02-25-2014, 14:30 | #2 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | If you just received your FuriousGold device you will need to register so it can be activated Download the latest Maintenance module Extract the file from the zip archive using Winzip Connect your FuriousGold device to the USB port on your computer and install the drivers provided with maintenance module Double click on Maintenance.exe and click the GO SUPPORT button Register your personal details If you have bought a FuriousGold USB KEY Lite version you need to select 3 packs of your choice to activate on your device if you have bought a FuriousGold USB KEY All activated all the packs will be activated except PACK12 Once the registration is done your account is activated instantly and you should get a confirmation by email Everytime you need to access your account simply use the Maintenance module and click GO SUPPORT button. How to register FuriousGold device |
The Following User Says Thank You to gcceleghg For This Useful Post: |
02-25-2014, 14:34 | #3 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | First go in the FuriousGold® The World Famous Unlocking Tool 6 years of non-stop updates and download the maintenance if you look in the right of the page you see Download latest maintenance software Then connect the box install the drivers and run the maintenance exe Go to support and download the setup from Support /SETUP /LATEST INSTALLER gsmvn-support.com How to Use Furious Gold Maintenance Updater - YouTube |
