Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > FuriousGold
FuriousGold FuriouS GOLD Support Area | Powered by FuriousTeam
Old 05-21-2009, 12:16   #1 (permalink)
Member: 420820
Thanks Meter: 71
LG KU990iGO Flash problem while unlocking
I have just got hold of a new viewty which is showing as SW;
KU990iG-MSM6280-V10a-FEB-25-2009-XX
when checked with furious shows as KU990iGOAT-01-V10a-234-10-FEB-25-2009+5
I downgraded firmware so i could unlock using FG pack 5.
When downgrading the screen turns yellow and says refreshing, i unlocked anyway using pack 5 and unlock went fine according to software. I then try to recover handset from "refreshing" screen by upgrading firmware back to KU990iGO FW;
KU990iGO-DZ-V10a+5-FEB-25-2009-o2-G
BUT i get the same problem after flashing back to this FW, just shows a yellow screen and "refreshing", i have tried in emergency mode as well but just get the same problem!
Could someone please advise how to recover this handset, many thanks in advance
Old 05-21-2009, 12:37   #2 (permalink)
Member: 717046
Thanks Meter: 237
flash phone lg to flash lg ku990 and unlock......gooode teste 100%
Old 05-21-2009, 13:14   #3 (permalink)
Member: 595700
Sonork: 100.1582336
Thanks Meter: 262
ku990i unlocked
hi bro, check this.... ur problem solve....
successfully unlocked ku990i n ku990iGO.
Old 05-21-2009, 13:23   #4 (permalink)
Member: 420820
Thanks Meter: 71
I have tried using the LG software upgrader it starts flashing, gets to 4% and then comes up with "problem with communication between cell phone and PC"
But now the phone just hangs on LG screen with "Please wait..." underneath, any ideas how to revive would be much appreciated
I will try Sebhas method by flashing ku990i file even tho this is a KU990iGO, see if that works and post result
Old 05-21-2009, 13:36   #5 (permalink)
Member: 595700
Sonork: 100.1582336
Thanks Meter: 262
hi.
bro which flasher u use ?.. but if u have furious-gold is best.
2nd .. use origenal usb cable battery atleast 50% charged..
3rd ... flash ur fone in emergency mode...how to put
1- To enable EMERGENCY DOWNLOAD
2- PRESS GREEN KEY + "C" KEY + KEY LOCK BUTTON + POWER ON.
BE SURE U PRESS THEM IN THIS ORDER AND U KEEP THEM PRESSED.
REMEBER: USE USB CABLE
hope problem solve ..................?
Last edited by sebha; 05-21-2009 at 13:40. Reason: ku990i flash wed emergency mode
Old 05-21-2009, 13:53   #6 (permalink)
Member: 595700
Sonork: 100.1582336
Thanks Meter: 262
Ku990igo unlocked..
my fone is ku990igo firmware KU990iGO-DZ-V10a+5-FEB-25-2009-o2-G.rar
how chk 3845#*990#
Old 05-21-2009, 14:30   #7 (permalink)
Member: 420820
Thanks Meter: 71
Tried this as well but phone still hanging, battery is full as have charged in another phone and have also tried flashing in emergency mode but still the same problem, now just hanging on LG logo and "please wait..."
Old 05-21-2009, 14:41   #8 (permalink)
Member: 420820
Thanks Meter: 71
how chk 3845#*990#
Checked this when i first got phone,
it is a KU990iGO, tried flashing with iGO file and still not working, i am flashing it with Furious QFG module
Old 05-21-2009, 15:11   #9 (permalink)
Member: 595700
Sonork: 100.1582336
Thanks Meter: 262
hi bro, try this files....
1. ku990i-dz-v10a-feb-25-2009-csm-g-rar
2.ku990i-dz-v10a+4-feb-23-2009-opn-g-rar
3.ku990i-dz-v10a+1mar-24-2009-opn-d-rar
if flash going ok if not maybe before u flash wed v10b.or v10c so than u find v10b or a10c smilar files...... ? post result
Old 05-21-2009, 17:13   #10 (permalink)
Member: 420820
Thanks Meter: 71
Tried flashing several KU990iGO files to phone of a similar type to original but still getting the yellow screen, now saying File system startup please wait and handset is just hanging on this screen but when i take battery out and turn on it just hangs on LG logo with Please wait... below it, please help as need to recover this handset ASAP
The Following User Says Thank You to roxrox For This Useful Post:
Old 05-26-2009, 11:30   #11 (permalink)
Member: 420820
Thanks Meter: 71
still having problems with this phone, stuck oin refresing screen, any further options??
Old 05-26-2009, 13:43   #12 (permalink)
Member: 420820
Thanks Meter: 71
I try using Hack's method that i found in another post;
"To repair is simple. Write back KU990i FW.
After using pack 5 do:
1. RESTORE PHONE USING KU990i.bin
2. REPAIR IMEI
3. UNLOCK"
Here is the logs;
FLASHING
Flashed handset back to KU990iGO firmware, closest file i could find
KU990iGO-DZ-V10a+2-FEB-26-2009-o2-D.sex with "forced mode selected"
Searching phone ...
MODEL : KU990
INIT FLASHING ENGINE ... OK;
NV READ SKIPPED;
UPLOADING STARTED;
WORKING IN EMERGENCY MODE;
EFS ERASING;
RESETTING PHONE !
WAITING 25s PHONE TO WAKE UP;
PHONE ONLINE;
Deleting folder :
/LGAPP/Media/Common/Battery
Deleting folder :
/LGAPP/Media/Common/Logo
Deleting folder :
/LGAPP/Media/Common/SubLCD
Deleting folder :
/LGAPP/Media/Common
Deleting folder :
/LGAPP/Media/Images/Default images
....TOO MUCH TOO POST HERE BUT ALL FLASHED FINE....
phone is now on LG logo with Please wait underneath
RESTORE;
MODEL : KU990i
COMPILED DATE : Mar 21 2009 16:21:00
RELEASE DATE : Feb 26 2009 17:00:00
FIRMWARE INFO : KU990iG-MSM6280-V10a-FEB-26-2009-XX
IMEI : 354693030*****
BLUETOOTH ADDR : B1 79 F8 A1 19 00
MEMORY ID : 0098:00CA
MEMORY NAME : toshiba_tya000bc00bogg
MEMORY INFO : 0800:0040:06BB
LOADING INIT DATA;
RESETTING PHONE !
WAITING FOR PHONE TO POWER ON 30 SEC;
PHONE ONLINE;
SW VERSION: [OK] Invalid Module Software Version
IMEI: [OK] 35469303*******
BLUETOOTH ADDR: [OK] 0019A1F879B1
PLAYING MUSIC ... WAIT;
DOING CONFIG;
Error ... !
Time needed - 00:01:31
I get this error when trying to restore, please help Hack
Old 05-26-2009, 18:03   #13 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,595
did u solve ur pb on ku990ig..?
Old 05-26-2009, 20:06   #14 (permalink)
.:hack3r2k:.'s Avatar
Member: 15022
Sonork: 100.53452
Thanks Meter: 56,335
2. REPAIR IMEI
3. UNLOCK"
Here is the logs;
FLASHING
Searching phone ...
MODEL : KU990
NV READ SKIPPED;
UPLOADING STARTED;
EFS ERASING;
RESETTING PHONE !
PHONE ONLINE;
Deleting folder :
Deleting folder :
Deleting folder :
Deleting folder :
/LGAPP/Media/Common
Deleting folder :
RESTORE;
MODEL : KU990i
LOADING INIT DATA;
RESETTING PHONE !
PHONE ONLINE;
DOING CONFIG;
Error ... !
I CLEARLY WROTE IN UPDATE . NO SIM INSIDE !!!!!!!!!!!!!!!!!!! PHONE MUST DISPLAY 'INSERT SIM' !
Old 05-27-2009, 10:23   #15 (permalink)
Member: 420820
Thanks Meter: 71
ALL of the above was done with NO SIM inside, But phone will NOT get to INSERT SIM screen!!!
All the phone is doing is showing LG Logo and "Please Wait..." underneath
Still stuck with this phone, tried flashing to V10b FWs and still same problem,
LG TU720 problem while unlock [Answered] fasttechjlm Activation Software Support (HTC, BLACKBERRY, ALCATEL, LG/ZTE, SAGEM/SE) 6 08-30-2011 10:21
Problem while unlock LG KP5500-Boot Failed! [Solved] svchost Z3X-Team Products 3 11-21-2009 12:32
problem while unlocking u970 lg... SicilianBoy FuriousGold 2 02-28-2008 13:06
having problem while unlocking LG 8138 ejazkhan9 LG 3G (USB-Smart) 5 04-19-2006 13:52
problems while unlocking Siemens C45 MisterVegas Phone Unlocking Codes & Maps 0 07-01-2004 13:15
Page generated in 0.43748 seconds with 8 queries
