10-28-2014, 23:37 | #1 (permalink) |
Insane Poster Join Date: Sep 2014
Member: 2259339 Status: Offline Thanks Meter: 7 | Help unlocking blu dash 3.5 [SOLVED] I found in one of the threads that i should use pack 6's mtkreader, but i dont get how to connect the phone, to the box with serial or usb, wich cable should i use, or i should connect to the computer. Must it be in download mode? Thanks, if there is a video will be great, i searched for it but i didnt found anything. |
10-29-2014, 11:18 | #2 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
Phone must be powered off, you press connect and then you connect the phone to usb br | |
10-29-2014, 12:06 | #3 (permalink) |
Member: 2259339 Status: Offline Thanks Meter: 7 | ok, i tried that but nothing happends, would you mind to explain it a bit better? Where i should connect the phone, to computer or box? Does the lateral switch must by in a special position? Should i use one of the cables you sent me? Which program you used? There is no connect button in mtkreader. |
10-29-2014, 13:35 | #4 (permalink) | |
To the usb cable that goes attached to the computer usb. READ CODE(s) is the connect button. And switch position has no meaning since i told to use the USB cable. Switch changes voltage of pin 5 of the rj45 socket. I suggest that for such questions to add me on skype. | |
10-29-2014, 20:38 | #6 (permalink) |
Member: 2259339 Status: Offline Thanks Meter: 7 | i still cant unlock blu dash, i tried what you said but i get this error: Searching phone; ERROR: Device not found ! Time needed - 00:00:24 Im using the latest full installer downloaded from your web. I tried to unlock with mtkreader using zet/acer/lenovo/huawei MTK Android and huawei/doro/verykool/blu/aeg mtk. Im using the original cable that comes with the phone connected to an usb in the computer, i tried with the phone on and off with the same result. |
10-30-2014, 08:38 | #7 (permalink) | |
br | |
10-31-2014, 11:47 | #10 (permalink) |
Member: 2259339 Status: Offline Thanks Meter: 7 | Ill try to explain, he did all remotely, but it seems that i needed this drivers: ALCATEL_MTK6573_Android_Unlock_Drivers; Alcatel_OT-4010x_Vodafone_875_975_StarTrail3_Android_Gadget_C DC_driver; usb_driver Before that installation i wasnt able to detect any phone, now i unlock easily Huawei, Alcatel and Blu. Ok, do not plug the phone untill needed, the steps where: 1. Install the above mentioned drivers. 2. Open the mtkreader in pack 6, and used the option ZTE/ACER/LENOVO/HUAWEI MTK Android (USB) 3. Check PERFORM DIRECT UNLOCK 4. Click READ CODE(S) 5. Plug the powered off phone to a free usb port in your computer. Use a standar usb/microusb cable. 6. It should detect the phone and perform the direct unlock 7. When the process is finished the phone will be frozen in the logo screen, just remove and insert battery. 8. Thats it. You've unlocked a Blu Dash 3.5 phone. If you need more detail just ask. Ill try to improve the explanation if needed. Last edited by ibritez; 10-31-2014 at 11:54. |
The Following 3 Users Say Thank You to ibritez For This Useful Post: |
11-21-2014, 16:20 | #11 (permalink) |
Insane Poster Join Date: Jan 2005 Age: 47
Member: 106234 Status: Offline Thanks Meter: 7 | 100% unlocked blu dash 5.0 with mtk code reader, here log: Searching phone; Phone detected (@oem359.inf,%mtk_preloader%;PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Gadget VCOM Driver (COM81); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6572, E01 Sw version: D620_BLU_BMOBILE_SML_MP_D1A_V1.0.1_S0523 Hw Version: RATECH72_WET_RGK_JB3_HSPA_HW Reading phone info; IMEI: 359395-05-xxxxxx-8 Reading simlock info; Locked to: 374-12 code_cat_n: 12345678 enabled: yes tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Time needed - 00:00:31 thx to .:hack3r2k:. |
The Following User Says Thank You to abibulaf For This Useful Post: |
