11-12-2013, 01:51 | #1 (permalink) |
No Life Poster Join Date: Feb 2007
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | help how to connect ZTE V768 and T760 the ZTE T760 it block please it can be solve? thanks |
11-12-2013, 02:55 | #2 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | Done T760 left V768 Searching phone; Phone detected (PreLoader USB VCOM (Android)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Gadget VCOM Driver (COM71); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6573, E00 Sw version: MAUI.11AMD.W11.37.SP.V3.F1.P1 Hw Version: ZTENJ73_HW Reading phone info; IMEI: 862033-01-021773-3 Reading simlock info; Locked to: 505-01 code_cat_n: 12345678 enabled: yes tries: 0 code_cat_ns: 56781234 enabled: no tries: 10 code_cat_sp: 11112222 enabled: no tries: 10 code_cat_c: 33334444 enabled: no tries: 10 code_cat_sim: 55556666 enabled: no tries: 10 code_cat_ns_sp: 77778888 enabled: no tries: 10 code_cat_sim_c: 99990000 enabled: no tries: 10 Time needed - 00:00:32 |
11-12-2013, 19:36 | #4 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | press "Read Code" then attach the phone power off then it install drivers when it done nothing happen result is here Code: Attach the phone to the USB now ... ERROR: 1 Time needed - 00:01:35 |
11-12-2013, 21:01 | #5 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | changing to another usb port Code: Attach the phone to the USB now ... Phone found on COM74 and initialized; Reading imei; IMEI: 865074-01-832105-8 Reading data; Log saved: 7F269A5002A0CF1DB15CCE72A9EC0A0E.bin Enter an restricted sim and use as unlock code : 00000000 (8 times 0) NOTE: For ZTE models enter *983*258# in order to be able to input code SIM_LOCK REMOVED ! Resetting the target ... Time needed - 00:00:12 |
