06-11-2018, 13:55 | #3 (permalink) |
Insane Poster Join Date: Sep 2010
Member: 1404722 Status: Offline Thanks Meter: 46 | sp6531.here is the firmware dump if it possible to patch,plase patch it after upload to the server.thanks https://drive.google.com/file/d/1_62...ew?usp=sharing |
06-12-2018, 07:23 | #4 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
Hi, The dump is bad. try reading using other model, The dump will be ok when you can see the imei number. As long is NONE the dump will be bad Br | |
06-12-2018, 22:16 | #6 (permalink) |
Freak Poster Join Date: Oct 2003 Location: Oslo Age: 41
Member: 41299 Status: Offline Thanks Meter: 16 | CPU: SC6531 Detected: SCI USB2Serial (COM13) Sending loader, keep boot key untill loader start. Loader OK: CPU: 6531 FlashId: WINBOND: [0x400000]W25Q32FV Reading Flash Info, wait... Flash Size: $400000 Sector Size: $8000 NVRAM Status: NV_MINVALID_SOK |
06-13-2018, 07:48 | #7 (permalink) | |
select NAVON T10 CLASSIC in SPDTool and read the flash. Br | |
06-13-2018, 08:36 | #8 (permalink) |
Member: 1404722 Status: Offline Thanks Meter: 46 | here is another t20 dunp https://my.pcloud.com/publink/show?c...5k4W4zLQ2XB1Qy |
06-13-2018, 20:48 | #9 (permalink) | |
There is still some bug in teh dump. Could you try to read again using Lanix U100 ? Br | |
06-13-2018, 21:55 | #10 (permalink) | |
Member: 1404722 Status: Offline Thanks Meter: 46 | Quote:
http://pc.cd/hMPctalK | |
06-14-2018, 07:31 | #11 (permalink) | |
Dump is ok now. Select simlock remove with Lanix u100 selected. Should unlock it ! Br | |
06-14-2018, 08:25 | #12 (permalink) | |
. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (@oem78.inf,%usbcomm_dl%;SPRD U2S Diag) Preparing to sync; Port opened [COM47]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT Chip type: 6531 FdlStat: 0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00EF:0040:0016 - SIZE : 00400000 Reading phone info; PHONE INFO: NONE BT ADDR: 11:28:16:13:13:26 SW IMEI[0]: 357992-08-088820-6 SW IMEI[1]: 352751-01-952326-7 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: ON FIXED NV BASE: 303B0000 Reading NV; NV saved to : NV_000000-00-000000-0_357992-08-088820-6_65310001_14_06_2018_09_20_59.spd IMEI: 357992-08-088820-6 UNLOCK CODE: NONE Re-programming; NV programmed; Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_14_06_2018_09_21_18.txt Time needed - 00:00:27 | |
