06-09-2018, 17:06 | #14642 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,108 | HUAWEI SCL-L01 [SCL-L01C316B130] Erase FRP done! 6/9/2018 5:58:23 PM FlyCaptain Huawei Module v2.0.0.0174 Furious Gold Pack 7 Dongle S/N: 882575AC Before detection connect cable to usb and enable Manufacture mode ! Qualcomm and HiSilicon: *#*#2846579#*#* MTK: *#*#14789632#*#* Windows: ##2846579# ProjectMenu 1.Background setting 2.USB ports setting Select Manufacture mode (for MTK other/debug mode) 2018-06-09 17:58:36.891 Start read phone info! 2018-06-09 17:58:37.920 Detect phone done! Model: HUAWEI SCL-L01 Firmware ver.: SCL-L01C316B130 SN: NQL7N16121006843 FB LockState: LOCKED widevine LockState: LOCKED Bootloader Lock State: LOCKED Root State: UNROOT Bootloader WidevineKey: WidevineKey_VALID System State: need to verify Boot image need to be verified Recovery image need to be verified Bootloader Version: 001.001.000 Battery state: 4175mv 2018-06-09 17:59:06.843 Erase FRP start 2018-06-09 17:59:13.256 Reading phone info... 2018-06-09 17:59:13.835 Read phone info success! Model: HUAWEI SCL-L01 Firmware ver.: SCL-L01C316B130 SN: NQL7N16121006843 2018-06-09 17:59:13.850 Reading Certify data... 2018-06-09 17:59:14.037 Reading Certify data success! 2018-06-09 17:59:14.037 Signing Certify data... 2018-06-09 17:59:17.783 Erase FRP done!
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. |
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post: |
06-12-2018, 08:32 | #14643 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | WIKO K-KOOL DIRECT UNLOCK DONE [IMG]ttps://s22.postimg.cc/y8mhenn1d/screenshot_133.png[/IMG] Last edited by .:hack3r2k:.; 06-20-2018 at 12:58. |
The Following User Says Thank You to fokal2008 For This Useful Post: |
06-13-2018, 09:33 | #14644 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,691 | 5042x unlocked Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@usb.inf,%usb\composite.devicedesc%;USB Composite Device) Preparing to enter download mode; Preparing to open COM66 Connecting; Init; Port opened; Phone detected (@oem191.inf,%qcomdevice90080%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM29 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22D4 size 7.3 GB IMEI: 86528902268837-1 PTH: 03 PTS: CNH PROV_ID: 5042X-2STBAL3 SBTADDR: 948:59:41:FA:63 SWIFIADDR: 948:59:41:FA:64 HS_PN: SAA6150AA14C SSN: HPKE53BERJY004O Work id: 02F200BE Setup 1; Done; Setup 2; Done; Setup 3; Done; Uploading; Done; SECURITY: X2CNCBH2BG00 Size: 00000430 Backup saved to: 86528902268837-1 Checking the simlock; Magic ok; Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_13_06_2018_10_34_03.txt Time needed - 00:00:43 |
The Following User Says Thank You to genci titi 2002 For This Useful Post: |
06-13-2018, 14:05 | #14645 (permalink) |
No Life Poster Join Date: Sep 2007 Location: nigeria
Member: 581848 Status: Offline Thanks Meter: 119 | 5044R UNLOCKED WITHOUT ANY EDL CABLE ONLY USB FURIOUS GOLD REMAIN FASTEST IN UNLOCKING ..... Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@usb.inf,%usb\composite.devicedesc%;USB Composite Device) Preparing to enter download mode; Preparing to open COM67 Connecting; Init; Port opened; Phone detected (@oem53.inf,%qcomdevice90080%;ALCATEL HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM68 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD size 7.3 GB IMEI: 01482700489242-8 PTH: 05 PTS: Y5Y PROV_ID: 5044R-2AAQUS1-R1 SBTADDR: D4:285:90:E7:37 SWIFIADDR: D4:285:91:AB:23 HS_PN: SAA1HQ0WA10C SSN: TCKC06CICNA01N9 Work id: 22021984 Done; Stype: 00000001 SECURITY: XAY5UAY0CL10 Size: 000002E9 Backup saved to: 01482700489242-8 Unlocking; SIM_LOCK REMOVED ! |
The Following User Says Thank You to ramsey1976 For This Useful Post: |
06-13-2018, 19:45 | #14646 (permalink) |
Freak Poster Join Date: Feb 2015 Location: guyane francaise
Member: 2351647 Status: Offline Thanks Meter: 37 | reset frp alcatel idol5 ot-6058 ok Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM15)) Preparing to start flash mode; Preparing to open COM15 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 037bdaab1c63c9bf09f2550b79906a28 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem94.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM47; DEVICE INFO: BB CHIP: MT6753 [CA00, 00, 337, 05] HW_STORAGE_EMMC: 0x47000115 0x4D423645 0xE1C60342 0xA3945DCC [SIZE=0x3A4A00000] IMEI1 [OTP 0001]: 358473-08-052385-2 IMEI2 [OTP 0001]: 358473-08-052386-0 PROVIDER: 6058D-2BALWE7 USRDATA INFO: 0x121000000 SIZE: 0x27F280000 Factory Reset Protection successfully removed ! Time needed - 00:00:01 Log file saved to: LOG_13_06_2018_15_31_03.txt |
The Following User Says Thank You to techmania97 For This Useful Post: |
06-15-2018, 19:45 | #14647 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Roumania
Member: 691388 Status: Offline Thanks Meter: 371 | Software engine version: 1.0.0.10670 Searching phone ... MODEL : QCOM SERIES 48 COMPILED DATE : Sep 9 2017 02:01:00 RELEASE DATE : May 10 2017 19:00:00 FIRMWARE INFO : MPSS.JO.3.0-00291-8909_GEN_PACK-1.97872.1.98558.1 IMEI : 35784808032534-4 BLUETOOTH ADDR : 00 00 00 00 00 00 FIRMWARE: RO_MR1_VDF_P809V51V1.0.0B05 close_event_report: OK; close_log_report: OK; close_message_report: OK; closing_com_port: OK; Starting the backup process; connect_server: OK; backup in progress: OK; Backup saved to: G:\Program Files\FURIOUS-GOLD\PACK5\35784808032534_15_06_2018_21_40_30.bkp switching_download_mode: OK; closing_com_port: OK; Preparing to open COM311 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD Looking for the interface; Port found [ZTE Handset Diagnostic Interface (COM1)] connect_server: OK; restore in progress: OK; SIM_LOCK REMOVED ! Log file saved to: LOG_15_06_2018_21_43_36.txt Time needed - 00:03:09 |
The Following User Says Thank You to maremestera For This Useful Post: |
06-16-2018, 16:19 | #14648 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | ALCATEL 5099A UNLOCK DONE Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM94)) Preparing to start flash mode; Preparing to open COM94 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: c1f2f804196a6fe3b45ccde27f3ea135 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem88.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM95; DEVICE INFO: BB CHIP: MT6737T [CA00, 00, 321, 05] HW_STORAGE_EMMC: 0x51000115 0x4D333645 0xC7430342 0x1D841CE0 [SIZE=0x3A4A00000] IMEI1 [OTP 0000]: 015106-00-010020-4 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: 5099A-2CAVDO1 USRDATA INFO: 0xEE000000 SIZE: 0x2B2280000 Searching data; Locked to [SIM1]: 370-02 code_cat_n: 1782683822881636 enabled: yes tries: 5 code_cat_ns: 1782683822881636 enabled: no tries: 0 code_cat_sp: 1782683822881636 enabled: no tries: 0 code_cat_c: 1782683822881636 enabled: no tries: 0 code_cat_sim: 1782683822881636 enabled: no tries: 0 Phone unlocked; Remove battery and cable; Time needed - 00:00:05 Log file saved to: LOG_16_06_2018_11_17_46.txt |
The Following User Says Thank You to maxpatri9 For This Useful Post: |
06-16-2018, 16:25 | #14649 (permalink) |
No Life Poster Join Date: Mar 2011 Location: dominican republic Age: 45
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@usb.inf,%usb\composite.devicedesc%;Dispositivo compuesto USB) Preparing to enter download mode; Preparing to open COM1207 Connecting; Init; Port opened; Phone detected (@oem13.inf,%qcomserialportdesc90080%;Android HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM36 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD size 14,7 GB IMEI: 01450400008656-6 PTH: 16 PTS: D79 PROV_ID: 5054W-2BTBUS1-R SBTADDR: 18:E3:BC:0C:A7:C5 SWIFIADDR: 18:E3:BC:0C:A7:C6 HS_PN: SAA35HAAA10C SSN: 2VKF09CL8PY0100 Work id: 0353DB2D Done; Stype: 00000001 SECURITY: X8C0AB01BR10 Size: 000002A5 Backup saved to: 01450400008656-6 Unlocking; SIM_LOCK REMOVED ! FRP has been Reset Successfully; Erase Setup Done; Erase Done; FRPEx Done; Log file saved to: LOG_16_06_2018_11_22_22.txt Time needed - 00:00:28 |
The Following User Says Thank You to chipscell25 For This Useful Post: |
06-18-2018, 14:39 | #14650 (permalink) |
Product Supporter Join Date: Dec 2004 Location: Furious Team ... GPGIndustries Age: 45
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,045 | HUAWEI TAG-L01 FRP Remove Done Code: 2018-06-18 16:21:11.441 Erase FRP start 2018-06-18 16:21:14.804 Reading phone info... 2018-06-18 16:21:15.328 Read phone info success! Model: HUAWEI TAG-L01 Firmware ver.: TAG_L01C525B103 SN: 9JPBBCA6C0905281 2018-06-18 16:21:15.506 Reading Certify data... 2018-06-18 16:21:15.691 Signing certify data... 2018-06-18 16:21:16.076 Signing certify data success! 2018-06-18 16:21:16.076 Erasing FRP... 2018-06-18 16:21:25.223 Erase FRP done! |
The Following User Says Thank You to Fast Unlocker For This Useful Post: |
06-18-2018, 20:13 | #14651 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | ALCATEL 5099A UNLOCK DONE Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM94)) Preparing to start flash mode; Preparing to open COM94 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 708911e4e335425730cb234096b38368 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem88.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM95; DEVICE INFO: BB CHIP: MT6737T [CA00, 00, 321, 05] HW_STORAGE_EMMC: 0x51000115 0x4D333645 0x162B0342 0x73B45C07 [SIZE=0x3A4A00000] IMEI1 [OTP 0000]: 015106-00-016400-2 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: 5099A-2CRGDO1 USRDATA INFO: 0xEE000000 SIZE: 0x2B2280000 Searching data; Locked to [SIM1]: 370-01 code_cat_n: 1437155750357282 enabled: yes tries: 10 code_cat_ns: 1437155750357282 enabled: no tries: 0 code_cat_sp: 1437155750357282 enabled: no tries: 0 code_cat_c: 1437155750357282 enabled: no tries: 0 code_cat_sim: 1437155750357282 enabled: no tries: 0 Phone unlocked; Remove battery and cable; Time needed - 00:00:10 Log file saved to: LOG_18_06_2018_15_02_39.txt |
06-19-2018, 21:39 | #14652 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | ALCATEL 5049Z UNLOCK DONE Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off with volume down pressed to the usb cable] Phone detected (MediaTek USB Port (COM94)) Preparing to start flash mode; Preparing to open COM94 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: d2e471d25c6dc58f8f7d58151c864cf0 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem88.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM95; DEVICE INFO: BB CHIP: MT6738 [CB00, 01, 6738, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333158 0xE58C0742 0x25641DD4 [SIZE=0x748800000] IMEI1 [OTP 0001]: 014940-00-078487-7 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5049Z-2AE4US1 USRDATA INFO: 0x120000000 SIZE: 0x6240FBE00 Searching data; Checking server support license; Bruteforcing ... relax ;-) Buteforce took 00:11:18 Checking data integrity; Data integrity: OK; SIM_LOCK: ENABLED Rebuilding security; Phone unlocked; Remove battery and cable; Time needed - 00:11:22 Log file saved to: LOG_19_06_2018_16_36_53.txt |
06-19-2018, 21:58 | #14653 (permalink) |
Banned Join Date: Jul 2006 Location: dword ptr [ebp-1C], edx
Member: 322417 Status: Offline Thanks Meter: 940 | Alcatel POP 7 LTE aka 9015B 6.0.1 Unlocked by Furious - No Root Need Hi, Unlocked via Pack 5 - Firehorse Mode - EDL Method - BruteForce (Not Simple) - No Root need. Code: Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem82.inf,%qcdownloaddiag%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM13 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD size 7.3 GB IMEI: 014************* PTH: 03 PTS: RG9 PROV_ID: 9015B-2ARRCA1 SBTADDR: 4C:4E:03:BF:B6:07 SWIFIADDR: 4C:4E:03:85:FD:AE HS_PN: SAA1FDBAC10C SSN: Z9KC07BP6HA00AL Bruteforcing data; This operation can take up to 30 minutes !!! Done; Work id: 0A370FE2 Done; Stype: 00000001 SECURITY: X5R0UR01CL00 Size: 000002B9 Backup saved to: 014732xxxxxxxxxxx Backup file(s) removed; Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_19_06_2018_22_52_41.txt Time needed - 00:16:03 Last edited by Formingus; 06-19-2018 at 22:04. Reason: IMEI |
The Following 4 Users Say Thank You to Formingus For This Useful Post: |
06-20-2018, 12:54 | #14654 (permalink) |
Junior Member Join Date: Jul 2007 Location: tunis
Member: 549911 Status: Offline Thanks Meter: 16 | unlock Done After Support thx for team Software engine version: 1.0.0.10670 Searching phone ... MODEL : QCOM SERIES 51 COMPILED DATE : May 19 2016 08:35:00 RELEASE DATE : Feb 1 2016 00:00:00 FIRMWARE INFO : MPSS.JO.1.1.c1-00028-8909_GEN_PACK-1 IMEI : 35559507197077-6 BLUETOOTH ADDR : 00 00 00 00 00 00 FIRMWARE: UK_MR1_VDF_P809V50V1.0.0B02 close_event_report: OK; close_log_report: OK; close_message_report: OK; closing_com_port: OK; Starting the backup process; connect_server: OK; backup in progress: OK; Backup saved to: E:\GSM\FURIOUS-GOLD\PACK5\QCOM_SMART_TOOL_v1.0.0.10670\3555950719 7077_20_06_2018_13_48_55.bkp switching_download_mode: OK; closing_com_port: OK; Preparing to open COM310 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD start_frp_reset: OK; frp_reset: OK; Log file saved to: LOG_20_06_2018_13_50_53.txt |
The Following User Says Thank You to babyninnja For This Useful Post: |
06-20-2018, 21:15 | #14655 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | ALCATEL 5099A FRP DONE Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM44)) Preparing to start flash mode; Preparing to open COM44 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: a0d86a321fcf0beb3d3edd96d7593317 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem107.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM42; DEVICE INFO: BB CHIP: MT6737T [CA00, 00, 321, 05] HW_STORAGE_EMMC: 0x51000115 0x4D333645 0xCB550342 0x4F9456CC [SIZE=0x3A4A00000] IMEI1 [OTP 0000]: 015106-00-002010-5 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: 5099A-2CRGDO1 USRDATA INFO: 0xEE000000 SIZE: 0x2B2280000 Factory Reset Protection successfully removed ! Time needed - 00:00:00 Log file saved to: LOG_20_06_2018_16_08_15.txt |
