02-20-2010, 11:26 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: *P*A*K*I*S*T*A*N
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | KP175 restart problem KP175AT-00-V10b-286-XXX-SEP-10-2008+0 Code: Press power on button ... Phone detected ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Requesting baudrate change ... Baudrate changed ... Flash ID(0): 0001:227E:3C00 Writing flash image ... Done ! Time needed - 00:12:08 |
The Following 2 Users Say Thank You to StRaNgE PeRsOn For This Useful Post: |
02-20-2010, 14:05 | #2 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | Try KP170 flash files. If still same some hw fault ! Br |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
03-28-2010, 12:41 | #4 (permalink) | |
No Life Poster Join Date: Feb 2004 Age: 49
Member: 52828 Status: Offline Sonork: KHADIM100 Thanks Meter: 1,212 | Quote:
i have same fault with LG KP175, only startup logo, i flash phone with kp175 file file, now phone is working fine >>>>>>>>>> LOG <<<<<<<<<< Press power on button ... Phone detected ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Requesting baudrate change ... Baudrate changed ... Flash ID(0): 0001:227E:3C00 Writing flash image ... Done ! Time needed - 00:37:47 | |
The Following User Says Thank You to khadim100 For This Useful Post: |
04-07-2010, 17:11 | #5 (permalink) |
Freak Poster Join Date: May 2007
Member: 504184 Status: Offline Thanks Meter: 55 | Thanks brother solution is tested i also flash kp175 with its files and now fone is ok kp175 was hang on lg logo now its ok after flash. its 100% tested solution. brother flash with this file KP175AT-00-V10e-ARB-XXX-OCT-14-2008+0 Press power on button ... Phone detected ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Requesting baudrate change ... Baudrate changed ... Flash ID(0): 0001:227E:3C00 Writing flash image ... Done ! Time needed - 00:33:55 |
07-13-2010, 08:11 | #8 (permalink) |
Freak Poster Join Date: Oct 2007
Member: 621466 Status: Offline Thanks Meter: 20 | mr .:hack3r2k:. i have flash kp 175 set on completly but imei is 00000000 i tryed to repair but not sucssesfull please help me fg team Press power on button ... Phone detected ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Requesting baudrate change ... Baudrate changed ... Flash ID(0): 0001:227E:3C00 Searching flash image ... Reading flash image ... Unlock finished ! Done ! Time needed - 00:00:44 with imei at repair Phone must be on ! Press any key till screen lights on ! Error ... ! Time needed - 00:01:05 imei pach repair Press power on button ... Phone detected ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Requesting baudrate change ... Baudrate changed ... Flash ID(0): 0001:227E:3C00 Unavailable feature selected ! Done ! Time needed - 00:00:09 |
07-13-2010, 08:13 | #9 (permalink) | |
No Life Poster Join Date: May 2006 Location: Pakistan Age: 41
Member: 278548 Status: Offline Sonork: 100.1583183 Thanks Meter: 948 | Quote:
07-14-2010, 07:44 | #10 (permalink) | |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | Quote:
Br | |
07-14-2010, 19:21 | #11 (permalink) |
Freak Poster Join Date: Jan 2006
Member: 223818 Status: Offline Thanks Meter: 31 | even ido repair imie my kp175 still retsarts problem , and i flashed it with all flashes in supports , please can you upload the kp175 eeprom for me to try if it will fix that problem , regards |
07-15-2010, 09:27 | #12 (permalink) | |
This so called eeprom is stupid thing . All flashes from support ARE FULL ! If you phone restarts its because phone itself has a problem. Br | |
07-17-2010, 17:17 | #14 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: IN GSM
Member: 304574 Status: Offline Sonork: 100.1593675 Thanks Meter: 72 | eprom is hear Quote:
try with furious if notworked then try with infinity | |
E2130 restart problem.... | aikonmani | SWIFT Platform | 11 | 10-24-2012 07:49 |
cect v180 restarting problem but after ffs same problem | shripalkawdia | Infinity-Box | 9 | 05-09-2009 02:06 |
LG KE800 restart problem but 1st problem is bluetoth | Freshbol | Infinity-Box | 4 | 02-13-2008 20:14 |
N95 had restart problem and now have problem with sensor key | Supermen! | Infinity-Box | 2 | 11-23-2007 09:23 |
6270 startup restarting problem help big problem | vinay_sharma | Nokia Hardware & Hardware Repair | 5 | 07-07-2007 22:06 |
