12-09-2009, 03:01 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: P A K I S T A N Age: 16
Member: 190344 Status: Offline Thanks Meter: 280 | .:hack3r2k:. the_genious man i need help in kg 130 with imei 08000 only [SOLVED] br hamid |
12-09-2009, 10:46 | #3 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | full flash the set with this ver KG130P32-30-V10c-202-05 JUN 03 2007+1.mot |
The Following User Says Thank You to Faheem Anjum For This Useful Post: |
12-09-2009, 11:08 | #4 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: *P*A*K*I*S*T*A*N
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | Quote:
as u have seen imei damaged | |
The Following User Says Thank You to StRaNgE PeRsOn For This Useful Post: |
12-09-2009, 12:05 | #6 (permalink) | |
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | Quote:
12-09-2009, 12:49 | #7 (permalink) |
Member: 190344 Status: Offline Thanks Meter: 280 | i am trying to flash using a checked lg 7050 cable but softwre hangs on this Press power on ! Starting communication ... i selected kg 130 tried with fidion, choose the correct port, in my case com 3? please need urgent help |
12-09-2009, 12:57 | #8 (permalink) |
Member: 190344 Status: Offline Thanks Meter: 280 | i connected with the trick holding the power key given commmand do job inserting battary with out releasing powqer key for 3 min Press power on ! Starting communication ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Baud rate changed ok ! Flash ID(0): 0001:227E:2100 READING INFO ... WAIT ! (CAN TAKE ~60s) DATE: VUK JUL 24 2007ERATOR: 234-30 VERSION: V10a REVISION: 44 FIRMWARE: KG130P40FL IMEI: 35531101618118400 LOCK: ON Writting flash data ... |
12-09-2009, 13:24 | #9 (permalink) |
Member: 190344 Status: Offline Thanks Meter: 280 | thanks mr. Faheem Anjum my problem is solved with the said version. |
The Following 2 Users Say Thank You to biochemistali For This Useful Post: |
12-16-2009, 04:31 | #12 (permalink) |
Junior Member Join Date: Oct 2005 Age: 55
Member: 187581 Status: Offline Thanks Meter: 4 | furious blackberry dongle unlock hi friend i have with the furious blackberry dongle unlock pack 4 the dongle work like pack 3 and no 4 help me please regards slyman007 |
i need help in kp 130 | piege | LG | 0 | 06-13-2008 22:29 |
help for kG 130 flashing | nadirghazi | HWK | 0 | 06-13-2008 15:45 |
need help in unlocking motorola v60i.imei 350644691600648 | paul2 | Phone Unlocking Codes & Maps | 0 | 12-26-2003 19:11 |
