Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > FuriouS TeaM Products
FuriouS TeaM Products FuriouS GOLD Support Area
Old 09-27-2012, 09:27   #1 (permalink)
.:hack3r2k:.'s Avatar
Member: 15022
Sonork: 100.53452
Smile HOW TO FIX V860/VODAFONE Smart 2 NOT ACCEPTING CODES !
Hi,
I normally hate to clean trash after others but this time i will do an exception just because this crap showed up on my sweet little dirty country and my sweet many customers might get pissed on that
TOOL:
1. FASTBOOT GET HERE
2. FACTORY FILES GET HERE
2.1
UF149090.img
LF149090.img
BF149090.img
3. FASTBOOT DRIVERS
HOW TO USE:
TO ENTER FASTBOOT MUST PRESS VOLUME DOWN + CONNECT USB CABLE
fastboot flash recovery RF149090.bin
fastboot flash boot BF149090.img
fastboot flash bootloader LF149090.img
fastboot flash system SF149090.bin
fastboot flash userdata UF149090.img
fastboot -w
fastboot reboot
That's all. After read code again and this time will be accepted. Don't use this unless you have to. You will loose everything from phone including the android lock So be warned
Best regards,
FuriouSTeaM
The Following 17 Users Say Thank You to .:hack3r2k:. For This Useful Post:
Old 09-27-2012, 12:45   #2 (permalink)
Member: 1751722
image links not working plz check once its very urgent ....
Old 09-27-2012, 13:05   #3 (permalink)
Member: 1645194
pleas upload files on mediafire server is better
Old 09-27-2012, 13:41   #4 (permalink)
Member: 15022
Sonork: 100.53452
they work very well. i tested. i dont have time to upload to other place today
br
Old 09-27-2012, 14:37   #5 (permalink)
Member: 1751722
after flash this files CODE Accepted phone Unlocked but it says setup com error and unable to load display ..... than i flash with 2.3.7 uk version it will ask code again use 00000000 now everything is ok phone works perfect procedure flash is from XDA developer here is link .......
roeddie v0.8 Vodafone Smart II Alcatel v860 Latest ROM with ROOT and Vodafone UPDATES - xda-developers
fastboot-windows.exe flash bootloader bootloader.img
fastboot-windows.exe flash boot boot.img
fastboot-windows.exe flash system system.img
fastboot-windows.exe flash recovery recovery.img
fastboot-windows.exe flash custpack custpack.img
fastboot-windows.exe flash userdata data.img
fastboot-windows.exe reboot
UK alcatel-onetouch.rar
The Following 4 Users Say Thank You to .::GSMUnlock::. For This Useful Post:
Old 09-27-2012, 14:40   #6 (permalink)
Member: 1751722
Originally Posted by .:hack3r2k:. View Post
they work very well. I tested. I dont have time to upload to other place today
br
links are working perfect just download after finisdh once
Old 09-27-2012, 19:31   #7 (permalink)
Fast Unlocker's Avatar
Member: 95960
Sonork: 100.1574721
Romanian People are Genius everybody knows that
The Following 2 Users Say Thank You to Fast Unlocker For This Useful Post:
Old 09-28-2012, 00:01   #8 (permalink)
Member: 1107289
Post
Nice Update
Thanks FuRiOuSGOLD_TeAm
Old 10-04-2012, 13:09   #9 (permalink)
Member: 273834
pls i dont understand the steps
Old 10-04-2012, 13:28   #10 (permalink)
Member: 273834
am i suppose put d files on memory card?
Old 10-04-2012, 20:49   #11 (permalink)
Member: 43216
run....cmd..and then copy comand from first post
download the files in the folder that executes commands
it works 100%
Old 10-05-2012, 14:48   #12 (permalink)
totmititelu's Avatar
Member: 880649
URAAAAA
after flashing... becouse it don't accept 8times0
Attach the phone to the USB now ...
Phone found on COM165 and initialized;
Reading imei;
IMEI: 862924-01-34917X-X
Reading data;
Log saved: 3AEBF898394CE77485CE3383A5CDC2DB.bin
Enter an restricted sim and use as unlock code : 00000000 (8 times 0)
NOTE: For ZTE models enter *983*258# in order to be able to input code
SIM_LOCK REMOVED !
Resetting the target ...
Time needed - 00:00:11
Old 10-10-2012, 19:54   #13 (permalink)
dragosgsm's Avatar
Member: 148032
Question
it works 100%
can someone please post detailed procedure?
Old 10-10-2012, 22:04   #14 (permalink)
dragosgsm's Avatar
Member: 148032
Question
Hi,
TOOL:
2.1
UF149090.img
LF149090.img
BF149090.img
3. FASTBOOT DRIVERS
HOW TO USE:
fastboot -w
fastboot reboot
Best regards,
FuriouSTeaM
can someone please be more explicit of how to use these files???????
Old 10-13-2012, 08:14   #15 (permalink)
Member: 1648084
1.DOWNLOAD SMART2.RAR FROM: smart2.rar - 4shared.com - online file sharing and storage - download
2.TO ENTER FASTBOOT MUST PRESS VOLUME DOWN + CONNECT USB CABLE,
3.RUN SMART2.BAT, WAIT FOR FLASH TO END
4.connect phone to usb cable WITHOUT BATTERY AND INSTALL DRIVERS
5.start BRCMREADER.exe and follow instructions
Good luck!
The Following 2 Users Say Thank You to empirion For This Useful Post:
Page generated in 0.37691 seconds with 10 queries
