06-10-2009, 22:39 | #1 (permalink) |
No Life Poster Join Date: Mar 2001 Location: Croatia Age: 45
Member: 3508 Status: Offline Thanks Meter: 71 | How to findout which flash is in the KU990!? Phone doesnt start, after LG logo it turns off, I can put it in emergency download mode!! Phone is from Croatia and TELE2 network but with which flash can I flash!? BR |
06-13-2009, 00:59 | #3 (permalink) |
Member: 3508 Status: Offline Thanks Meter: 71 | I flashed phone in emergency mode with KU990-BINARIES-V10a-JAN-25-2008-ERA-PL.sex and got yellow screen with refreshing on it! After that I tried with KU990-BINARIES-V10c-JAN-08-2008-OPN-EU+1.sex and now I got yellow screen with Unavalaible OTP block!! Which file to flash!?!? Phone was only showing LG logo so I could not see the version before flash!! And here is log (I deleted some part in log uploading files and directories to short the post, whole log is in the attachment): Searching phone ... MODEL : KU990 COMPILED DATE : Jan 25 2008 10:52:00 RELEASE DATE : Oct 5 2007 17:00:00 FIRMWARE INFO : KU990-MSM6280-V10a-JAN-25-2008-XX IMEI : 35994402343128-7 BLUETOOTH ADDR : 00 21 FB 9D 78 F7 MEMORY ID : 0098:00CA MEMORY NAME : toshiba_tya000bc00bogg MEMORY SIZE : 223MB INIT FLASHING ENGINE ... OK; READING NV ... READY... UPLOADING STARTED; WORKING IN NORMAL MODE; RESETTING PHONE ! WAITING 25s PHONE TO WAKE UP; PHONE ONLINE; EFS ERASING; RESETTING PHONE ! WAITING 25s PHONE TO WAKE UP; PHONE ONLINE; Deleting folder : /LGAPP/Media/Common/Battery Deleting folder : /LGAPP/Media/Common/Logo Deleting folder : /LGAPP/Media/Common/SubLCD Deleting folder : /LGAPP/Media/Common Deleting folder : /LGAPP/Media/Images/Default images Deleting folder : /LGAPP/Media/Images Deleting folder : /LGAPP/Media/MMS Deleting folder : /LGAPP/Media/Midis Deleting folder : /LGAPP/Media/Multi Deleting folder : /LGAPP/Media/Others Deleting folder : /LGAPP/Media/Pafs Deleting folder : /LGAPP/Media/Playlists Deleting folder : /LGAPP/Media/Skins Deleting folder : /LGAPP/Media/Sounds/Voice recordings Deleting folder : /LGAPP/Media/Sounds Deleting folder : /LGAPP/Media/ThumbImages Deleting folder : /LGAPP/Media/Videos Deleting folder : /LGAPP/Media FOLDER MISSING. ERASE OF /LGAPP/ FAILED. Deleting folder : /LGAPP/Temp Writing : /LGAPP/Common/Planet3.bmp Writing : .... .... .... Writing : /UPLOAD/Pxo/WorldClock.pxo Writing : /UPLOAD/Pxo/Xdl.pxo Writing : /UPLOAD/Pxo/Version RESETTING PHONE ! WAITING 130s PHONE TO WAKE UP; PHONE ONLINE; KU990 NV FILE VERSION 2 WITH 817 RECORDS. WRITING NV ... RESETTING ... WAITING 25s PHONE TO WAKE UP; PHONE ONLINE; Error ... ! Time needed - 01:12:49 |
The Following User Says Thank You to GSMBlade For This Useful Post: |
06-13-2009, 01:19 | #4 (permalink) |
Freak Poster Join Date: Nov 2008
Member: 895524 Status: Offline Thanks Meter: 33 | dude there are about 4 kinds for LG viewty u990 ku990 ku990go ku990i i remember flashing the ku990go with ku990 file and it ended up with the yellow screen. i would only say keep trying if u didnt know what model it it but check the back that it is not a u990. |
06-13-2009, 01:58 | #5 (permalink) | |
Member: 3508 Status: Offline Thanks Meter: 71 | Quote:
I will try with other flash!! BR | |
06-13-2009, 03:10 | #6 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Melbourne / Australia Age: 47
Member: 177834 Status: Offline Thanks Meter: 1,800 | if fone shows Unavalaible OTP block after flashing then run LG amdo on pack 5 do restore, use ku990 bin file repair with original imei unlock next time read F.A.Q. |
The Following User Says Thank You to ::.imeimate.:: For This Useful Post: |
06-13-2009, 10:09 | #7 (permalink) |
Product Supporter Join Date: Sep 2004 Age: 39
Member: 81703 Status: Offline Thanks Meter: 1,332 | Also, we will check if there is something wrong, it should take like 30 minutes to flash this phone not one hour. Well at least we know that it's a KU990. I recommend you to flash it with a newer flash file from support area. As far as I remember you can have there v10i. In some LG phones if you don't write new version you have this kind of problems (like KE500, KE850...). If you have PACK5 try first the Imeimate answer as it will take less time. If not first, download again QFG from support area and update PACK1 to be sure that there is no issues with the flashing situation BR Luskao |
The Following User Says Thank You to luskao For This Useful Post: |
06-15-2009, 15:59 | #8 (permalink) | |
@ ::.imeimate.:: I don't have pack 5!! @ luskao OK, I will try with other flash!! I will download again QFG, but I think that I did that before flashing, because to be shure that I'm using the latest version!! BR | |
06-17-2009, 23:48 | #9 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
Br | |
06-18-2009, 23:49 | #10 (permalink) | |
But I flashed it with original LG flasher and this file: KU990-DZ-V10a-SEP-04-2008-TLK-HR.dz and phone turned on but with no network, so I wrote in NV file: KU990_Rev1.0_V05_070828.nv2 and phone was OK!! BR | |
how to discover which mxkey is cloned and which is original!!!! | ARC | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 10-06-2009 15:01 |
How to find which cpu use in china phones to see logos | gunjan1 | SpiderMan | 2 | 08-08-2008 17:56 |
how to know which languages are in flash files? | yakety | Nokia Base Band 5 ( BB-5 ) | 3 | 02-07-2008 12:19 |
how to check which version is in LG U890 | buqki | FuriousGold | 2 | 01-12-2008 09:42 |
how to know which flash is red which one brown | after89 | SonyEricsson (USB-Smart) | 0 | 05-12-2006 05:40 |
