01-13-2014, 02:54 | #1 (permalink) |
No Life Poster Join Date: Feb 2007
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | Huawei Y300 after unlock with "Emergency call only" [SOLVED] Code: HUAWEI ANDROID UNLOCKER v1.00.0058 Searching Huawei phone COM ports... OK Application port: COM15 Diagnostics port: COM14 Driver version: 2.0.6.601 OEMSBL running: 8X25-2030-SSNSKOLYM Checking bootloader status... not running! Connecting to server... OK Sending data to server... OK Reading data from server... OK Sending data to server... OK Reading data from server... OK Sending data to server... OK Reading data from server... OK Uploading bootloader... OKOK Starting bootloader... OK Disconnecting from server... OK Initializing flash... OK Reading phone info... OK Decrypting IMEI... OK Reading sensitive data... OK Reading bootloader lock status... OK Model name: Huawei MSM8X25 series IMEI: 868442013978429 Bootloader status: locked SIM Lock status: locked (NCK lock) 2014-01-13 14:39:31.624 Start unlocking procedure (868442013978429) Connecting to server... OK Sending data to server... OK Reading data from server... OK Checking bootloader status... OK Initializing flash... OK Reading phone info... OK Decrypting IMEI... OK Reading sensitive data... OK Creating backup of Sensitive Data... OK Backup saved to file "C:\Program Files\FURIOUS-GOLD\PACK7\Backup\868442013978429_2014-01-13_143939.fhb" Sending data to server... OK Reading data from server... OK Writing flash... OK Reseting unblock retry counter... OK Sending data to server... OK Reading data from server... OK Disconnecting from server... OK 2014-01-13 14:39:41.459 Done! |
The Following User Says Thank You to chris2007 For This Useful Post: |
01-13-2014, 06:42 | #2 (permalink) | |
No Life Poster Join Date: Apr 2011
Member: 1552610 Status: Offline Sonork: 100.1604734 Thanks Meter: 1,370 | Quote:
repair imei if there is option | |
01-14-2014, 00:47 | #4 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | sorry this was post that i need help after unlock then use my client sim card that he said it a good sim after all and found out chaning sim then he said it a old sim and problems was solve but i have already post then edit the post sorry for that |
