10-24-2019, 08:54 | #1 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Skopje, Macedonia Age: 36
Member: 472933 Status: Offline Sonork: 100.1590967 Thanks Meter: 1,331 | Huawei P10 VTR-09 can't write BL via testpoint hi i have hw p10 with imei null problem and phone restart after few seconds. I see yesterday update for repair nv/downgrade tried that but always incomplete. im using latest version of fly ressurector and do the same test point like on the picture i repaired more than 4-5 p10 vtr-l09 with software problems last year this phone has android 9 and cant acces becoze of restarting and high security logs of fly v39 are in attachments when i try to flash board always says: Quote:
10-24-2019, 11:32 | #2 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | You must use the special files for DOWNGRADE !!! VTR-Downgrade-Board-A067-7.0.0_r1.fcff and VTR-Full-Repair-NV-included-Board-A067-7.0.0_r1.fcff Br |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
10-24-2019, 11:45 | #3 (permalink) | ||
Member: 472933 Status: Offline Sonork: 100.1590967 Thanks Meter: 1,331 | Quote:
10-24-2019, 11:48 | #4 (permalink) |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | First use Downgrade. After use full repair ! Also charge the battery. I think thats the error of the error you get ! Br |
10-26-2019, 09:53 | #5 (permalink) | |
Member: 472933 Status: Offline Sonork: 100.1590967 Thanks Meter: 1,331 | ok, after flashing via tp first downgrade file: VTR-Downgrade-Board-A067-7.0.0_r1 than VTR-Full-Repair-NV-included-Board-A067-7.0.0_r1 now phone after 5 seconds restart in fastboot and also have only board firmware, not full. Quote:
than i repeat the same procedure, same results and tried to upgrade on 9 with this file, phone was bricked. Victoria-L09B 9.1.0.262(C02E9R1P9T8)_Firmware_9.0.0_r3_EMUI9.1.0 _05014KYG for sure phone has no hw failure becoze is everything working fine before someone tried to erase imei/nv data for changing imei. can i find tutorial what to check on software of fly ressurector when i try to flash with board firmwares and full firmwares and what is the diferences between basic and advanced flashing, rescure recovery and do i need to skip nv data and oem info writing? tnx a lot. | |
10-27-2019, 14:26 | #6 (permalink) | |
Member: 472933 Status: Offline Sonork: 100.1590967 Thanks Meter: 1,331 | Ok i found how to revive with this thread http://forum.gsmhosting.com/vbb/13626995-post12.html and phone has normal fw but when i try to repair imei/sn fly captian give me this: Quote:
11-01-2019, 14:53 | #7 (permalink) |
Freak Poster Join Date: Apr 2008
Member: 748456 Status: Offline Thanks Meter: 32 | I could finally revive VTR-L29, perhaps, it can help you with your device 1) Download here the flash tool for the board 2) Download here the board without files erasing nvm and modem. It is usefull for stf-l09/vrt-l29 and i guess for vtr-l09 3) Run IDT, click on settings button with tool image and choose file update_nv_rback.xml 4) after this flash oeminfo and then flash the service firmware As you will flash it from the old recovery from board software put the files like this put the file update.app to the dload directory and put iinto dload directory the directory STF-L09_hw_eu with file update_STF-L09_hw_eu.app 5) after flashing the firmware check in settings is there baseband. 6) flash again the board firmware 7) run flycaptain, choose repair UMTS, choose rewrite simlock data, factory reset and enter your IMEI One strange thing was that I also after that ran direct unlock but after flashing I was asking the code to unlocke the phone, so i flashed again the board software and unlocked it via HCU 8) flash oeminfo and again flash the service user software I tried to revive my vtr-l29 with no network for 2 months with HCU, everything was ok, but no network Flashing NVM from support of dc phoenix makes just imei null null and no baseband But reflashing and reviving with furios fixed the problem Perhaps, you should flash the whole board software. If you failed to flash it, i will upload the full version |
The Following 2 Users Say Thank You to Alva For This Useful Post: |
