Help for unlock Alcatel OT-985 ! Please help me for unlock Alcatel OT-985. How to put phone in service mode for unlock ? Program always displayed: Searching phone; ERROR: Device not found ! Time needed - 00:00:42 |
Searching phone; Phone detected (PreLoader USB VCOM (Android)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on FTEAM USB Serial Port (COM50); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6573, E00 Sw version: MAUI.11AMD.W11.37.SP.V27.P7 Hw Version: JRD73_GIN_MODEM_GEMINI2_HW Reading phone info; IMEI: 861568-01-xxxxxx-x Reading simlock info; Locked to: 284-03 code_cat_n: 06607252 enabled: yes tries: 3 code_cat_ns: 05438650 enabled: no tries: 10 code_cat_sp: 19194621 enabled: no tries: 10 code_cat_c: 17087050 enabled: no tries: 10 code_cat_sim: 13975750 enabled: no tries: 10 code_cat_ns_sp: 53297761 enabled: no tries: 5 code_cat_sim_c: 86817778 enabled: no tries: 5 Time needed - 00:00:17 All OK,sorry for thread !! |
Please insert USB cable now... Port:\\?\usb#vid_0e8d&pid_2000#6&a3e544&0&4#{a5dcb f10-6530-11d2-901f-00c04fb951ed} Phone detected, switch to meta mode, wait.... META Port detected : COM:5 ENTER META ERROR: Communication through either RS232 or IPC error Meta mode error, check if phone driver is corectly installed! All done. i have this error whenever i try to read codes..pls help..i already installed the driver |
That log isnt from our soft so ask someone else Br;) |
I try to find how unlock the alcatel 985 ,,,not found !! Here the solution 1. install alcatel android manager 2 . open mtk reader ,insert cable to alcatel without battery ,click read code, then put battery to phone, install all drivers ,after you can read the correct code If not work reapeat the procedure ,after all drivers you instaled . Good luck ! |
