: BB CHIP: MT6735M_S00 [CA00, 00, 335, FF] HW_STORAGE_EMMC: 0x484A0190 0x65314738 0x3A470705 0xB53478AC [SIZE=0x1D2C00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: 5045A-2ARGDO1 USRDATA INFO: 0xB7800000 SIZE: 0x1B400000 Searching data; Locked to [SIM1]: 370-01 code_cat_n: 0315037168090682 enabled: yes tries: 10 code_cat_ns: 9246139626937767 enabled: no tries: 10 code_cat_sp: 5216425390271190 enabled: no tries: 10 code_cat_c: 2327674908451254 enabled: no tries: 10 code_cat_sim: 9409919598990412 enabled: no tries: 10 code_cat_ns_sp: 8391823918787605 enabled: no tries: 5 code_cat_sim_c: 8313251747747286 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:07 Log file saved to: LOG_28_08_2017_17_09_11.txt |
08-29-2017, 09:52 | #13919 (permalink) |
Freak Poster Join Date: Oct 2008 Location: Romania/Piatra Neamt
Member: 880649 Status: Offline Thanks Meter: 73 | Huawei PRA-LX1 unlock ok 29.08.2017 11:36:29 FlyCaptain Huawei Module v2.0.0.0157 Furious Gold Pack 7 Dongle S/N: xxxxxxxxxxx Before detection connect cable to usb and enable Manufacture mode ! Qualcomm and HiSilicon: *#*#2846579#*#* MTK: *#*#14789632#*#* Windows: ##2846579# ProjectMenu 1.Background setting 2.USB ports setting Select Manufacture mode (for MTK other/debug mode) 2017-08-29 11:36:33.937 Autodetect started! 2017-08-29 11:36:35.359 Compatible COM ports not found! 2017-08-29 11:36:35.375 ERROR! Phone not found ! 2017-08-29 11:37:39.390 Autodetect started! 2017-08-29 11:37:40.812 Compatible COM ports not found! 2017-08-29 11:37:40.828 ERROR! Phone not found ! 2017-08-29 11:40:08.046 Autodetect started! 2017-08-29 11:40:09.296 ERROR! Phone not found ! 2017-08-29 11:41:00.578 Autodetect started! 2017-08-29 11:41:01.828 ERROR! Phone not found ! 2017-08-29 11:42:30.953 Autodetect started! 2017-08-29 11:42:33.015 Found COM port: COM537 2017-08-29 11:42:34.234 Start read phone info! 2017-08-29 11:42:34.234 Open port COM537 (Android Adapter PCUI (COM537))... 2017-08-29 11:42:35.390 Phone authorize start 2017-08-29 11:42:35.484 Connecting to server... 2017-08-29 11:42:36.406 Connected! 2017-08-29 11:42:36.406 Read data from server... 2017-08-29 11:42:38.406 Read data from server success! 2017-08-29 11:42:42.015 Phone authorize success! 2017-08-29 11:42:42.015 Read basic info... 2017-08-29 11:42:43.390 Read secure info... 2017-08-29 11:42:52.281 Detect phone done! Model: PRA-L11 MEID: 00000000000000 pESN: 00000000 IMEI: 865006032xxx IMEI 0: 000000000000000 IMEISV: 49 Firmware ver.: NRD90M test-keys SN: 57U7N17720000461 Custom SN: 7N4EWG177M061185 WiFi MAC: 5C:03:39:C4:FC:ED BlueTooth MAC: 5C:03:39:C5:06:E4 Vendor: vodafone Country: default FASTBOOT:Chipset-dallas 5.0.0.1(09Z4)_FASTBOOT BOOTallas-Release_B200_BOOT RECOVERYunknow) SYSTEM:System 5.0.0.57(0NSL) MAINVER:NRD90M test-keys DATAVER:PRA-LX1C02B149_DATA_PRA-L11_vodafone_default APTIME:Fri Jun 23 15:30:34 CST 2017 RAM: 3G eMMC: 16G IMEI 1 Sim Lock status: NET: locked, unlock retry counts: 10 NETSUB: unlocked SP: unlocked 2017-08-29 11:43:13.828 Autodetect started! 2017-08-29 11:43:17.890 Found COM port: COM537 2017-08-29 11:43:17.890 Open port COM537 (Android Adapter PCUI (COM537))... 2017-08-29 11:43:18.000 Connecting to server... 2017-08-29 11:43:18.937 Connected! 2017-08-29 11:43:18.953 Read data from server... 2017-08-29 11:43:21.031 Read data from server success! 2017-08-29 11:43:21.312 Phone authorize start 2017-08-29 11:43:25.250 Phone authorize success! 2017-08-29 11:43:25.265 Read secure info... 2017-08-29 11:43:34.093 Read secure info success! 2017-08-29 11:43:34.093 Read basic info... 2017-08-29 11:43:37.937 Read basic info success! 2017-08-29 11:43:37.937 Unlocking start 2017-08-29 11:43:37.937 Phone secure identify start 2017-08-29 11:43:40.937 Phone secure identify success! 2017-08-29 11:43:40.937 Reading data from server... 2017-08-29 11:43:41.468 Reading data from server success! 2017-08-29 11:43:42.703 Unlock done! 2017-08-29 11:43:42.703 Read bootloader code start 2017-08-29 11:43:47.234 Read bootloader code success! 2017-08-29 11:43:47.234 Job finished! Bootloader code 4538168368XXXXX |
08-29-2017, 15:58 | #13920 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Moldova
Member: 614304 Status: Offline Thanks Meter: 150 | Vodafone Smart Turbo 7 Unlock Done !!! Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (PreLoader USB VCOM Port (COM118)) Preparing to start flash mode; Preparing to open COM118 Connecting; Downloading DA; Initializing; Rid: f2dd255720ad0bef78f20dd0ac3f367f Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (DA USB VCOM Port) TRYING TO OPEN COM125; DEVICE INFO: BB CHIP: MT6735M_S00 [CA00, 00, 335, FF] HW_STORAGE_EMMC: 0x46000115 0x4D32584E 0x8B140642 0x8B343BF2 [SIZE=0x1D2880000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: V500-2AVDGB2 USRDATA INFO: 0x84000000 SIZE: 0x4E880000 Searching data; Locked to [SIM1]: 234-15 code_cat_n: 9654589826597762 enabled: yes tries: 8 code_cat_ns: 4957604761903047 enabled: no tries: 10 code_cat_sp: 9077146077025256 enabled: no tries: 10 code_cat_c: 2327674908451254 enabled: no tries: 10 code_cat_sim: 9409919598990412 enabled: no tries: 10 code_cat_ns_sp: 8391823918787605 enabled: no tries: 5 code_cat_sim_c: 8313251747747286 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:04 Log file saved to: LOG_29_08_2017_17_55_28.txt |
