09-09-2014, 18:37 | #1 (permalink) |
Freak Poster Join Date: Jan 2012 Location: On Earth
Member: 1716439 Status: Offline Thanks Meter: 38 | Huawei fc312e unlock issue thnks. cosmin d. |
09-10-2014, 00:04 | #2 (permalink) |
No Life Poster Join Date: Oct 2007 Location: PT
Member: 600502 Status: Offline Sonork: 100.1653742 Thanks Meter: 91 | http://i48.tinypic.com/2ia2x06.jpg File:Connector mini-usb male.png - AllPinouts furious pin 7-8=pin 1 mini-usb furious pin 2=pin 3 mini-usb furious pin 3=pin 2 mini-usb i think is this the correct if not correct tell that i can see best |
The Following User Says Thank You to mr.kopy For This Useful Post: |
09-10-2014, 17:44 | #3 (permalink) | |
Member: 1716439 Status: Offline Thanks Meter: 38 | Quote:
may be i have already on the 52-54 cables of furious suport this one, if you know number ok, otherwise i´ll have to invent one. | |
03-11-2017, 10:46 | #7 (permalink) |
Junior Member Join Date: May 2016 Location: venezuela
Member: 2578927 Status: Offline Thanks Meter: 1 | Hello friends, apparently the connection is through a cable uart to mini usb, now my question is with which module or in which pack is supported for said model thanks ... |
03-13-2017, 06:09 | #8 (permalink) | |
Member: 1716439 Status: Offline Thanks Meter: 38 | Huawei fc312e unlock issue Quote:
Hi, as the model is Qualcomm you need to use pack 5 qcom tab or pack 2 sw. Try to read/dump first for security reasons and after do direct unlock. If direct unlock failed then you need to send full dump to Furious support for checking purpose. They will make custom flash firmware and after you will do direct unlock. I will come back later with more info.All best for you. | |
03-13-2017, 22:00 | #9 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
Br | |
