09-17-2014, 04:13 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Sri Lanka
Member: 576633 Status: Offline Thanks Meter: 392 | Help To unlock Huawei U2805-1 (MTK 6276) So i try with MTKReader, but not connect then i try with OTZ Flasher with Huawei U5130 model selected ! with U5130 model has no Remove Sim lock option, but it can read flash here is screen shot, log file & reded flash file (dump) Using library Brom_DLL_v5.1316.1 EMI Settings Loaded; Searching phone; (for some models keep SPACE or * (STAR) key pressed before inserting the cable) Phone detected (MTK USB Port) Preparing to start flash mode; Connecting; Downloading DA; Initializing; Requesting baudrate change; Done; DEVICE INFO: BB CHIP: MT6276W_S0101 [CB00, 101, 6276, 05] MEMORY: [HYNIX] HYD0SQG0MF1P [AD:B1:00] [SIZE=0x08000000] FAT INFO: 0x04000000 SIZE: 0x04000000 Reading data; Done; Contents saved to :C:\Documents and Settings\NTDcare\Desktop\MEMORY_DUMP_08000000.otz Time needed - 00:11:15 Flash file, https://mega.co.nz/#!cc9kjQ6D!I5iOKj...PNEwj9xj9bzrKQ sir, pls can u help me to unlock that phone Br, nishue |
The Following User Says Thank You to nishue For This Useful Post: |
09-18-2014, 09:07 | #4 (permalink) |
Member: 576633 Status: Offline Thanks Meter: 392 | Yes its done ! MTK Reader, Huawei/doro/.. & USB selected Searching phone; Phone detected (MTK USB Port) Preparing to start meta mode; COM opened ok; Phone must be powered off; Keep pressing the power button if serial used ! (for USB connection keep SPACE or * (STAR) key pressed and insert the usb cable) Connecting; Meta mode entered; Baseband Chip: MT6276 Sw version: U2805-1V100R001C457B200SP03SC Hw Version: Reading phone info; IMEI: 860555-02-031564-6 Reading simlock info; Unlock codes: Locked to: 419-04 code_cat_n: 37735526 enabled: yes tries: 9 code_cat_ns: 56781234 enabled: no tries: 10 code_cat_sp: 11112222 enabled: no tries: 10 code_cat_c: 33334444 enabled: no tries: 10 code_cat_sim: 55556666 enabled: no tries: 10 code_cat_ns_sp: 77778888 enabled: no tries: 10 code_cat_sim_c: 99990000 enabled: no tries: 10 Time needed - 00:00:20 BR, nishue |
09-18-2014, 09:13 | #5 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | You can also unlock it by imei Huawei NP Unlock Codes Instant Permanent Official Factory Unlocking Guaranteed or Huawei NP Unlock Codes Instant Br |
