11-15-2017, 08:19 | #2 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | Must connect it in FTM mode and use latest update of pack 5 Br |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
11-15-2017, 10:43 | #3 (permalink) | |
No Life Poster Join Date: Dec 2015 Location: hossting
Member: 2501288 Status: Offline Thanks Meter: 328 | Quote:
Software engine version: 1.0.0.10603 Searching phone ... MODEL : QCOM SERIES 54 COMPILED DATE : Sep 25 2017 00:10:00 RELEASE DATE : May 7 2017 21:00:00 FIRMWARE INFO : MPSS.TA.2.3.c1-00307-8953_GEN_PACK-1.95386.1.98068.3 IMEI : 3581240xxxxxxxxx BLUETOOTH ADDR : 00 00 00 00 00 00 FIRMWARE: ES_S_VDF_P840V70V1.0.1B22 close_event_report: OK; close_log_report: OK; close_message_report: OK; closing_com_port: OK; Starting the backup process; connect_server: OK; backup in progress: OK; Backup saved to: D:......358124xxxxxxx_15_11_2017_09_38_37.bkp switching_download_mode: OK; closing_com_port: OK; Preparing to open COM7 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22E9 start_frp_reset: OK; frp_reset: OK; | |
11-15-2017, 16:21 | #4 (permalink) |
Freak Poster Join Date: May 2010 Location: peterhead
Member: 1302378 Status: Offline Thanks Meter: 5 | Connecting; Check your phone and "Always allow from this computer" and select "OK". Connected; BRAND: VODAFONE MODEL: VFD 710 ANDROID: v7.1.1 CPU: QCOM IMEI: NA KERNEL: Linux version 3.18.31-perf (wsys@SCL-2SH203) (gcc version 4.9 20150123 (prerelease) (GCC) ) #1 SMP PREEMPT Fri Jun 30 14:25:40 CST 2017 ERROR: Unknown/unsupported brand ! Log file saved to: LOG_15_11_2017_15_17_42.txt Time needed - 00:00:07 unlocking any solution |
11-15-2017, 17:36 | #5 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | Quote:
11-16-2017, 14:55 | #8 (permalink) |
Major Poster Join Date: Oct 2007 Location: Czech Republic
Member: 618649 Status: Offline Thanks Meter: 12 | Hi, I cant remove FRP too, any ideas? Tried two different PCs, always getting "timeout error". Drivers OK. Code: Software engine version: 1.0.0.10603 Searching phone ... MODEL : QCOM SERIES 54 COMPILED DATE : Jun 29 2017 19:21:00 RELEASE DATE : Apr 13 2017 23:00:00 FIRMWARE INFO : MPSS.TA.2.3.c1-00307-8953_GEN_PACK-1.95386.1 IMEI : 35812408014078-9 BLUETOOTH ADDR : 00 00 00 00 00 00 FIRMWARE: CZ_S_VDF_P840V70V1.0.4B15 close_event_report: OK; close_log_report: OK; close_message_report: OK; closing_com_port: OK; Starting the backup process; connect_server: OK; backup in progress: OK; Backup saved to: ********\35812408014078_16_11_2017_14_47_42.bkp switching_download_mode: OK; closing_com_port: OK; ERROR: Timeout waiting for the phone; Log file saved to: LOG_16_11_2017_14_50_51.txt Time needed - 00:03:13 |
11-16-2017, 15:21 | #9 (permalink) |
Member: 618649 Status: Offline Thanks Meter: 12 | Oh, got it working. FYI, you need English version of Windows for Qcom Smart tool to run correctly Code: Software engine version: 1.0.0.10603 Searching phone ... MODEL : QCOM SERIES 54 COMPILED DATE : Jun 29 2017 19:21:00 RELEASE DATE : Apr 13 2017 23:00:00 FIRMWARE INFO : MPSS.TA.2.3.c1-00307-8953_GEN_PACK-1.95386.1 IMEI : 35812408014078-9 BLUETOOTH ADDR : 00 00 00 00 00 00 FIRMWARE: CZ_S_VDF_P840V70V1.0.4B15 close_event_report: OK; close_log_report: OK; close_message_report: OK; closing_com_port: OK; Starting the backup process; connect_server: OK; backup in progress: OK; Backup saved to: ***\35812408014078_16_11_2017_06_16_18.bkp switching_download_mode: OK; closing_com_port: OK; Preparing to open COM15 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22E9 start_frp_reset: OK; frp_reset: OK; Log file saved to: LOG_16_11_2017_06_19_28.txt Time needed - 00:03:14 |
11-21-2017, 08:33 | #11 (permalink) | |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | Quote:
Has nothing to do with the language of your os. If you get "Timeout waiting for the phone;" its because qdl loader is installed as nokia care/connectivity driver so you have to find that , right click and install the drivers Br | |
