01-18-2016, 12:13 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: INDIA Age: 43
Member: 75612 Status: Offline Thanks Meter: 1,427 | HOW TO UNLOCK alcatel one touch fierce xl 5054N |
The Following User Says Thank You to rajan nishchal For This Useful Post: |
01-18-2016, 13:01 | #2 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Root the phone, enable diag, unlock via diagnostic port Br |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
01-18-2016, 22:02 | #3 (permalink) | |
Crazy Poster Join Date: Nov 2008
Member: 900802 Status: Offline Thanks Meter: 156 | kingroot apk work last version enable diag work unlock no work in alcatel fierce xl (5054N) log Quote:
01-27-2016, 03:28 | #6 (permalink) |
Major Poster Join Date: Mar 2010 Location: Miami, Fl
Member: 1254395 Status: Offline Thanks Meter: 4 | update: Got the adb driver to work by forcing it from the OT993 driver from support. Still no luck getting a comm port. Kingo root failed to root it as well. Any ideas more than welcome. I see too little to no info out there about this model. |
01-27-2016, 04:11 | #7 (permalink) |
Member: 1254395 Status: Offline Thanks Meter: 4 | update 2: Also forced the com port driver into the phone and worked fine. Tried qcomm smart tool, firehorse mode (vol up & down) and it recognized the phone but didn't worked either. Here is the log: Connect the phone powered off with both volume down and up pressed; Phone detected (@oem123.inf,%qcomdevice90080%;RELINK HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM75 Connecting; Loading; Init; Port opened; ERROR: Boot loading failed; Log file saved to: LOG_26_01_2016_22_09_01.txt Time needed - 00:00:14 |
01-28-2016, 08:13 | #8 (permalink) | |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
You have the wrong drivers installed ! RELINK HS-USB QDLoader 9008. Must use the alcatel ones ! Br | |
01-28-2016, 10:33 | #9 (permalink) |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | Failed even with Alcatel drivers, but at least it shows "Hello Received;" Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem573.inf,%qcomdevice90080%;ALCATEL HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM3 Connecting; Loading; Init; Port opened; Hello Received; ERROR: Boot loading failed; Log file saved to: LOG_28_01_2016_04_16_20.txt Time needed - 00:00:02 |
01-28-2016, 18:26 | #10 (permalink) | |
Member: 1254395 Status: Offline Thanks Meter: 4 | Quote:
Tried with right driver, same answer: Connect the phone powered off with both volume down and up pressed; Phone detected (@oem120.inf,%qcomdevice90080%;ALCATEL HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM75 Connecting; Loading; Init; Port opened; ERROR: Boot loading failed; Log file saved to: LOG_28_01_2016_12_20_58.txt Time needed - 00:00:14 This time the phone is even rooted. I checked trough cmd and it gained superused status and everything. Some help here would be greately appreciated. Remember my model is the 5054W from T-Mobile | |
01-31-2016, 09:46 | #11 (permalink) | |
Can arrange such model to be sent yo us ? We will pay it Br | |
02-14-2016, 13:24 | #12 (permalink) |
Freak Poster Join Date: Nov 2006 Location: Nairobi,Kenya
Member: 390521 Status: Offline Thanks Meter: 57 | TCL 5054N Metro-Pcs (Fierce XL) Device Locked. Normal mode..Diag Mode..Rooted Software engine version: 1.0.0.9830 Searching phone ... MODEL : QCOM SERIES 48 COMPILED DATE : Oct 4 2015 16:51:00 RELEASE DATE : Sep 30 2015 08:00:00 FIRMWARE INFO : MPSS.JO.1.0.c5.2-00018-M8909EAAAANVZM-1 IMEI : 0144xxxxxxxxxxxx BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; Error ... Error ... ! Log file saved to: LOG_14_02_2016_15_16_26.txt Time needed - 00:00:24 Firehorse Mode Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@usb.inf,%usb\composite.devicedesc%;USB Composite Device) Preparing to enter download mode; Preparing to open COM169 Connecting; Init; Port opened; Phone detected (@oem197.inf,%qcomserialportdesc90080%;Android HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM71 Connecting; Loading; Init; Port opened; Hello Received; ERROR: Boot loading failed; Log file saved to: LOG_14_02_2016_15_19_26.txt Time needed - 00:00:29 |
02-14-2016, 21:08 | #13 (permalink) | |
This model is already supported. Contact me for tests on skype Br | |
