11-11-2011, 03:01 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: burkina faso
Member: 457765 Status: Offline Thanks Meter: 77 | help me step by step unlock treo 650 it is my first time to unlock treo 650 with furious i need help to unlock this phone.i have read that phone require credit?how to buy these credits and unlock phone help needed please |
11-11-2011, 03:06 | #2 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: Free Palestine
Member: 330579 Status: Offline Thanks Meter: 67,515 | Quote:
This is not first Time answared. Regards Haicha | |
11-11-2011, 18:55 | #4 (permalink) |
Member: 457765 Status: Offline Thanks Meter: 77 | i have seen how to do it but i have > ERROR: 02 statut infos > REFILL STRING: UJM623AAWJ4XY5TF4YRO4 recharge code :PGBDNN63NXPM2RP3MBCT5W633PN5W34E when i put recharge code i have > ERROR: 03 help needed please |
11-12-2011, 10:35 | #5 (permalink) |
No Life Poster Join Date: Oct 2009 Location: FuriouSGold Age: 18
Member: 1144248 Status: Offline Sonork: 100.1574721 Thanks Meter: 3,936 | NO! You are doing wrong! do not use TXT to CODE How i read codes from TREO 650 and use them to unlock it ? 1. Run treo read code software 2. remove any card inside in phone 3. Remove Treo Battery Cover & Power on your Treo 4. Connect USB Sync Cable (as supplied with phone) 5. Place Phone in “Test Mode” - Press and Hold Button on USB Cable - Using Pen Press and hold for 1 second Reset button in Back of Treo - Release reset button, then release Active Sync button on Cable - Display should be red/blue etc and detail boot loader version - Phone is now in Test Mode If Windows now detects a new device (this will happen the first time you put a treo 650 into test mode, then you will need to do the following (you will only need to do this once) 1. A new hardware wizard will appear. Select “No, not this time” if asked about connecting to the internet 2. Then on the next screen Select “Don’t search, I will choose driver to install.” Click on the “Have Disc … “ button 3. Select the drivers, direct windows to the folder containing the Treo HTTC drivers, if presented with a Windows warning about Microsoft signing of drivers. Choose “Continue Anyway” 4. Windows will now install the drivers. 5. Click on finish on next screen 6. Windows has finished installing New Hardware .You will only need to do this once per PC. 7. Now click “Do Job” on SW, (codes should be displayed in under 5 Seconds) Entering Codes 1. Remove Treo battery, unplug cable 2. Insert incorrect SIM card (1 the phone does not accept) 3. Power on Treo-650, “Sim not allowed” is displayed, click “ok” 4. Go to the dial pad, and use the stylus to enter code exactly as displayed in the software. Then press “Dial” 5. Phone will reset and display “sim lock removed” Phone Unlocked !!!! |
11-12-2011, 15:07 | #6 (permalink) |
Member: 457765 Status: Offline Thanks Meter: 77 | hi i have this error after put phone in test mode and connect to computer: Failed to open the communication port ! Error ... ! Time needed - 00:00:00 |
11-12-2011, 15:44 | #7 (permalink) |
Member: 1144248 Status: Offline Sonork: 100.1574721 Thanks Meter: 3,936 | Close from task manager the wcescomm.exe and next time search ! |
The Following User Says Thank You to FTEAM_MODERATOR For This Useful Post: |
11-12-2011, 17:07 | #9 (permalink) |
Member: 457765 Status: Offline Thanks Meter: 77 | problem solved phone unlocked successfully.Problem was driver,my computer has installed driver automatically,i have uninstalled windows driver and use furious driver in treo folder after that all have been ok |
The Following User Says Thank You to ahmedao1 For This Useful Post: |
