03-09-2008, 06:24 | #1 (permalink) |
Freak Poster Join Date: Feb 2008 Location: sri Lanka
Member: 709608 Status: Offline Thanks Meter: 14 | will furious team give support for this? Starting communication ... Platform: E-Gold Lite ... Preloader sent .... Loader sent .... Flash ID(0): 0001:011A Bypassing security ... LOCK: ACTIVE IMEI: 355588********* UNLOCK CODE: 19956514 Data saved to INFINEON_EEP_09.25.28_09.03.2008_DUMP.bin REMOVE BATTERY AND PUT BACK ! Time needed - 00:00: kg275 when insert sim my mobile shows sim card error, when try to enter code shows emergency calls only also folowed by #*# also emergency calls only,dont accept code, last time also i got same problem but a nother person could do it in the nother shop. thanks |
03-09-2008, 12:43 | #3 (permalink) |
Member: 709608 Status: Offline Thanks Meter: 14 | i did repair, now the phone doesn't power on at all, right back firmware KG275P16-ESA-V10a-***-XX-APR-05-2007 then tried with MG160bP16FL-55-V10a-724-05-MAR-19-2007+1.bin still dead, my phone originel version before doing repair is KG275P16FL 44-V10a 234-33 Aug-17-2007 i am trying whole day gold support will you help me? |
03-09-2008, 17:03 | #4 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
Br | |
03-09-2008, 20:03 | #5 (permalink) |
Member: 709608 Status: Offline Thanks Meter: 14 | keep power on longer doesn't detect the phone, as you says i have to put the betery then began to start loading, but look at this it doesn't power on death. this heppend after i did repair by furious,what is the meaning of repair? i saw it erase some thin thats all,phone doesn't power on still,that function not to kg275? i flash with MG160bP16FL-55-V10a-724-05-MAR-19-2007+1.bin Press power on ! Starting communication ... Platform: E-Gold Lite ... Preloader sent .... Loader sent .... Flash ID(0): 0001:011A Writing... Done ! Time needed - 00:07:40 although flash finish it is still death man.what can i do know? Last edited by helperer; 03-09-2008 at 20:08. |
03-09-2008, 22:37 | #6 (permalink) | |
Br | |
03-10-2008, 03:08 | #8 (permalink) |
Member: 709608 Status: Offline Thanks Meter: 14 | i tried KG275P 16V10D,V10,V10C.. no luck also can try MG160a,10c, difrent firmware? my originel firmware version KG275P16FL 44-V10a 234-33 Aug-17-2007,not in the suuport, i sent it to your mail please check,i didn't do ant thing just press repaire then it dosn't power on |
03-10-2008, 14:16 | #11 (permalink) |
No Life Poster Join Date: Jan 2005 Location: PT Age: 40
Member: 108180 Status: Offline Sonork: 100.106866 Thanks Meter: 381 | when u try to unlock a KG275 u read codes ok pwr on mobile with other network card it be displayed " Sim Not Valid " or other message. enter 8 digits " NCK " READED and click Green Botton " CALL BUTTON " Wait 5 seconds and MIRACLE PHONE UNLOCKED WITHOUT FLASH so Easy. |
03-10-2008, 21:04 | #12 (permalink) | |
Br | |
03-13-2008, 16:07 | #14 (permalink) | |
Freak Poster Join Date: Aug 2004 Location: barika algeria
Member: 75927 Status: Offline Thanks Meter: 18 | Quote:
hi doesn't work for me is ther any other way to entre NCK in phone? | |
03-13-2008, 16:56 | #15 (permalink) |
Member: 75927 Status: Offline Thanks Meter: 18 | hey geuss what .......... i got this after repair Press power on ! Starting communication ... Platform: E-Gold Lite ... Preloader sent .... Loader sent .... Flash ID(0): 0001:011A Bypassing security ... LOCK: INACTIVE IMEI: N/A UNLOCK CODE: N/A Data saved to INFINEON_EEP_16.40.52_13.03.2008_DUMP.bin REMOVE BATTERY AND PUT BACK ! Time needed - 00:00:31 phone won't power on |
E52 RM-469 Flashing problem.Flash ID not supported for this loader (RAPUv11_algo_xsr1 | rafik2533 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 04-04-2010 20:38 |
Bring back Furious team product supporters to this forum | salimben | FuriousGold | 6 | 11-08-2008 16:59 |
will furious team support unlocking LG SH110?? | kevin168 | FuriousGold | 1 | 08-10-2008 07:24 |
Will Furious Team adead Unlock for Amoi MD-1 (MOMO DESIGN) ??? | Unlocker_001 | FuriousGold | 2 | 12-29-2007 22:27 |
myx-1wt trio new ht when give support for this mitek | saily | SagMaster Team OLD Products | 7 | 11-10-2005 09:22 |
