03-26-2016, 17:50 | #1 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Bolivia
Member: 2202707 Status: Offline Sonork: whatsapp +59170073722 Thanks Meter: 212 | help .. 5065A no unlock :( there is some method to read the code ... ??? Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@usb.inf,%usb\composite.devicedesc%;USB Composite Device) Preparing to enter download mode; Preparing to open COM289 Connecting; Init; Port opened; Phone detected (@oem213.inf,%qcomdevice90080%;RELINK HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM293 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD IMEI: 01435400042121-9 PTH: 07 PTS: A75 PROV_ID: 5065A-2KLDBO1 SBTADDR: 1C:CB:99:A4:F9:F3 SWIFIADDR: 1C:CB:99:A4:F9:F4 HS_PN: SAA34N1AA11C SSN: 1TKJ10BABOY0021 Work id: 00F914DF Done; SECURITY: X8C0AB01BR10 Size: 000002A5 Backup saved to: 01435400042121-9 Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_26_03_2016_12_03_22.txt Time needed - 00:00:25 |
The Following User Says Thank You to tomelich For This Useful Post: |
03-28-2016, 17:34 | #4 (permalink) |
Member: 2202707 Status: Offline Sonork: whatsapp +59170073722 Thanks Meter: 212 | Here another cell, also with the same problem job done, but continues to call network code Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@usb.inf,%usb\composite.devicedesc%;USB Composite Device) Preparing to enter download mode; Preparing to open COM73 Connecting; Init; Port opened; Phone detected (@oem213.inf,%qcomdevice90080%;RELINK HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM293 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD IMEI: 01435400047881-3 PTH: 07 PTS: A75 PROV_ID: 5065A-2KLDBO1 SBTADDR: 1C:CB:99:A4:2D:C2 SWIFIADDR: 1C:CB:99:A4:2D:C3 HS_PN: SAA34N1AA11C SSN: 1TKJ09BCVNY004G Work id: 00C4F4FA Done; SECURITY: X2A0MA00BR10 Size: 000002B1 Backup saved to: 01435400047881-3 Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_28_03_2016_12_29_17.txt Time needed - 00:00:25 |
