06-20-2018, 23:36 | #14656 (permalink) |
Registered User Join Date: Jul 2006 Location: <<SearcH EnginE>>
Member: 307373 Status: Offline Sonork: paypal.me/div859 Thanks Meter: 590 | Infinix Hot 5 Lite X559 android 7.0 frp done [connect the phone powered off to the usb cable] Phone detected (PreLoader USB VCOM Port (COM42)) Preparing to start flash mode; Preparing to open COM42 Connecting; Downloading DA; Initializing; Rid: 66ffae6c4b0bf6930d6a4d10044ac3f9 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (DA USB VCOM Port) TRYING TO OPEN COM43; DEVICE INFO: BB CHIP: MT6580_S00 [CA00, 00, 6580, FF] HW_STORAGE_EMMC: 0x46000115 0x4D323645 0xC3DE0342 0x83A4C2CC [SIZE=0x3A4A00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 0?8>50-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x127000000 SIZE: 0x27BD80000 Factory Reset Protection successfully removed ! Time needed - 00:00:00 With other tools phone stuck in log or supported API: 3 problem But with furious gold box is supported even if it's not in the list trust support |
The Following 2 Users Say Thank You to div_859 For This Useful Post: |
06-21-2018, 20:44 | #14657 (permalink) |
No Life Poster Join Date: Mar 2011 Location: dominican republic Age: 45
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | ALTICE S70 FRP DONE Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM20)) Preparing to start flash mode; Preparing to open COM20 Connecting; Downloading DA; Initializing; Rid: 16fe40e6834557edfe8ecc47e3f15896 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem62.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM14; DEVICE INFO: BB CHIP: MT6750 [CB00, 01, 6750, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333145 0xE51E0D42 0xB184E6D0 [SIZE=0x3A4A00000] IMEI1 [OTP 0001]: 357581-08-018746-9 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x12F800000 SIZE: 0x270AFBE00 Factory Reset Protection successfully removed ! Time needed - 00:00:00 Log file saved to: LOG_21_06_2018_15_42_12.txt |
The Following User Says Thank You to chipscell25 For This Useful Post: |
06-22-2018, 19:05 | #14658 (permalink) |
No Life Poster Join Date: Jan 2006 Location: PORTUGAL
Member: 216446 Status: Offline Thanks Meter: 220 | 5025D-ALWE1 FLASH FIRMWARE FURIOUS GOLD-OT SMART(PACK 6) DOWNLOADING FIRMWARE OPEN MAINTANCE >>>GO TO SUPPORT AREA>>>DOWNLOADABLE FILES>>>ALCATEL>>>PACK 6>>>SELECT THE MODEL N DOWNLOAD OPEN OT SMART WRITE FIRMWARE>>>>>>>>>>>SELECT FILE AND MODEL N CONNECT THE PHONE IN POWER OFF MODE >>>PRES CONNECT ************************************************** ** LOG BELOW ************************************************** ***** Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM40)) Preparing to start flash mode; Preparing to open COM40 Connecting; Downloading DA; Initializing; Rid: 8dfcae1b849c7b881b189a68218fc99b Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem138.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM64; DEVICE INFO: BB CHIP: MT6580_S00 [CA00, 00, 6580, FF] HW_STORAGE_EMMC: 0x51000115 0x4D533237 0x2A950042 0x7F82E29B [SIZE=0x1D2880000] IMEI1 [OTP 0000]: 351506-07-085168-9 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: 5025D-2BALWE1 USRDATA INFO: 0x9B000000 SIZE: 0x133480000 Loading the file ... Cfg done ... Formatting file system now... Done; Formatting NVDATA partition now... Done; Formatting METADATA partition now... Done; Downloading bootloader... Done; Downloading images... Done; Success; Time needed - 00:09:26 Log file saved to: LOG_22_06_2018_18_59_38.txt |
The Following User Says Thank You to jseyedanas For This Useful Post: |
06-24-2018, 06:42 | #14659 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Kotla arab ali khan Age: 56
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | >>>>> alcatel 5056n unlock Done By FuriousGold<<<<< Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (USB Composite Device) Preparing to enter download mode; Preparing to open COM10 Connecting; Init; Port opened; Phone detected (Android HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM63 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD size 14.7 GB IMEI: 01465000447136-9 PTH: 08 PTS: B6G PROV_ID: 5056N-2ATBUS7 SBTADDR: 24:0D:C2:83:35:1D SWIFIADDR: 24:0D:C2:99:ED:6C HS_PN: SAA1F5BWA10C SSN: N6KB11CQLNZ01SV Bruteforcing data; This operation can take up to 30 minutes !!! Done; Work id: 072C8FAB Done; Stype: 00000001 SECURITY: XUB0UP02BR10 Size: 000002C3 Backup saved to: 01465000447136-9 Unlocking; SIM_LOCK REMOVED ! |
The Following 3 Users Say Thank You to shahid41 For This Useful Post: |
06-26-2018, 21:08 | #14661 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,337 | Hisense U989 Pro FRP Reset / Read Flash Done by Manually Select Premio P530 [INFO] FRP Reset Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MTK USB Port (COM41)) Preparing to start flash mode; Preparing to open COM41 Connecting; Downloading DA; Initializing; Rid: 79bfc030578e0c2514b0a3b44bb791b7 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem93.inf,%mtk_sp_da%;DA USB VCOM Port) TRYING TO OPEN COM42; DEVICE INFO: BB CHIP: MT6580 [CA00, 00, 6580, 05] HW_STORAGE_EMMC: 0x46000115 0x4D32584E 0xFDC90142 0xC914FDB2 [SIZE=0x1D2880000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xCA000000 SIZE: 0x106F80000 Factory Reset Protection successfully removed ! Time needed - 00:00:00 Read Device Memory Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (PreLoader USB VCOM Port (COM16)) Preparing to start flash mode; Preparing to open COM16 Connecting; Downloading DA; Initializing; Rid: b957b458cb8b092b385722dfe47d26de Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6580 [CA00, 00, 6580, FF] HW_STORAGE_EMMC: 0x46000115 0x4D323238 0x9F790042 0x1193409A [SIZE=0x3A4A00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xC3800000 SIZE: 0x2DF580000 Getting partitions info; Reading info; Partitions info: [0x00080000-0x00300000]-[proinfo] [0x00380000-0x00500000]-[nvram] [0x00880000-0x00A00000]-[protect1] [0x01280000-0x00A00000]-[protect2] [0x01C80000-0x00040000]-[seccfg] [0x01CC0000-0x00060000]-[lk] [0x01D20000-0x01000000]-[boot] [0x02D20000-0x01000000]-[recovery] [0x03D20000-0x00080000]-[para] [0x03DA0000-0x00800000]-[logo] [0x045A0000-0x00A00000]-[expdb] [0x04FA0000-0x00100000]-[frp] [0x050A0000-0x02000000]-[nvdata] [0x070A0000-0x02760000]-[metadata] [0x09800000-0x00200000]-[oemkeystore] [0x09A00000-0x00600000]-[secro] [0x0A000000-0x00800000]-[keystore] [0x0A800000-0xA9000000]-[system] [0xB3800000-0x10000000]-[cache] [0xC3800000-0x2DF580000]-[userdata] [0x3A2D80000-0x01000000]-[flashinfo] Reading full dump; Contents saved to : C:\Users\Dream\Documents\Android_MTK\firmware_back up\FULL_DUMP_MT6580_EMMC_Hisense_Hisense U989 Pro_6_0_alps-mp-m0_mp1-V2_34_rlk6580_we_c_m.osp Time needed - 03:37:11 Log file saved to: LOG_26_06_2018_21_27_16.txt Also read this one by the same model Premio P530 http://forum.gsmhosting.com/vbb/f272...st-fg-2419273/ |
The Following 2 Users Say Thank You to ..::GMSR::.. For This Useful Post: |
06-27-2018, 04:18 | #14662 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off with volume down pressed to the usb cable] Phone detected (USB Modem Driver (COM43)) Preparing to start flash mode; Preparing to open COM43 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 14d7e60877b435af87b2e883f10cae2c Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@mtk-usb-all.inf,%mtk_sp_da%;MediaTek DA USB VCOM Port) TRYING TO OPEN COM45; DEVICE INFO: BB CHIP: MT6738 [CB00, 01, 6738, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333145 0xF8920D42 0xAD44C2D4 [SIZE=0x3A4A00000] IMEI1 [OTP 0001]: 014858-00-059463-5 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5085C-2ARKUS3 USRDATA INFO: 0x14E800000 SIZE: 0x251AFBE00 Searching data; Locked to [SIM1]: 310-15 code_cat_n: 4343764482226253 enabled: yes tries: 6 code_cat_ns: 4343764482226253 enabled: no tries: 0 code_cat_sp: 4343764482226253 enabled: no tries: 0 code_cat_c: 4343764482226253 enabled: no tries: 0 code_cat_sim: 4343764482226253 enabled: no tries: 0 Phone unlocked; Remove battery and cable; Time needed - 00:00:05 Log file saved to: LOG_26_06_2018_23_17_25.txt |
The Following User Says Thank You to ghacks For This Useful Post: |
06-27-2018, 23:04 | #14664 (permalink) |
No Life Poster Join Date: Jan 2017 Location: Jamaica
Member: 2673816 Status: Offline Thanks Meter: 612 | Alcatel 50044A read codes done Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM6)) Preparing to start flash mode; Preparing to open COM6 Connecting; Downloading DA; Initializing; Rid: 1cd73e3bed38a12d94769788eb79767d Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6737M [CA00, 00, 335, FF] HW_STORAGE_EMMC: 0x46000115 0x4D32584E 0xBD390142 0x2BA4D4CE [SIZE=0x1D2880000] IMEI1 [OTP 0001]: 01XX16-00-XX53XX-1 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5044A-2DC9JMD USRDATA INFO: 0xBF800000 SIZE: 0x10EC00000 Searching data; Locked to [SIM1]: 338-05 code_cat_n: 2808656477858240 enabled: yes tries: 10 code_cat_ns: 4816014444402960 enabled: no tries: 10 code_cat_sp: 7909087531875968 enabled: no tries: 10 code_cat_c: 0486644688736998 enabled: no tries: 10 code_cat_sim: 3345509836439650 enabled: no tries: 10 code_cat_ns_sp: 6833565651910903 enabled: no tries: 5 code_cat_sim_c: 9858246137720504 enabled: no tries: 5 Code reading finished; Remove battery and cable; Time needed - 00:00:10 |
The Following 2 Users Say Thank You to ThePhoneTechDoc For This Useful Post: |
06-28-2018, 08:47 | #14665 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Romania,Buc
Member: 694535 Status: Offline Thanks Meter: 70 | UMI Iron frp done ;) Frp done by otsmart select zte blade a410 Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM120)) Preparing to start flash mode; Preparing to open COM120 Connecting; Downloading DA; Initializing; Rid: 8faf25bdacd8f557228a98d482f859a1 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem216.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM121; DEVICE INFO: BB CHIP: MT6753_S00 [CA00, 00, 337, FF] HW_STORAGE_EMMC: 0x52000115 0x41423133 0x50450642 0x35829ADC [SIZE=0x3A4A00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xA4000000 SIZE: 0x2FED80000 Factory Reset Protection successfully removed ! Time needed - 00:00:00 |
The Following 3 Users Say Thank You to IM8 For This Useful Post: |
06-28-2018, 13:16 | #14666 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | alcatel ot4055u dead recovery done by flashing ALCATEL OT4055U FLASHING DONE BY FURIOUSGOLD PACK6 |
The Following User Says Thank You to fokal2008 For This Useful Post: |
06-29-2018, 10:18 | #14668 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Balkan Age: 50
Member: 1473716 Status: Offline Thanks Meter: 1,273 | Alcatel 2012D language change ok Read backup Using library Brom_DLL_v5.1316.1 EMI Settings Loaded; Searching phone; (for some models keep SPACE or * (STAR) key pressed before inserting the cable) Phone detected (MediaTek USB Port (COM171)) Preparing to start flash mode; Requesting authorization; Done; Connecting; Downloading DA; Initializing; Requesting baudrate change; Done; DEVICE INFO: BB CHIP: MT6260_S0000 [CB00, 00, 6260, 05] MEMORY: [MXIC] MX25U12835FZNI_10G [C2:25:38] [SIZE=0x01000000] FAT INFO: 0x00900000 SIZE: 0x00700000 IMEI1 [OTP]: 861244-03-242972-4 IMEI2 [OTP]: 861244-03-242973-2 Reading data; Done; Contents saved to :C:\FURIOUS BOX\OTZFlasher_v1.0.0.1643\2012D MEMORY_DUMP_01000000.otz Time needed - 00:01:03 --------------------------------------------------------------- Flash firmware done Using library Brom_DLL_v5.1316.1 EMI Settings Loaded; Searching phone; (for some models keep SPACE or * (STAR) key pressed before inserting the cable) Phone detected (MediaTek USB Port (COM171)) Preparing to start flash mode; Requesting authorization; Done; Connecting; Downloading DA; Initializing; Requesting baudrate change; Done; DEVICE INFO: BB CHIP: MT6260_S0000 [CB00, 00, 6260, 05] MEMORY: [MXIC] MX25U12835FZNI_10G [C2:25:38] [SIZE=0x01000000] FAT INFO: 0x00900000 SIZE: 0x00700000 IMEI1 [OTP]: 861244-03-242972-4 IMEI2 [OTP]: 861244-03-242973-2 Loading the file ... Cfg done ... File contents to write: [70006600-70009B07] ARM_BL [FFFFFFFF-00000406] ROOT_CERT [10005800-1000F173] ARM_EXT_BL [10BBC498-10BBCE43] SECURE_RO_ME [10030000-1038230B] PRIMARY_MAUI [1038270C-107D87B3] VIVA Downloading bootloader... Done; Pre-formatting code area.. Done; Downloading images... Done; Done; Done; Done; Formatting file system now... Done; Time needed - 00:01:40 |
The Following User Says Thank You to gile@gile For This Useful Post: |
06-29-2018, 18:43 | #14669 (permalink) |
No Life Poster Join Date: May 2007 Location: Algerie,Batna
Member: 508860 Status: Offline Sonork: 1613186 Thanks Meter: 224 | unlock MTN Smart s810 don thank you furious team Searching phone; Phone detected (@oem175.inf,%vcom_preloader%;MediaTek PreLoader USB VCOM (Android)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on MediaTek USB VCOM (Android) (COM108); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6580B, E00 Sw version: MOLY.WR8.W1449.MD.WG.MP.V57.P2 Hw Version: HEXING6580_WE_M_HSPA_HW Reading phone info; IMEI: 35xxxx-xx-xxxxxx-x Reading simlock info; Locked to: 616-03 code_cat_n: 78563412 enabled: yes tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Time needed - 00:01:01 Log file saved to: LOG_29_06_2018_19_38_38.txt |
The Following User Says Thank You to SkyMobile05 For This Useful Post: |
07-02-2018, 22:15 | #14670 (permalink) |
Member: 2673816 Status: Offline Thanks Meter: 612 | Alcatel 5049W unlock done Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off with volume down pressed to the usb cable] Phone detected (MediaTek USB Port (COM12)) Preparing to start flash mode; Preparing to open COM12 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 0b7512aa04e67326804a823ba6115815 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem59.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM7; DEVICE INFO: BB CHIP: MT6738 [CB00, 01, 6738, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333158 0x16CD0742 0x0D3532D4 [SIZE=0x748800000] IMEI1 [OTP 0001]: 01XX76-00-XX612X-7 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5049W-2ATBUS1 USRDATA INFO: 0x120000000 SIZE: 0x6240FBE00 Searching data; Checking server support license; Bruteforcing ... relax ;-) Buteforce took 00:14:22 Checking data integrity; Data integrity: OK; SIM_LOCK: ENABLED Rebuilding security; Phone unlocked; Remove battery and cable; Time needed - 00:14:29 |
The Following User Says Thank You to ThePhoneTechDoc For This Useful Post: |
