04-01-2019, 17:20 | #1 (permalink) |
Freak Poster Join Date: Aug 2004 Location: WORLDWIDE
Member: 78516 Status: Offline Thanks Meter: 62 | Huawei p20 pro clt-al00 failed remove huawei id [SOLVED=SOLUTION INSIDE] Code: Device detected: BOOTLOADER File to update: Kirin970_T2_A8.1_V5 OEM File to update: CLT-AL00 01/04/2019 17:40:00 Starting to write device... Writing bootloader... Writing Kirin970_T2_A8.1_V5_3.dtwork... Writing Kirin970_T2_A8.1_V5_4.dtwork... Writing Kirin970_T2_A8.1_V5_5.dtwork... Waiting for fastboot device... Device found: D5F7N1871600XXXX Looking for a device in fastboot mode Device found: D5F7N1871600XXXX Getting IMEI... Getting build number... Getting model ... Getting battery state... Getting backdoor info... Getting lock state info... Getting lock boot info... SN:D5F7N1871600XXXX IMEI:86981304XXXXXXX IMEI1:86981304XXXXXXX MEID:A000009376XXXX Build number: :CLT-AL00 8.1.0.176(C00) Model: CLT-AL00 Battery state: 5956mv OEM lock state info: FB LockState: UNLOCKED USER LockState: LOCKED OEM get bootinfo: unlocked Writing OEMINFO partition OEMINFO partition UPDATE ...OK Software written 01/04/2019 17:40:48 Writing device finished OK 1 I put it in HUAWEI USB 1.0 mode by using testpoint 2 I checked use bootloader 3 I selected the bootloader 4 I checked "Update OEMINFO and Unlock Huawei ID" 5 I selected CLT-AL00 6 I clicked update Do I need to flash it after this ? What is wrong ? Thanks |
The Following User Says Thank You to tooko For This Useful Post: |
04-01-2019, 18:27 | #2 (permalink) |
Member: 78516 Status: Offline Thanks Meter: 62 | I did a factory reset ! Huawei ID remains ! I changed OEMINFO selecting CLT-L29 instead of CLT-AL00 , the device hung on logo! I changed back to the right OEMINFO , Huawei ID remains ! I want to flash it but there are only CLT-L29 and CLT-L09 on the support and for some reasons I cannot download them ! Can I convert it from CLT-AL00 to CLT-L29 ? any idea ?? Thanks |
04-13-2019, 14:54 | #8 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Havana, CUBA
Member: 181633 Status: Offline Thanks Meter: 730 | Download full firmware from HERE. 1. Change OEMINFO to CLT-L29. 2. Flash firmware in UPGRADE MODE (not fastboot). 3. Then change OEMINFO only country again, phone must factory reset after completion. 4. Done HWID gone! |
The Following 4 Users Say Thank You to jepetu For This Useful Post: |
04-13-2019, 14:57 | #9 (permalink) |
Member: 181633 Status: Offline Thanks Meter: 730 | You can see my experience with an ALP-AL00 in this thread posts 13 and 14, it's the same process. |
The Following 2 Users Say Thank You to jepetu For This Useful Post: |
04-13-2019, 16:49 | #10 (permalink) | |
Member: 78516 Status: Offline Thanks Meter: 62 | Quote:
thank you jepetu . BR | |
04-16-2019, 12:14 | #11 (permalink) |
Member: 78516 Status: Offline Thanks Meter: 62 | Hi, tested with Huawei P20 pro CLT-AL00, it works like a charm, thank you jepetu. 1. Updated OEMINFO using tespoint to match needed vendor/country (in my case hw/spcseas) 2. Flashed CLT-L29 FULL ROM Charlotte-L29C_8.1.0.158(C636)_Firmware_8.1.0_r1_EMUI8.1_050 15AQX 3. Updated OEMINFO once more changing country to hw/eu to force phone to do a full factory reset because the diference after operation (this is NEEDED) thanks to jepetu BR |
The Following 6 Users Say Thank You to tooko For This Useful Post: |
05-29-2019, 06:23 | #12 (permalink) | |
Freak Poster Join Date: Mar 2016
Member: 2542848 Status: Offline Thanks Meter: 80 | Updated OEMINFO using tespoint Quote:
Hi Sir, Please help to explain me. There are many -Kirin970 A8.1_V1 -Kirin970 A8.1_V2 -Kirin970 A8.1_V3 -Kirin970 A8.1_V4 So which one should I choose the right ? Now my phone is CLT-AL00 DaulSim. Lock Huawei ID. android : 9 build number: 9.0.0.184(C00E57R1P15) Turbo Android Sec patch : April 1, 2019 Please help | |
05-29-2019, 07:35 | #13 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
You try all one by one. Only one will work Br | |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
