04-13-2016, 02:46 | #1 (permalink) |
No Life Poster Join Date: Feb 2007
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | Huawei Y360-U72 unlock help [SOLVED=UNLOCKED] Code: Using library Brom_DLL_v7.1413.5 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM8)) Preparing to start flash mode; Preparing to open COM8 Connecting; Downloading DA; Initializing; Rid: 242b63fe8063d2f89e9bbd450a02882b Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver\x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem246.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM20; DEVICE INFO: BB CHIP: MT6572_S00 [CA01, 00, 6572, FF] HW_STORAGE_EMMC: 0x30000111 0x45473430 0x59120130 0xDFC2B775 [SIZE=0xEC480000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x6BB80000 SIZE: 0x80900000 Searching data; File not found; ST33A008 File not found; ERROR: EXT4_SIMLOCK_REMOVE failed; Time needed - 00:00:04 Log file saved to: LOG_13_04_2016_14_44_42.txt |
04-17-2016, 21:42 | #5 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | thanks for good support Code: Using library Brom_DLL_v7.1413.5 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM8)) Preparing to start flash mode; Preparing to open COM8 Connecting; Downloading DA; Initializing; Rid: 242b63fe8063d2f89e9bbd450a02882b Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver\x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem246.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM20; DEVICE INFO: BB CHIP: MT6572_S00 [CA01, 00, 6572, FF] HW_STORAGE_EMMC: 0x30000111 0x45473430 0x59120130 0xDFC2B775 [SIZE=0xEC480000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x6BB80000 SIZE: 0x80900000 Searching data; Locked to [SIM1]: FFF-FF code_cat_n: N/A enabled: no tries: 5 code_cat_ns: 66633BF2D8DA96AA enabled: yes tries: 10 code_cat_sp: 11112222 enabled: no tries: 10 code_cat_c: 33334444 enabled: no tries: 10 code_cat_sim: 55556666 enabled: no tries: 10 code_cat_ns_sp: 77778888 enabled: no tries: 10 code_cat_sim_c: 99990000 enabled: no tries: 10 Phone unlocked; Remove battery and cable; Time needed - 00:00:10 Log file saved to: LOG_18_04_2016_09_32_55.txt |
