10-17-2019, 10:33 | #1 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Budapest Age: 54
Member: 87188 Status: Offline Thanks Meter: 226 | Honor 8S KSA-L09 dead after remove FRP [SOLVED] Searching phone in normal mode; [connect the phone powered off to the usb cable with testpoint connected] Phone detected (MediaTek USB Port (COM67)) Preparing to start flash mode; Preparing to open COM67 Connecting; Downloading DA; Initializing; Rid: 2bc86f17736f240ecc37fd1f69151460 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6761 [CA01, 200, 6761, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333644 0x6D040142 0xD1367E68 [SIZE=0x749400000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xEE000000 SIZE: 0x659A00000 Contents saved to : C:\Program Files\FURIOUS-GOLD\PACK6\OTSmart\HUAWEI HONOR 8S_IMEI_FE6C8360_605DDFBB_2bc86f17736f240ecc37fd1f 69151460_17_10_2019_10_36_30.osp Downloading images... Done; Searching phone; (insert the USB cable in the powered off phone) Phone detected (MediaTek PreLoader USB VCOM (Android) (COM28)) Preparing to start fastboot mode; Done; Fastboot mode entered; Connecting; switching_fastboot_mode: OK; resistance is futile : OK !?; data_written : OK; data_written : OK; data_written : OK; data_written : OK; data_written : OK; data_written : OK; data_written : OK; data_written : OK; Factory Reset Protection successfully removed ! Time needed - 00:01:44 Stayed only recovery mode:-( Factory reset or recovery phone over network failed. Backup file: HUAWEI HONOR 8S_IMEI_FE6C8360_605DDFBB_2bc86f17736f240ecc37fd1f 69151460_17_10_2019_10_36_30.osp how to get back? Which particion? Files from support: Katyusha-L29B 9.0.1.107(C431E5R1P4)_Firmware_9.0.0_r3_EMUI9.0.1_ 05015VWJ.osp download 12 hours via 1000/500 digi network Please help what to do in this case? |
10-17-2019, 10:37 | #2 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
Br | |
10-17-2019, 10:37 | #3 (permalink) | |
Br | |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
10-17-2019, 15:03 | #4 (permalink) |
Member: 87188 Status: Offline Thanks Meter: 226 | I'm starting to get scared:-( OTSMART: Katyusha-L29B 9.0.1.107(C431E5R1P4)_Firmware_9.0.0_r3_EMUI9.0.1_ 05015VWJ.osp Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable with testpoint connected] Phone detected (MediaTek USB Port (COM67)) Preparing to start flash mode; Preparing to open COM67 Connecting; Downloading DA; Initializing; Rid: 2bc86f17736f240ecc37fd1f69151460 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6761 [CA01, 200, 6761, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333644 0x6D040142 0xD1367E68 [SIZE=0x749400000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x14E800000 SIZE: 0x5F9200000 Loading the file ... Cfg done ... Downloading bootloader... Done; ERROR: STATUS_DOWNLOAD_EXCEPTION Time needed - 00:08:04 Log file saved to: LOG_17_10_2019_15_20_40.txt Fly Captain, orig files Katyusha-L09B 9.0.1.114(C431E2R2P4)_Firmware_9.0.0_r3_EMUI9.0.1_ 05015VPC: ly Captain Huawei Resurrector 0.0.0.35 user:E3041E27 Looking for a device in upgrade mode COM186: Android Adapter PCUI (COM186) COM187: DBAdapter Reserved Interface (COM187) 10/17/2019 3:55:52 PM Starting to write device in UPGRADE mode... Device found: 3PQNU19513210485 Slowdown NOT selected SlowDownElapsedTime setted to 0 msecs. 10/17/2019 3:55:55 PM start to write update file File to update: UPDATE.APP File size: 2,678,639,988 bytes Current version(BASE_VER): KSA-LGRP2-OVS 9.0.1.67 Process identifier:4742525 Validating file... Detecting port... Preparing to write... Device does not support this update file Error writing software 10/17/2019 3:56:12 PM Writing device finished with ERROR |
10-17-2019, 15:05 | #5 (permalink) |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Downloading bootloader... Done; ERROR: STATUS_DOWNLOAD_EXCEPTION Time needed That means wrong drivers installed. Must be 3.1504. Is written on the damn notes jobody cares to read ! And flashing you do using otsmart only SPECIAL NOTE1: If you are using windows 10 x64 be sure that the installed mtk driver version is 3.0.1504 . Any different drivers will create random read bugs on newer chipset phones. As usual the correct drivers come inside OTSMart archive inside the 'usb_driver' folder SPECIAL NOTE2: For HONOR 8A / HONOR 8S / Y5 2019 / Y6 2019 series in case the phone doesnt power on correctly after FRP / IMEI REPAIR you have to flash the phone using the firmware from the support. Is not important which variant of phone you have . One flash works fine for all ! |
10-17-2019, 16:54 | #6 (permalink) |
Member: 87188 Status: Offline Thanks Meter: 226 | Unlock (successfully) and after write imei unsuccessfully, not detected in fastboot (previously yes) Phone is completely dead Flashing same Katyusha-L29B 9.0.1.107(C431E5R1P4)_Firmware_9.0.0_r3_EMUI9.0.1_ 05015VWJ.osp sucessfully: Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable with testpoint connected] Phone detected (MediaTek USB Port (COM67)) Preparing to start flash mode; Preparing to open COM67 Connecting; Downloading DA; Initializing; Rid: 2bc86f17736f240ecc37fd1f69151460 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6761 [CA01, 200, 6761, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333644 0x6D040142 0xD1367E68 [SIZE=0x749400000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x14E800000 SIZE: 0x5F9200000 Loading the file ... Cfg done ... Downloading bootloader... Done; Downloading images... Done; Success; Time needed - 00:07:19 Log file saved to: LOG_17_10_2019_16_47_02.txt Phone work, unlocked and imei original. Not understand but all is well if the end is good Thanks. |
