06-12-2009, 14:46 | #3 (permalink) |
No Life Poster Join Date: May 2006
Member: 273834 Status: Offline Thanks Meter: 68 | CODE NOT WORKING HERE IS THE LOG Press power on ! Starting communication ... Platform: E-Gold Lite ... Preloader sent .... Loader sent .... Flash ID(0): 0001:011A Bypassing security ... LOCK: ACTIVE IMEI: 353999031761808 UNLOCK CODE: 15013058 Saved: INFINEON_14.45.23_12.06.2009_EEP.bin REMOVE BATTERY AND PUT BACK ! Time needed - 00:00:22 |
06-18-2009, 00:12 | #5 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | Quote:
Impossiblke not to work ! What phone says ? Read flash and send me aswell. Br | |
06-24-2009, 14:05 | #7 (permalink) |
Freak Poster Join Date: Sep 2004
Member: 82815 Status: Offline Thanks Meter: 160 | Press power on ! Starting communication ... Platform: E-Gold Lite ... Preloader sent .... Loader sent .... Flash ID(0): 0001:011A Bypassing security ... LOCK: ACTIVE IMEI: 353999030534784 UNLOCK CODE: 24046854 Saved: INFINEON_14.03.05_24.06.2009_EEP.bin REMOVE BATTERY AND PUT BACK ! Time needed - 00:00:16 then Try 2945#20001# and then then config. -> security -> simlock and enter code |
06-24-2009, 16:34 | #9 (permalink) |
No Life Poster Join Date: Jun 2004 Location: Cameroon- Bamenda
Member: 69269 Status: Offline Thanks Meter: 175 | lg GB102 code read using kp100 Press power on ! Starting communication ... Platform: E-Gold Lite ... Preloader sent .... Loader sent .... Flash ID(0): 0001:011A Bypassing security ... LOCK: ACTIVE IMEI: 353999030953687 UNLOCK CODE: 34034857 Saved: INFINEON_16.29.01_24.06.2009_EEP.bin REMOVE BATTERY AND PUT BACK ! Time needed - 00:00:24 After you read code, insert non accepted simcard and press unlock button on phone then u shall see space to put code |
01-24-2010, 07:44 | #10 (permalink) |
No Life Poster Join Date: Jun 2006 Location: {JUST@PRAY@FOR@ME} Age: 39
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | THE PHONE SHOWS SIM CARD ERROR COM5 [VCP0] selected module v1.68 Device: LG-GB102 Checking data, wait... Action: unlock read unlock codes Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 230400 Set Baud Done Connecting ... flash: 007F:22F6 Connecting Done Check hardware ... sw version: .01 ULC2GL 2008-03-17 1.0 TMO_UK GB102 01 FL 44 V10a 234-30 M Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-static_20100124-123756.B1E.bin loading data... data loaded imei: 35761602540687900 reading eeprom-security_35761602540687900... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-security_35761602540687900_20100124-123756.B1E.bin reading eeprom-complete_35761602540687900... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-complete_35761602540687900_20100124-123800.B1E.bin backup critical area Done Check memory ... loading data... data loaded code: 11769759 Finished, time used: 16 sec Remove/Install battery now ! |
LG GB102 how to unlock it? [Solved] | kariakala | Z3X-Team Products | 5 | 10-16-2009 06:30 |
nec n223i how to unlock or how to enter code? | infogsm | NEC | 14 | 11-26-2005 13:53 |
OT view v.12 I how to enter code to phone (letter B is in code) | gladeo | Alcatel & TCL Old Models | 0 | 12-19-2003 21:45 |
