Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > FuriousGold
FuriousGold FuriouS GOLD Support Area | Powered by FuriousTeam
Old 12-10-2012, 13:46   #1 (permalink)
Member: 142632
Sonork: 100.1589012
Thanks Meter: 391
Help for unlock Alcatel OT-985 !
Please help me for unlock Alcatel OT-985. How to put phone in service mode for unlock ? Program always displayed:
Searching phone;
ERROR: Device not found !
Time needed - 00:00:42
The Following User Says Thank You to Umbabaraumba For This Useful Post:
Old 12-10-2012, 14:44   #2 (permalink)
Member: 142632
Sonork: 100.1589012
Thanks Meter: 391
Searching phone;
Phone detected (PreLoader USB VCOM (Android))
Preparing to start meta mode;
Searching for debug port; (be sure drivers from support were installed)
Debug Port found on FTEAM USB Serial Port (COM50);
Preparing to connect meta mode;
Meta mode entered;
Baseband Chip: MT6573, E00
Sw version: MAUI.11AMD.W11.37.SP.V27.P7
Hw Version: JRD73_GIN_MODEM_GEMINI2_HW
Reading phone info;
IMEI: 861568-01-xxxxxx-x
Reading simlock info;
Locked to: 284-03
code_cat_n: 06607252 enabled: yes tries: 3
code_cat_ns: 05438650 enabled: no tries: 10
code_cat_sp: 19194621 enabled: no tries: 10
code_cat_c: 17087050 enabled: no tries: 10
code_cat_sim: 13975750 enabled: no tries: 10
code_cat_ns_sp: 53297761 enabled: no tries: 5
code_cat_sim_c: 86817778 enabled: no tries: 5
Time needed - 00:00:17
All OK,sorry for thread !!
Old 12-11-2012, 11:18   #3 (permalink)
Member: 186972
Thanks Meter: 4
Please insert USB cable now...
Port:\\?\usb#vid_0e8d&pid_2000#6&a3e544&0&4#{a5dcb f10-6530-11d2-901f-00c04fb951ed}
Phone detected, switch to meta mode, wait....
META Port detected : COM:5
ENTER META ERROR: Communication through either RS232 or IPC error
Meta mode error, check if phone driver is corectly installed!
All done.
i have this error whenever i try to read codes..pls help..i already installed the driver
The Following User Says Thank You to roland_13 For This Useful Post:
Old 12-12-2012, 09:52   #4 (permalink)
.:hack3r2k:.'s Avatar
Member: 15022
Sonork: 100.53452
Thanks Meter: 51,056
All done.
That log isnt from our soft so ask someone else
The Following User Says Thank You to .:hack3r2k:. For This Useful Post:
Old 04-12-2013, 19:59   #5 (permalink)
Member: 472482
Thanks Meter: 88
I try to find how unlock the alcatel 985 ,,,not found !! Here the solution
1. install alcatel android manager
2 . open mtk reader ,insert cable to alcatel without battery ,click read code, then put battery to phone, install all drivers ,after you can read the correct code
If not work reapeat the procedure ,after all drivers you instaled .
Good luck !
Page generated in 0.24266 seconds with 7 queries
