07-08-2018, 11:55 | #1 (permalink) | |
Freak Poster Join Date: Dec 2006 Location: Khartoum-Sudan
Member: 420318 Status: Offline Sonork: 100.1661057 Thanks Meter: 65 | MTN C290 Not unlocked C290 after flashing all patched file from support still gives invalid sim Quote:
MEMORY_DUMP_MTN C290_000000-00-000000-0_NONE_65310001 | |
The Following User Says Thank You to sudsud For This Useful Post: |
07-09-2018, 15:33 | #5 (permalink) |
Member: 420318 Status: Offline Sonork: 100.1661057 Thanks Meter: 65 | all of them tried but not unlocked: 1- MTN_C290_EN_FR_ARABIC-2.spd 2- MTN_C290_EN_FR_PT_ARB-2.spd 3- MTN_C290_EN_FR_PT_ARB-2-NEW.spd |
07-09-2018, 18:36 | #6 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Impossible. What phone displays ? Also try SIMLOCK remove after writing the file Br |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
07-15-2018, 12:20 | #9 (permalink) | |
Member: 420318 Status: Offline Sonork: 100.1661057 Thanks Meter: 65 | still invalid sim Quote:
seem it's new firmware because the imei is not detected in the log here the log when i try to unlock: Port opened [COM24]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT Chip type: 6531 FdlStat: 0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00EF:0040:0016 - SIZE : 00400000 Reading phone info; PHONE INFO: NONE BT ADDR: NONE SW IMEI[0]: NONE SW IMEI[1]: NONE SW IMEI[2]: NONE SW IMEI[3]: NONE SIMLOCK FLAG: OFF FIXED NV BASE: 303C0000 Reading NV; NV saved to : NV_000000-00-000000-0_NONE_65310001_15_07_2018_13_16_10.spd IMEI: NONE UNLOCK CODE: NONE ERROR: Simlock not enabled ! Phone is unlocked; Log file saved to: LOG_15_07_2018_13_16_44.txt Time needed - 00:00:46 | |
07-17-2018, 15:32 | #12 (permalink) |
Member: 420318 Status: Offline Sonork: 100.1661057 Thanks Meter: 65 | unfortunately i can't send a sample, i have only 3 phones here but if u need to read dump or board picture i can do that... i believe sooner or later you will do ur best and this new versions will be supported Thanks Daniel |
07-18-2018, 09:06 | #14 (permalink) | |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
Honestly wont loose time on an old phone which i dont have.. I cant do anything with a picture. Br | |
07-19-2018, 18:21 | #15 (permalink) | |
Freak Poster Join Date: Sep 2012 Location: Malawi, Africa
Member: 1814195 Status: Offline Thanks Meter: 17 | Quote:
