02-05-2020, 12:15 | #1 (permalink) |
No Life Poster Join Date: Jul 2007 Location: In My Laptop Age: 16
Member: 541117 Status: Offline Sonork: .::100.1586906::. Thanks Meter: 173 | JAT-AL00 dead solution need [SOLVED] could not flash by Jakarta-L29A 9.0.1.183(C432E5R2P1)_Firmware_9.0.0_r3_EMUI9.0.1_ 05015RRL Code: Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable with testpoint connected] Phone detected (MediaTek USB Port (COM48)) Preparing to start flash mode; Preparing to open COM48 Connecting; Downloading DA; Initializing; Rid: 7d1646debffe03740c4d44b88e9567b3 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6765 [CA00, 00, 6765, 00] HW_STORAGE_EMMC: 0x684A0190 0x50613842 0x5962013E 0xFFA68882 [SIZE=0x749400000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x14E800000 SIZE: 0xC0000000 |
The Following User Says Thank You to shahzadthe1 For This Useful Post: |
02-05-2020, 12:22 | #2 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,572 | I dont see any error there !? also can try Flash using Madrid-L21A 9.0.1.184(C431E5R2P1)_Firmware_9.0.0_r3_EMUI9.0.1. osp from support Br |
The Following 2 Users Say Thank You to .:hack3r2k:. For This Useful Post: |
02-05-2020, 13:18 | #3 (permalink) |
Member: 541117 Status: Offline Sonork: .::100.1586906::. Thanks Meter: 173 | Madrid-L21A 9.0.1.184(C431E5R2P1)_Firmware_9.0.0_r3_EMUI9.0.1_ 2.osp giving this error Code: Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable with testpoint connected] Phone detected (MediaTek USB Port (COM48)) Preparing to start flash mode; Preparing to open COM48 Connecting; Downloading DA; Initializing; Rid: 7d1646debffe03740c4d44b88e9567b3 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6765 [CA00, 00, 6765, 00] HW_STORAGE_EMMC: 0x684A0190 0x50613842 0x5962013E 0xFFA68882 [SIZE=0x749400000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x14E800000 SIZE: 0xC0000000 Loading the file ... Cfg done ... ERROR: STATUS_SCATTER_HW_CHIP_ID_MISMATCH Time needed - 00:05:25 Log file saved to: LOG_5_02_2020_17_16_12.txt |
02-05-2020, 13:20 | #4 (permalink) | |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,572 | Quote:
So use jakarta l29 file theb. With that which error you have !? Sent from my iPhone using Tapatalk Pro | |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
02-05-2020, 14:05 | #5 (permalink) |
Member: 541117 Status: Offline Sonork: .::100.1586906::. Thanks Meter: 173 | Done by try again with Jakarta-L29A 9.0.1.183(C432E5R2P1)_Firmware_9.0.0_r3_EMUI9.0.1_ 05015RRL thank you sir Code: Searching phone in normal mode; [connect the phone powered off to the usb cable with testpoint connected] Phone detected (MediaTek USB Port (COM48)) Preparing to start flash mode; Preparing to open COM48 Connecting; Downloading DA; Initializing; Rid: 7d1646debffe03740c4d44b88e9567b3 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6765 [CA00, 00, 6765, 00] HW_STORAGE_EMMC: 0x684A0190 0x50613842 0x5962013E 0xFFA68882 [SIZE=0x749400000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x687BFBE00 SIZE: 0xC0000000 Loading the file ... Cfg done ... Downloading images... Done; Downloading bootloader... Done; Success; Time needed - 00:04:49 Log file saved to: LOG_5_02_2020_17_39_28.txt |
