12-19-2014, 23:15 | #3 (permalink) |
No Life Poster Join Date: Feb 2007
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | Select "ZTE/Acer/Lenovo/Huawei/HTC MTK Android (USB)" check "PERFORM DIRECT UNLOCK" Press "READ CODE(S)" Connect phone to usb (phone must off) driver will search for driver (if you install drivers from support area) then it done! Code: Searching phone; Phone detected (@oem82.inf,%vcom_preloader%;PreLoader USB VCOM (Android)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Gadget VCOM Driver (COM5); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6572, E01 Sw version: MOLY.WR8.W1315.MD.WG.MP.V1.P13.T1 Hw Version: ZTENJ72_WE_JB3_HSPA_HW Reading phone info; IMEI: 862773-02-725724-4 Reading simlock info; Locked to: 001-01 code_cat_n: 12345678 enabled: yes tries: 10 code_cat_ns: 56781234 enabled: no tries: 10 code_cat_sp: 11112222 enabled: no tries: 10 code_cat_c: 33334444 enabled: no tries: 10 code_cat_sim: 55556666 enabled: no tries: 10 code_cat_ns_sp: 77778888 enabled: no tries: 10 code_cat_sim_c: 99990000 enabled: no tries: 10 Time needed - 00:00:37 |
The Following User Says Thank You to chris2007 For This Useful Post: |
