12-23-2015, 14:57 | #1 (permalink) |
No Life Poster Join Date: Nov 2006
Member: 384641 Status: Offline Thanks Meter: 31 | I need help with unlock Huawei F317 [SOLVED] |
12-23-2015, 21:45 | #3 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
Br | |
The Following 2 Users Say Thank You to .:hack3r2k:. For This Useful Post: |
12-24-2015, 15:27 | #4 (permalink) |
Member: 384641 Status: Offline Thanks Meter: 31 | Thank you Sr. I do combination key and that ok , see of log of one Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (@oem66.inf,%dvcdsc%;SCI USB2Serial) Preparing to sync; Port opened [COM115]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT Chip type: 6530 FdlStat: C000 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00C8:0060:0016 - SIZE : 00400000 Reading phone info; PHONE INFO: NONE BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: 867428-02-848397-7 SW IMEI[1]: 352751-01-952326-7 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: ON FIXED NV BASE: 303C8000 Reading NV; NV saved to : NV_000000-00-000000-0_867428-02-848397-7_6530C000_24_12_2015_08_26_29.spd IMEI: 867428-02-848397-7 UNLOCK CODE: 1950362545788214 To finalise the unlock dial ####1111#, select NCK and enter the unlock code; Re-programming; NV programmed; Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_24_12_2015_08_26_38.txt Time needed - 00:00:19 |
The Following 2 Users Say Thank You to siscel For This Useful Post: |
07-18-2016, 20:35 | #5 (permalink) |
Freak Poster Join Date: Mar 2005 Age: 44
Member: 129016 Status: Offline Thanks Meter: 6 | hello, So sorry to bump an old thread but my problem relates.. I have a huawei f317 but it is IMEI locked to the sim and the sim also has a pin code. 1- is it possible to read the sim pin code from the f317 handset ? I want to use the original sim card in a different mobile phone . if i put the original sim in any unlocked mobile it says enter sim lock code. ( 3 tries left ) |
07-18-2016, 20:41 | #6 (permalink) | |
Br | |
07-19-2016, 11:39 | #7 (permalink) |
Member: 129016 Status: Offline Thanks Meter: 6 | Thank you so much for replying back, but I just want to understand before I buy the code, The code that I will get will unlock the f317 so I can use any sim in it that means it is the unlock code for the huawei f317, but what I want is the sim pin code ,so I can use the SIM card in a different mobile phone after receiving the unlock code and I enter it in the f317 ###1111# NCK option ? Or the code I receive needs to be entered when I put the SIM card in any mobile And it asks for sim pin lock code? That means the f317 has the sim pin lock code programmed in ..it is from Digicel Trinidad and Tobago . Thank again I hope I explained it clear .... |
The Following User Says Thank You to rampe For This Useful Post: |
07-20-2016, 08:22 | #8 (permalink) | |
You will enter the unlock code only once and after the phone will work with any sims without entering anything else Br | |
07-20-2016, 13:28 | #9 (permalink) | |
Member: 129016 Status: Offline Thanks Meter: 6 | Quote:
the f317 came with a sim that has a pin code , Lets call that sim A, so when i remove sim A from the f317 and place sim A in any unlocked mobile it asks for the sim lock pin code which i donot have , after I replace sim A back into the f317 it works normal no sim lock pin code is needed , so that means the sim lock pin code for sim A, is programmed into the f317. That is the code i need , so i can use sim A in any mobile device . Can that code be read from the f317 ? thank you ... | |
07-20-2016, 13:37 | #10 (permalink) | |
Br | |
07-25-2016, 11:10 | #11 (permalink) | |
The operator will not give me sim pin cause they donot want us to move the sim to a normal mobile they want the sim to stay in f317. The f317 has the sim pin stored , because no pin is needed when you power on the f317 handset. Can furious read the sim pin from the f317 ? Because no device can read the sim pin using the sim only , so I thinking I need to get it from the f317 when it is powering on ,the sim will ask for a pin and the f317 will answer with the correct pin.. Sent from my iPhone using Tapatalk | |
07-25-2016, 11:38 | #12 (permalink) | |
Br | |
