10-31-2018, 19:32 | #1 (permalink) |
No Life Poster Join Date: Jan 2014 Location: africa mali
Member: 2098907 Status: Offline Thanks Meter: 154 | m4 ss1010 after unlock succe invalid simcard (solved) Keep pressing the power button if serial used ! (for USB connection keep SPACE or * (STAR) key pressed and insert the usb cable) Connecting; Meta mode entered; Baseband Chip: MT6276 Sw version: M4TEL_SS1010_S03_Ver203 Hw Version: CKT76_11B_HW Reading phone info; IMEI: 865935-01-040419-3 Reading simlock info; Unlock codes: Locked to: FFF-FF code_cat_n: N/A enabled: no tries: 5 code_cat_ns: N/A enabled: no tries: 5 code_cat_sp: 0000000000 enabled: no tries: 5 code_cat_c: N/A enabled: no tries: 5 code_cat_sim: N/A enabled: no tries: 5 code_cat_ns_sp: N/A enabled: no tries: 5 code_cat_sim_c: N/A enabled: no tries: 5 Time needed - 00:00:34 Log file saved to: LOG_31_10_2018_16_34_19.txt |
11-01-2018, 18:53 | #5 (permalink) |
Member: 2098907 Status: Offline Thanks Meter: 154 | her is nvra, backu^p https://www.4shared.com/file/UJB6bL8...501040419.html |
The Following User Says Thank You to goudio For This Useful Post: |
11-06-2018, 18:47 | #9 (permalink) |
Member: 2098907 Status: Offline Thanks Meter: 154 | not solved COM opened ok; Phone must be powered off; Keep pressing the power button if serial used ! (for USB connection keep SPACE or * (STAR) key pressed and insert the usb cable) Connecting; COM opened ok; Phone must be powered off; Keep pressing the power button if serial used ! (for USB connection keep SPACE or * (STAR) key pressed and insert the usb cable) Connecting; Meta mode entered; Baseband Chip: MT6276 Sw version: M4TEL_SS1010_S03_Ver203 Hw Version: CKT76_11B_HW Reading phone info; IMEI: 865935-01-040419-3 Reading simlock info; Unlock codes: Locked to: FFF-FF code_cat_n: N/A enabled: no tries: 5 code_cat_ns: N/A enabled: no tries: 5 code_cat_sp: 0000000000 enabled: no tries: 5 code_cat_c: N/A enabled: no tries: 5 code_cat_sim: N/A enabled: no tries: 5 code_cat_ns_sp: N/A enabled: no tries: 5 code_cat_sim_c: N/A enabled: no tries: 5 Time needed - 00:01:00 Log file saved to: LOG_6_11_2018_17_42_48.txt |
11-07-2018, 08:08 | #11 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | Quote:
Do you select m4 ss1010 from teh models llists !? or something else ? Br | |
11-07-2018, 11:10 | #14 (permalink) |
Member: 2098907 Status: Offline Thanks Meter: 154 | unlocking not supported COM opened ok; Phone must be powered off; Keep pressing the power button if serial used ! (for USB connection keep SPACE or * (STAR) key pressed and insert the usb cable) Connecting; Meta mode entered; Baseband Chip: MT6276 Sw version: M4TEL_SS1010_S03_Ver203 Hw Version: CKT76_11B_HW Reading phone info; IMEI: 865935-01-040419-3 Reading simlock info; Unlock codes: Time needed - 00:00:18 Log file saved to: LOG_7_11_2018_11_09_15.txt |
