Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > FuriouS TeaM Products
FuriouS TeaM Products FuriouS GOLD Support Area
Old 02-28-2010, 21:28   #1 (permalink)
Member: 665242
How to work with 2-3 boxes simultaneously!
As you all know using more then 1 unlocking/flashing tool is not possible. I tried many times to make working in the same time, JAF, FURIOUS and UBBOX for example but i didn;t succed because almost all box producers are using the same ftdi drivers and the same port .
Of course one of the option is to install VMware and use one box per one image installed in you pc but for that you need a NASA pc since you need to use 10boxes at a time.
So, my question is..how we can make to work in the same time more devices? i want to flash somthing with JAF and unlock with Furious in the same time. Anyone had succed ? si there any chance to resolve this at least for FG?
Thank you
Old 02-28-2010, 21:50   #2 (permalink)
Max_B's Avatar
Member: 16856
Sonork: 1582037
For FG you can open multiple exes from the same pack at the same time
Also you will have to connect several comport cables or boxes, all is possible!
eg. Open 2 TOSHIBA modules and service two phones at a time COM1 + COM2
For Jaf this is not possible, because of ****ty protection, UB only one per computer !
Max_B
Old 02-28-2010, 22:04   #3 (permalink)
dawah telecom's Avatar
Member: 868940
Thank you
This is nice info to me....cos am using any box on my pc at any time even with 3-4 boxes without install anything...but to my surprise am using it as usual one day immediately i plug polar box to other 3 boxes on pc....the driver of the box now conflict and my pc hang up.....now since then 4 usb port is not working on my pc again till date....and i dont know how to solve the problem sice then...
if anyone can help me out...i'll be appriciate.
regards.
Old 02-28-2010, 22:06   #4 (permalink)
Max_B's Avatar
Member: 16856
Sonork: 1582037
regards.
WINDOWS = SHIIT
Max_B
Old 02-28-2010, 22:14   #5 (permalink)
Member: 868940
Originally Posted by Max_B View Post
WINDOWS = SHIIT
Max_B
what you mean by this.....bro, explain more
Old 02-28-2010, 22:15   #6 (permalink)
Temporary banned !!
Member: 252220
Sonork: 100.1606995
im working at the same computer with this box at the same time: setool, jaf, furious gold and ustpro2 without installing any other softwar, just change the comport for box, it means give to box a specific comport number, so all be ok and no conflit on pc, its better to install ustpro first
Old 02-28-2010, 22:25   #7 (permalink)
Member: 868940
but now, 4 usb port is no more working......with other two that is working.
Old 02-28-2010, 22:40   #8 (permalink)
Member: 868940
any more help.....????????
Old 02-28-2010, 23:56   #9 (permalink)
Aishur's Avatar
Member: 28188
Max_B
Different EXEs from different packs should work too at the same time
Old 03-01-2010, 00:46   #10 (permalink)
maya's Avatar
Member: 19423
Sonork: 69566
first you need to know dongel protection driver
exp setool: Axalto-egate-drivers
FG : Rokey 5
EUB: rokey 5
expl: FG and EUB dont use it at same port you kill smart card
FG an jaf mybe worcking you need to see device info about comport use'it
USB1 USB2, on your computer
most have conflit if you plug more device the power comsuption is low and device not work perfectly
The Following User Says Thank You to maya For This Useful Post:
Old 03-01-2010, 01:15   #11 (permalink)
.:CARLO:.'s Avatar
Member: 126086
Sonork: 100.113901
iam using 17 box in one pc...besides the 4 pc ports i use pci usb so there is 9 ports now plus 2 in front to make 10 usb...now you need to know the combination of box so it wont have conflict...good luck..
Old 03-01-2010, 01:22   #12 (permalink)
yassinek85's Avatar
Member: 938547
Sonork: 100.1591926
if have more work buy other pc and all its ok no need to use 10000box in one pc
Old 03-02-2010, 00:22   #13 (permalink)
Max_B's Avatar
Member: 16856
Sonork: 1582037
Connect as many boxes as you want !
We are in two thousand fuccking ten
Max_B
Old 03-02-2010, 21:41   #14 (permalink)
Member: 665242
Can you please give us your order and wich com ports you use?
Thanks
::Here How To Work With Spider-Man Box :: SiLver GSM SpiderMan 139 03-09-2012 17:58
I not know how to work with sagdd box . mileta5 SAGEM JTAG UNLOCKER 8 02-20-2009 10:49
Page generated in 0.52378 seconds with 11 queries
