04-15-2013, 03:18 | #1 (permalink) |
No Life Poster Join Date: Feb 2007
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | Help to Unlock my Huawei Ascend Y 101 U8186-7 thanks |
04-15-2013, 03:51 | #3 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | earching Huawei phone COM ports... OK Application port: COM78 Diagnostics port: COM90 Reading phone info... failed! Product name: U8185 IMEI: 863759010073036 Firmware: M7x25AV100R001C00B827 Error! Sorry, this phone not supported ! 2013-04-15 15:50:02.562 Start unlocking procedure (863759010073036) Connecting to server... OK Sending data to server... OK Reading data from server... OK Disconnecting from server... OK bug detect : no phone handle ! |
04-15-2013, 09:48 | #4 (permalink) |
No Life Poster Join Date: Oct 2009 Location: FuriouSGold Age: 18
Member: 1144248 Status: Offline Sonork: 100.1574721 Thanks Meter: 3,936 | As far as I know it's not supported but may try to add it. We will check the options to add this device |
The Following User Says Thank You to FTEAM_MODERATOR For This Useful Post: |
04-15-2013, 11:41 | #5 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
Br | |
04-15-2013, 21:01 | #6 (permalink) | |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | Quote:
not sure now i will check today and if i use the old version i will do with the latest version and post result here. thanks | |
04-17-2013, 00:33 | #9 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | Successfully unlock first put phone into download mode by press vol - & vol + & power and pink display then connect to usb cable Code: Searching Huawei phone COM ports... OK Application port: COM78 Diagnostics port: COM90 Checking bootloader status... not running! Error! DBAadapter Reserved Interface driver ver. 2.0.6.601 required, please download from support and install while installation in configure software then press phone into download mode and connect to finish installation Code: Searching Huawei phone COM ports... OK Application port: COM78 Diagnostics port: COM79 Checking bootloader status... not running! Connecting to server... OK Sending data to server... OK Reading data from server... OK Sending data to server... OK Reading data from server... OK Sending data to server... OK Reading data from server... OK Uploading bootloader... OK Waiting phone to be ready ... OK Starting bootloader... OK Disconnecting from server... OK Initializing flash... OK Reading phone info... OK Decrypting IMEI... OK Reading sensitive data... OK Model name: Huawei U8185/U8655 IMEI: 863759010073036 SIM Lock status: locked (NCK lock) Code: Searching Huawei phone COM ports... OK Application port: COM78 Diagnostics port: COM79 Checking bootloader status... not running! Connecting to server... OK Sending data to server... OK Reading data from server... OK Sending data to server... OK Reading data from server... OK Sending data to server... OK Reading data from server... OK Uploading bootloader... OK Waiting phone to be ready ... OK Starting bootloader... OK Disconnecting from server... OK Initializing flash... OK Reading phone info... OK Decrypting IMEI... OK Reading sensitive data... OK Model name: Huawei U8185/U8655 IMEI: 863759010073036 SIM Lock status: locked (NCK lock) Log file successfully saved to file "C:\Documents and Settings\Unlock Teritory\Desktop\Unlock Teritory\Furious Gold Box\Pack 7\2013-04-17_122259_log.txt" 2013-04-17 12:23:03.355 Start unlocking procedure (863759010073036) Connecting to server... OK Sending data to server... OK Reading data from server... OK Checking bootloader status... OK Initializing flash... OK Reading phone info... OK Decrypting IMEI... OK Reading sensitive data... OK Directory "C:\Documents and Settings\Unlock Teritory\Desktop\Furious Gold Box\Pack 7\HUAWEI_ANDROID_UNLOCKER_0034\Backup" not found! Creating backup directory "C:\Documents and Settings\Unlock Teritory\Desktop\Furious Gold Box\Pack 7\HUAWEI_ANDROID_UNLOCKER_0034\Backup"... failed! Backup directory set to default! ("C:\Documents and Settings\Unlock Teritory\Desktop\Unlock Teritory\Furious Gold Box\Pack 7\HUAWEI_ANDROID_UNLOCKER_0034\Backup")OK Creating backup of Sensitive Data... OK Backup saved to file "C:\Documents and Settings\Unlock Teritory\Desktop\Unlock Teritory\Furious Gold Box\Pack 7\HUAWEI_ANDROID_UNLOCKER_0034\Backup\863759010073036_2013-04-17_122311.fhb" Sending data to server... OK Reading data from server... OK Writing flash... OK Reseting unblock retry counter... OK Sending data to server... OK Reading data from server... OK Disconnecting from server... OK 2013-04-17 12:23:13.605 Done! Code: Searching Huawei phone COM ports... OK Application port: COM78 Diagnostics port: COM79 Checking bootloader status... not running! Connecting to server... OK Sending data to server... OK Reading data from server... OK Sending data to server... OK Reading data from server... OK Sending data to server... OK Reading data from server... OK Uploading bootloader... OK Waiting phone to be ready ... OK Starting bootloader... OK Disconnecting from server... OK Initializing flash... OK Reading phone info... OK Decrypting IMEI... OK Reading sensitive data... OK Model name: Huawei U8185/U8655 IMEI: 863759010073036 SIM Lock status: not locked |
The Following User Says Thank You to chris2007 For This Useful Post: |
