08-08-2018, 23:53 | #14731 (permalink) |
No Life Poster Join Date: Feb 2015 Location: Jamaican
Member: 2339843 Status: Offline Thanks Meter: 1,450 | Xt1767 unlock done by the beast copy pasters ur late Searching phone ... MODEL : QCOM SERIES 53 COMPILED DATE : Jun 10 2017 22:44:00 RELEASE DATE : Jun 8 2017 23:00:00 FIRMWARE INFO : MPSS.JO.3.0-00269-8937_GENNS_PACK-1.95745.3.102706.1 IMEI : 35413609158572-3 BLUETOOTH ADDR : 00 00 00 00 00 00 close_event_report: OK; close_log_report: OK; close_message_report: OK; closing_com_port: OK; Starting the backup process; connect_server: OK; backup in progress: OK; Backup saved to: c:\users\ziggy\desktop\qcom_smart_tool_v1.0.0.1075 5\35413609158572_8_08_2018_03_34_33.bkp Connecting; switching_fastboot_mode: OK; waiting_the_phone: OK; Looking for the interface; Port found [Motorola QC Diag Port (COM96)] connect_server: OK; restore in progress: OK; close_event_report: OK; close_log_report: OK; close_message_report: OK; Connecting; switching_fastboot_mode: OK; UNLOCK CODE: 46136385 SIM_LOCK REMOVED ! OTHER TEAM COPY PASTE SOLUTION...FURIOUS ALWAYS ON TOP |
The Following 4 Users Say Thank You to ziggywong0305 For This Useful Post: |
08-08-2018, 23:55 | #14732 (permalink) |
Member: 2339843 Status: Offline Thanks Meter: 1,450 | Kyocera sim lock removed by the beast Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem7.inf,%qcomdevice90080%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM3 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD size 3.5 GB IMEI: 01468500280103-5 PTH: 01 PTS: B7S PROV_ID: 4044O-2BAQUS1-R SBTADDR: 5C:77:76:1B1:C0 SWIFIADDR: 5C:77:76:1A:4A:E7 HS_PN: SAA61UAAC20C SSN: C7KF05CGVGB00GM Bruteforcing data; This operation can take up to 30 minutes !!! Done; Work id: 142ADA13 Done; Stype: 00000001 SECURITY: XWB7UAS0BR00 Size: 000002E2 Backup saved to: 01468500280103-5 Unlocking; SIM_LOCK REMOVED ! |
The Following 3 Users Say Thank You to ziggywong0305 For This Useful Post: |
08-10-2018, 15:29 | #14733 (permalink) |
No Life Poster Join Date: Mar 2011 Location: dominican republic Age: 45
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | Software engine version: 1.0.0.10755 Searching phone ... MODEL : QCOM SERIES 51 COMPILED DATE : Jul 27 2017 00:13:00 RELEASE DATE : Jul 4 2017 23:00:00 FIRMWARE INFO : MPSS.JO.3.0-00323-8909_GEN_PACK-1.106164.1 IMEI : 864864xxxxxxx-5 BLUETOOTH ADDR : 00 00 00 00 00 00 FIRMWARE: P890A16V1.0.0B11 close_event_report: OK; close_log_report: OK; close_message_report: OK; closing_com_port: OK; Starting the backup process; connect_server: OK; backup in progress: OK; Backup saved to: C:\Users\cell center\Desktop\01-FURIUOS GOLD DONGLE\QCOM_SMART_TOOL_v1.0.0.10755\86486403013056 _10_08_2018_10_24_51.bkp switching_download_mode: OK; closing_com_port: OK; Preparing to open COM36 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD start_frp_reset: OK; frp_reset: OK; Log file saved to: LOG_10_08_2018_10_27_01.txt Time needed - 00:02:14 |
The Following User Says Thank You to chipscell25 For This Useful Post: |
08-10-2018, 17:20 | #14734 (permalink) |
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem91.inf,%qcomserialportdesc90080%;Android HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM36 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD size 7,3 GB IMEI: 01482700055567-2 PTH: 02 PTS: Y58 PROV_ID: 5044R-2AAQUS1-R1 SBTADDR: 4C:4E:03:62:1C:76 SWIFIADDR: 4C:4E:03:5E:73:87 HS_PN: SAA1HQ0WA10C SSN: TCKC04CKTGA01OQ Work id: 22021984 Done; Stype: 00000001 SECURITY: X8C0LS01BR20 Size: 000002A5 Backup saved to: 01482700055567-2 Unlocking; SIM_LOCK REMOVED ! FRP has been Reset Successfully; Erase Setup Done; Erase Done; Erase Done; FRPEx Done; Log file saved to: LOG_10_08_2018_12_11_16.txt Time needed - 00:00:23 |
08-11-2018, 10:20 | #14735 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Pakistan
Member: 570093 Status: Offline Thanks Meter: 1,067 | Alcatel 5009-a unlock Code: Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM11)) Preparing to start flash mode; Preparing to open COM11 Connecting; Downloading DA; Initializing; Rid: 9af54d52362804b7e9b3609675e96111 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6580 [CA00, 00, 6580, FF] HW_STORAGE_EMMC: 0x45000170 0x44434148 0xCF1D0138 0xD3551ABF [SIZE=0x390C00000] IMEI1 [OTP 0000]: 355399-09-04xxxx-5 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: 5009A-2ATSAU1 USRDATA INFO: 0xBE000000 SIZE: 0x2CE480000 Searching data; Locked to [SIM1]: 505-01 code_cat_n: 8972135705550122 enabled: yes tries: 95 code_cat_ns: 2274121200826302 enabled: no tries: 99 code_cat_sp: 2274121200826302 enabled: no tries: 99 code_cat_c: 6763530417886659 enabled: no tries: 99 code_cat_sim: 7112370464727335 enabled: no tries: 99 code_cat_ns_sp: 7112370464727335 enabled: no tries: 99 code_cat_sim_c: 7112370464727335 enabled: no tries: 99 Phone unlocked; Remove battery and cable; Time needed - 00:00:06 Log file saved to: LOG_11_08_2018_14_07_20.txt |
08-11-2018, 15:37 | #14736 (permalink) |
No Life Poster Join Date: May 2009 Location: Bangladesh/USA/UK Age: 39
Member: 1033714 Status: Offline Sonork: 1640811:mothertelecom Thanks Meter: 91 | moto xt1700 unlock done with OTSMART Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM22)) Preparing to start flash mode; Preparing to open COM22 Connecting; Downloading DA; Initializing; Rid: f3c2a976708f207f0ae3233fbfebfb26 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6735M [CA00, 00, 335, FF] HW_STORAGE_EMMC: 0x484A0190 0x61344738 0x8A29A292 0x73B399B9 [SIZE=0x1D2C00000] IMEI1 [OTP 0000]: NO_IMEI IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x8E800000 SIZE: 0x13FC80000 Searching data; File not found; ST33A005 Locked to [SIM1]: C1C-1C code_cat_n: 12345678 enabled: no tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 2422322538263016 enabled: yes tries: 1 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:03 |
The Following User Says Thank You to mothertelecom For This Useful Post: |
08-11-2018, 17:03 | #14737 (permalink) |
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | Software engine version: 1.0.0.10755 Searching phone ... MODEL : QCOM SERIES 48 COMPILED DATE : Jun 7 2017 16:46:00 RELEASE DATE : May 4 2016 00:00:00 FIRMWARE INFO : MPSS.JO.1.1.c1-00040-8909_GEN_PACK-1 IMEI : 86927802023452-4 BLUETOOTH ADDR : 00 00 00 00 00 00 FIRMWARE: P890A07V1.0.0B15 close_event_report: OK; close_log_report: OK; close_message_report: OK; closing_com_port: OK; Starting the backup process; connect_server: OK; backup in progress: OK; Backup saved to: C:\Users\cell center\Desktop\01-FURIUOS GOLD DONGLE\QCOM_SMART_TOOL_v1.0.0.10755\86927802023452 _11_08_2018_12_00_17.bkp switching_download_mode: OK; closing_com_port: OK; Preparing to open COM36 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD start_frp_reset: OK; frp_reset: OK; Log file saved to: LOG_11_08_2018_12_02_28.txt Time needed - 00:02:14 |
08-11-2018, 17:50 | #14738 (permalink) | ||
No Life Poster Join Date: May 2014 Location: Morocco Age: 34
Member: 2178934 Status: Offline Thanks Meter: 1,288 | Unbrick a Dead Alcatel 4047D Only with FuriousGold Hello Yesterday im trying to flash alcatel ot-4047d with a sp flash tool and scatter rom ... Flashing stopped and a lot of problems comes 1 - Phone Dead not booting .. no Vebrate 2 - Phone is a secure boot with cert need authentication file 3 - Buckup not flashing at all 4 - all box and tools failed to flash this phone Some errors from flash tool brom error s_auth_handle_is_not_ready Error: S_AUTH_HANDLE_IS_NOT_READY(5000) [User] This is a secure Base-band Chip! Please select the authentication file first. BBCHIP MT6580 [AUTH]Not supported by exe or wrongly selected, aborting If model is listed, please select correct model Boot Fail.!!! This is my first experience with flashing this rsa boot security The Great thing is why only FuriousGold succes to flash this phone ? Logs Quote:
The Following 7 Users Say Thank You to mouhane For This Useful Post: |
08-12-2018, 09:14 | #14739 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | sing library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM48)) Preparing to start flash mode; Preparing to open COM48 Connecting; Downloading DA; Initializing; Rid: e4a41e75b97a03cde6e16efa85b48058 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6737M [CA00, 00, 335, FF] HW_STORAGE_EMMC: 0x46000115 0x4D323645 0xFD860342 0xE994CDD0 [SIZE=0x3A4A00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xE4000000 SIZE: 0x2BED80000 Searching data; Locked to [SIM1]: 234-10 code_cat_n: 2396090021139997 enabled: yes tries: 76 code_cat_ns: N/A enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 10 code_cat_c: 33334444 enabled: no tries: 10 code_cat_sim: 55556666 enabled: no tries: 10 code_cat_ns_sp: 77778888 enabled: no tries: 10 code_cat_sim_c: 99990000 enabled: no tries: 10 Code reading finished; Remove battery and cable; Time needed - 00:00:17 Log file saved to: LOG_12_08_2018_10_05_59.txt |
08-13-2018, 12:51 | #14740 (permalink) | ||
Banned Join Date: Jan 2017 Location: Algeria DZ
Member: 2669781 Status: Offline Thanks Meter: 1,839 | First in the World/Full support of Wiko Jerry 3 'secure-boot'/ frp reset done Factory Reset Protection done/Wiko Jerry 3 by selecting Jerry 2 from drop-down list 'OtSmart' Log of the operation/ FRP reset Quote:
The Following 6 Users Say Thank You to lyes_albert For This Useful Post: |
08-14-2018, 05:20 | #14741 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Kotla arab ali khan Age: 56
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | >>>>> ConeXis X1 Unlock Done By FuriousGold<<<<< Software engine version: 1.0.0.10758 Searching phone ... MODEL : QCOM SERIES 48 COMPILED DATE : Nov 2 2016 12:31:00 RELEASE DATE : Sep 2 2016 08:00:00 FIRMWARE INFO : MPSS.JO.1.2.c3-00131-8909_GEN_PACK-1 IMEI : 86224203074340-0 BLUETOOTH ADDR : 00 00 00 00 00 00 FIRMWARE: FNB_ZA_P809F52V1.0.0B10 close_event_report: OK; close_log_report: OK; close_message_report: OK; closing_com_port: OK; Starting the backup process; connect_server: OK; backup in progress: OK; Backup saved to: E:\Box Setup\FuriousGold box\QCOM_SMART_TOOL_v1.0.0.10758\86224203074340_13 _08_2018_21_11_08.bkp switching_download_mode: OK; closing_com_port: OK; Preparing to open COM12 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD Looking for the interface; Port found [ZTE Handset Diagnostic Interface (COM228)] connect_server: OK; restore in progress: OK; SIM_LOCK REMOVED ! Log file saved to: LOG_13_08_2018_21_15_07.txt Time needed - 00:04:03 |
The Following 2 Users Say Thank You to shahid41 For This Useful Post: |
08-14-2018, 20:59 | #14743 (permalink) |
No Life Poster Join Date: Aug 2012 Location: under pross
Member: 1798174 Status: Offline Sonork: 100.114149 Thanks Meter: 1,048 | LP N-37 frp removed selected alcatel OT-4049G Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM Port (COM14)) Preparing to start flash mode; Preparing to open COM14 Connecting; Downloading DA; Initializing; Rid: fc1f20b88e1e195088da64ba4691a1d0 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6570 [CA00, 00, 6570, 00] HW_STORAGE_EMMC: 0x4D000170 0x30373236 0x75090134 0x1B84CA14 [SIZE=0xE2480000] PROVIDER: N/A USRDATA INFO: 0x80000000 SIZE: 0x60F80000 Factory Reset Protection successfully removed ! Time needed - 00:00:00 Log file saved to: LOG_14_08_2018_20_45_20.txt |
08-15-2018, 13:41 | #14744 (permalink) |
Member: 2178934 Status: Offline Thanks Meter: 1,288 | SFR 117 Unlock Product: OT-117 Provider ID: 117X-2[X=A,B,C]ALFR1 IMEI: 864047012100240 Start code calculate... NCK: NSCK: SPCK: PCK: This Provider ID is SIM free version! Unlock code is not necessary! Please choose one Provider ID first! Product: SFR117 Provider ID: F117X-2[X=D]SFFR1 IMEI: 864047012100240 Start code calculate... NCK:2186381237 NSCK: SPCK: PCK: Code calculate finished successfully! |
The Following User Says Thank You to mouhane For This Useful Post: |
08-17-2018, 11:10 | #14745 (permalink) |
Member: 2669781 Status: Offline Thanks Meter: 1,839 | Alcatel 2010X network-lock successfully eliminated Full log of the operation/ Code: Using library Brom_DLL_v5.1316.1 Searching phone; (for some models keep SPACE or * (STAR) key pressed before inserting the cable) Phone detected (MTK USB Port (COM27)) Preparing to start meta mode; Requesting authorization; Done; Meta mode entered; Baseband Chip: MT6250 Sw version: MAUI.11B.W12.24.MP.V2.F41 Hw Version: JRDHZ50_12864_11B_24MP_HW Reading phone info; IMEI: 860063-02-084184-4 Reading security; Done; Checking; Preparing; Writing security; Phone unlocked; Remove battery and cable; Time needed - 00:00:21 Log file saved to: LOG_17_08_2018_10_56_46.txt |
The Following User Says Thank You to lyes_albert For This Useful Post: |
