12-19-2015, 21:35 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: JAMAICA Age: 46
Member: 220143 Status: Offline Thanks Meter: 108 | Huawei Y360 wont unlock after flash [SOLVED] Got a Huawei Y360 to flash. Flashed it with file from support and it powers up fine. But need to unlock it for it to accept network. Keep getting error: Code: Using library Brom_DLL_v7.1413.5 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (PreLoader USB VCOM Port (COM19)) Preparing to start flash mode; Preparing to open COM19 Connecting; Downloading DA; Initializing; Rid: be82b271cde3ac25d013256309affb49 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver\x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem8.inf,%mtk_sp_da%;DA USB VCOM Port) TRYING TO OPEN COM20; DEVICE INFO: BB CHIP: MT6582_S00 [CA00, 00, 6582, FF] HW_STORAGE_EMMC: 0x30000111 0x45473430 0x54880130 0xF322FCD2 [SIZE=0xEC480000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x6BB80000 SIZE: 0x80900000 ERROR: GET_PART_INFO; Time needed - 00:00:00 |
12-19-2015, 21:44 | #2 (permalink) |
Member: 220143 Status: Offline Thanks Meter: 108 | I also noticed that it was saying Get part erro so I tried to read partion got the following:- Code: Using library Brom_DLL_v7.1413.5 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (PreLoader USB VCOM Port (COM19)) Preparing to start flash mode; Preparing to open COM19 Connecting; Downloading DA; Initializing; Rid: be82b271cde3ac25d013256309affb49 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver\x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem8.inf,%mtk_sp_da%;DA USB VCOM Port) TRYING TO OPEN COM20; DEVICE INFO: BB CHIP: MT6582_S00 [CA00, 00, 6582, FF] HW_STORAGE_EMMC: 0x30000111 0x45473430 0x54880130 0xF322FCD2 [SIZE=0xEC480000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x6BB80000 SIZE: 0x80900000 ERROR: GET_PART_INFO; Time needed - 00:00:00 |
12-21-2015, 17:30 | #3 (permalink) | |
Member: 220143 Status: Offline Thanks Meter: 108 | Quote:
Help!!!!! I cant unlock the Y360 after flash from support | |
12-22-2015, 20:15 | #5 (permalink) |
Member: 220143 Status: Offline Thanks Meter: 108 | Not done with MTK Code Reader V1.0.0.600 Code: Searching phone; Phone detected (@oem8.inf,%mtk_preloader%;PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Adapter PCUI (COM73); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6582, E01 Sw version: MOLY.WR8.W1315.MD.WG.MP.V34.P46 Hw Version: WINGTECH82_CWET_KK_HSPA_HW Reading phone info; IMEI: 866838-02-045008-2 Reading simlock info; ERROR: Simlock data error (0) Time needed - 00:01:09 |
12-23-2015, 10:11 | #6 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,552 | Quote:
Br | |
12-29-2015, 00:27 | #7 (permalink) | |
Code: Using library Brom_DLL_v7.1413.5 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (PreLoader USB VCOM Port (COM19)) Preparing to start flash mode; Preparing to open COM19 Connecting; Downloading DA; Initializing; Rid: 8a21d8812ab44b8622b767b234fc638a Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver\x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem8.inf,%mtk_sp_da%;DA USB VCOM Port) TRYING TO OPEN COM20; DEVICE INFO: BB CHIP: MT6582_S00 [CA00, 00, 6582, FF] HW_STORAGE_EMMC: 0x30000111 0x45473430 0xD4A50130 0x05428DC3 [SIZE=0xEC480000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x6BB80000 SIZE: 0x80900000 ERROR: GET_PART_INFO; Time needed - 00:00:00 Log file saved to: LOG_28_12_2015_18_25_10.txt | |
12-29-2015, 23:05 | #8 (permalink) | |
Freak Poster Join Date: Dec 2005
Member: 209047 Status: Offline Thanks Meter: 7 | Quote:
same problem customers phone needed flashng used file on support now its simlocked without solution tried what was posted also | |
