03-02-2011, 14:58 | #1 (permalink) |
Freak Poster Join Date: Jul 2005 Location: Pak Age: 45
Member: 162328 Status: Offline Sonork: 100.1618216 Thanks Meter: 21 | How Flash LG KP500 where can i find flasher for flashing and files plz help me |
03-02-2011, 15:50 | #3 (permalink) |
No Life Poster Join Date: Sep 2005 Location: near Network Age: 48
Member: 185608 Status: Offline Thanks Meter: 592 | Here is my help! |
The Following User Says Thank You to Nadjombe For This Useful Post: |
03-03-2011, 10:58 | #6 (permalink) | |
Member: 185608 Status: Offline Thanks Meter: 592 | ?????? Quote:
Even though,i will continue to explain you more. To resume here is step by step: Tutorial (step by step) How to flash LG KP500 - cookie In this tutorial you will see how to flash lg cookie with new firmware. 1.) BACKUP - First off all you should make a backup of your phone files (contacts, messages ...) because after flashing, all the files saved on the phone will be erased. I recommend that you use LG PC SuiteII. - Dont forget to unplug your phone. 2.)DOWNLOAD GSMULTI AND FIRMWARE FIRMWARE LG KP500 KP500AT-00-V10n-DEC-17-2008 (v10N) NEW! http://www.filefactory.com/file/a03f...N_Firmware_rar FLASHER LG - MultiGSM ver 3.0 + kp500 .dll file http://www.filefactory.com/file/a03g...SMULTI_V30_rar 3.)INSTALL THE SOFTWARE AND DRIVERS - DRIVERS WORKS ONLY ON XP WINDOWS (Don't connect your phone on computer yet) Downloaded files should be un-ziped (I unziped them in one folder which i made it on desktop) You got next files: program - SETUP_GSMULTI_V30 - KP500_081002.dll firmware - KP500AT-00-V10n-CIS-XXX-DEC-17-2008 - KP500AT-00-V10n-CIS-XXX-DEC-17-2008.bin.mbn 3.1.) Install GSMULTI (SETUP_GSMULTI_V30). The icon will shows on your desktop otherwise the program install on C disk, folder GSMULTI - start GSMULTI - select: Settings/Configuration - put .dll file and firmware file in and choose USB then click OK and close program [ 3.2.)Install DRIVERS (INFINEON and TI_NEPTUNE) Drivers to be found in install folder of GSMMULTI program. My path is C:\GSMULTI\UsbDrivers - First install INFINEON - Second TI_NEPTUNE 4.) PREPARE AND CONNECT YOUR PHONE - Now u take a phone (shut it down) and remove, BATTERY, SIM CARD and MEMORY CARD then - conect it with your USB cable to computer (I suggest that u connect only in one USB port on computer) - wait about one minute that comuputer recognize new device 5.) USBMap PROGRAM - Run program USBMap_V01 (which can be found in C:\GSMULTI) - Select INFINEON and then click MAPPING START -WAIT (about one minute) that USBMAP will find USB port where is the phone connected - When the port will be found click on (select it) and press SAVE&EXIT 6.)MAIN PART - FLASHING - Run GSMULTI program (shourtcut is in your desktop) - Check if settings/configuration are the same like we set it before (otherwise look step 3.1.) - Now its everything ready to start flashing - Check MODEL and SW VERSION and if that is correct just click START and wait until the program finished | |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
